Question about Campbell Hausfeld Single Stage Air Compressor. Single Stage Cast Iron Compressortwin Cylinder Vt Pump with Flywheel
Compressor not wired, no schematic or instruction in manual
Purchased a Campbell Hausfeld VT6275 compressor from Lowes. No wiring , no instruction on how to. I know it is 240 volt, 15 amp but nothing provided to help me and I prefer to not guess and also prefer to not need to contact electrician.
I was told to use 12-3 wire to my box , but that is it. I have some experience with 110-120 but very limited on the actual wiring of 240 units.
Help please
  • Matt beakley Nov 12, 2011
    That schematic shows nothing I m in same situation what did you do to resolve?
    Scholar:
  • 104 Answers
There is a schematic under the cover of the elecrtrical connection box. Remove the top of the box ( typically one nut on top of the pressure regulator) and look under the cover you removed.
Good Luck
Posted on Feb 07, 2009
Looking for instruction manual for Campbell Hausfeld 5 in 1 cordless PowerPal
Go to the Campbell Haousfeld home page (http://www.chpower.com/) and under the Sservice & Support tab select Manual/Parts List. Put IB200100AV in the Find Model box and hit search. If your model number on the compressor is different use that. You will then be able to download the manual and parts list.
Feb 02, 2012 | Campbell Hausfeld Air Tools & Compressors
Husky Manual for TF291201AJ
Go to http://www.chpower.com/manualsearch/ (its the Campbell-Hausfeld website) and put TF2912 in the 'Find Model' search box and you'll get the operating instructions, parts lists and other information on your compressor.
Oct 16, 2011 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
How do I get an instruction manual?
Try Googling: instruction manual Campbell Hausfeld CC2300 12V RCH Air Compressor
Dec 15, 2010 | Campbell Hausfeld CC2300 12V RCH Air...
I have a 240v plug in with 4 wires ( red and black-hot, white-common, and copper-ground) and on my campbell hausfeld air compressor i have only three wires ( white and black- hot and green-ground) how do i...
First are you sure your compressor is wired for 220. If so \,use the white and black for the hots connected to the black and red in your recptacle. Connect the green to green or bare conductor. The compressor most likely has no 120V devices on it so the neutral is not requied.
Jul 13, 2010 | Campbell Hausfeld Air Tools & Compressors
Need owners manual for campbell hausfeld vt6275
go to chpower.com and type in your model number under the header needing manual and it lists several different options for you. Hope this helps and if I have helped you with your request would you please rate this response accordingly. Thank you.
Nov 20, 2009 | Campbell Hausfeld Air Tools & Compressors
Need a wirring diaphram
At the risk of sounding stupid, did you try their website?
May 24, 2009 | Campbell Hausfeld 28 - Gallon Air...
Hose from compressor to air tank
Campbell hausfeld parts are available at www.chpower.com, however, you can use standard parts like copper tube or rubber pressure hose available at Lowes lumber or True Value Hardware. Check for cause of failure of the airline, could be from vibration due to loose motor mount or faulty check valve at tank causing back pressure. Enjoy
Dec 09, 2008 | Campbell Hausfeld 13 - Gallon Air...
Wiering
look at the motor nameplate it should have voltage and fla which is full load amps this should be calculated by an electrician for wire size hope this helps
Aug 05, 2008 | Campbell Hausfeld 04 Gallon Twin Stack...
Campbell Hausfeld Single Stage Air Compressor. Single Stage Cast Iron Compressortwin Cylinder Vt Pump with Flywheel Logo
576 people viewed this question
Top Campbell Hausfeld Plumbing Experts
Paul Carew
Tom Chichester
Are you a Campbell Hausfeld Plumbing Expert? Answer questions, earn points and help others
