Question about Microsoft Xbox 360 Controller
Broken mic port
My mic hook got broke off inside the port and i had to tear up the controller to get the broken peice out.So now the controller port is ripped out and all that there is now is two metal bars where the mic should go
What can I do hdmi broke off of ps4
turn off and unplug. wait 15 minutes. get needle nose pliers and pull broke peice out. make sure to get all little peices out. vacuum the port to extract all the small peices. plug new hdmi in and enjoy
Jun 22, 2015 | PS4 Video Game Consoles & Games
My speaker jack broke off inside my audio input in the back of the computer. I want to use the thermaltake case's front usb and audio out/mic in jacks, but they don't seem to get power or work. My drivers...
> Have you removed the broken jack from the rear end of the pc ?
> Are you trying to use the audio ports on the front panel ?
> if you are trying to use the audio port on the front panel you will first need to remove the piece of the broken jack stuck in the rear port - cos you can take an audio out line either from the front OR the rear any one
Oct 22, 2013 | Thermaltake Mid-Tower VL10001W2Z Element G...
The gameboy wont charge
maybe you have to go to an electronic technician to fix your problem.they have the expertise in opening the gameboy and repair the broken charging port.
Jun 25, 2010 | Nintendo Game Boy Advance SP Blue Console
One headphone has stoped working completeley and the other has a broken fussy noise ?
Ok. One head phone's wire may have broken some how. And the other may have got water in it or broke aswell. If not then it may be the ear peice port that is not running properly. Or most of all the earphones have blown. You can pick up some cheap and good earphones from **** smith's or the warehouse from a price range from around $10-$60. Hope i have helped.
Thank's
Mar 18, 2010 | Monster Cable Radio Communications
I have a 93 crand caravan the water pump went out and in the process of changing it bolts broke how can i fix it?
If the bolts broke off inside the engine block they must be extracted, buy a easy out set of bolt extractors choose the appropriate size drill to use in relation to the broken bolt to be removed then dril a hole through the old broken off peice remaining inside the bock take the easy out extrctor and push it into the drilled hole then tap it into the hole firmly proceed to tur n the extractor counter clockwise to remove the broken off peice. whatever you do don't use an extractor that is too large it may not work you can always go up on the size later.
Dec 15, 2009 | 1992 Dodge Grand Caravan
EWF TV ANT IN BOKEN
It can be soldered back on. With that particular model, I don't know if the connector is connected to the tuner or if there is a litte square anteena box which then feed a cable to the tuner.
Nov 26, 2008 | Televison & Video
Xbox 360 broken controller
i will buy it if you dont want it any more
Aug 23, 2008 | Microsoft Xbox 360 Controller
Microsoft Xbox 360 Controller Logo
588 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
