Question about Gaggia Classic Espresso Machine
Where do I locate the fuse for the steam nozzle of the Gaggia Classic? - the coffee brews but no steam will come out to froth up -I was advised it was probably the fuse -all othe rparts have been cleaned
    President:
  • 1,618 Answers
If the coffee brews hot then the problem is a blockage on the steam valve nozzle or line. Try removing steam wand and opening valve to see if it works, if it does the problem is in the wand that has been removed. Dismantle parnello and using a paperclip clear out the hole in the end of the steam wand.
Posted on May 18, 2009
Where is pinhole on frothing wand classic gaggia machine
IT IS INSIDE THE INJECTOR ASSEMBLY. IF STEAM DOES NOT COME OUT THE ACTUAL STEAM TUBE THEN ITS CONTROL VALVE OPERATED BY THE ROTATING KNOB IS CLOGGED. REPLACE THE VALVE IF DESCALING WOULD NOT CLEAR OF THE INTERNAL ORIFICES.
Sep 23, 2014 | Gaggia Classic Espresso Machine
My Gaggia classic has suddenly stopped frothing
Hi There,
You are not getting enough steam, to produce the froth and there no blockage. I suggest you replace the thermostats. Takes 10 min max.. Gaggia thermostat set
Sep 28, 2017 | Gaggia Classic Espresso Machine
Frothing attachment coming off from pressure
Check the holes in the attachment they might be blocked and the pressure of the steam is blowing it off.
Apr 14, 2010 | Gaggia Classic Espresso Machine
Gaggia Coffee Delux Steam pressure probem
1: do you pres the switch for steam and wait until it is ready? 2: how long time machine needs to be ready for steaming?
solution 1 = if you don't press the steam switch on you will have very small amount of steam. solution 2 = if the machine gets ready only for few seconds to steam, than you must change your steaming thermostat attached in boiler(there are 3 of them: 1 security 2 coffee brewing 3 steam
i hope you fix it soon and enjoy in perfect espresso
Apr 04, 2010 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
The water coming out of the steam nozzle is clear but fromthe brew head it is milky looking. I have descaled
That's ok .
The water from the steam nozzle is straight from a boiler.
Where as the brew head is fed from another boiler via the brew unit,so you will still have some coffee in the system.
If you wanted to you can rinse the brew head by making preground coffee without coffee this will flush it clean.
Nov 28, 2009 | Gaggia Titanium Espresso Machine
Gaggia classic -no steam from spout
I had almost the exact same thing. The fuse for your frother is out. If both the frother and the brew head won't heat, then it is your Thermal Fuse. There are two different fuses inside the machine. Take the top off, and find both fuses. Take a piece of wire and connect it to each end of the fuse. Now turn the power on. If it heats, then that is the fuse. If no results, try the other fuse. Either fuse should be cheap. My thermal fuse was $1.98. Good luck!
Jan 07, 2009 | Gaggia Classic Espresso Machine
Gaggia Steam Nozzle
There is a sit where you can get the parts for the gaggia it is at WholeLatteLove.
Jan 04, 2009 | Gaggia Classic Espresso Machine
Losing steam
Try to descale the machine to see if will be better.
Aug 13, 2008 | Gaggia Classic Espresso Machine
Gaggia Classic Espresso Machine Logo
261 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
