I have a modem with a wireless card that AOL Broadband provided. It is a Comtrend CT-534 and works great when connected to my desktop. But when I try to use the wireless card to connect to my laptop I get a "connected" and "excellent" signal message but I can't open a browser window. Any suggestions?
  • 1 more comment
  • peej0e Jan 15, 2009
    rtrahan - I did what you said and got an error message that says:
    "An error occurred while renewing interface Wireless Network Connection: unable to contact your DHCP server."
    I have a wireless ready DSL modem that gives me the DHCP server info. It also give me the DHCP Relay and Client info and right now the Relay is disabled. I have the ability to enable the Relay and then it asks me to add an IP address. Should I do this? And if so, do I add the DHCP Gateway IP address? Could this possible be my problem? Or do I still need to contact my ISP?
    Thanks for your help!
    The DCHP server seems to assign me an IP automatically, but when I try to repair or renew the IP it can't connect to the DCHP server.
  • DEKR
    DEKR May 11, 2010
    open your internet then type www.msn.com
    it just may be that you have your settings wrong
    were you ever able to access the internet
    let me know what the msn page says
    Genius:
  • 1,102 Answers
Can you open your internet connections through control panel right click on your wireless internet and click repair
Posted on Jan 15, 2009
  • DEKR
    DEKR Jan 15, 2009
    I take it you don't know your ip address
    you can get your ip by going back into control panel network connections
    right click on icon
    click status and then support
    the ip address should be in there
    that may be your problem
    you can always enable it type your ip address restart
    if internet does not come on then go back and do a repair on it
    let me know if that helps
  • DEKR
    DEKR Jan 15, 2009
    okay did you try what i suggested
    i think it is just a matter of a setting
  • 741 Answers
If you are getting a connected and excellent signal for your wireless connection then you need to double check the IP address. If you are not connecting to your Internet Service Providers Web server then this would block you from being able to connect to the web. While you are connected to your wireless card click on start>run>type in "cmd". This will bring you to the DOS prompt. Type in c:\ to get to the root directory. Then type in "ipconfig /release, then type in ipconif /renew. This will reconnect your network to your ISP's web server. If this does not work then the problem is at the ISPs end and there is nothing you can do to correct it immediately. You need to call your Internet Service Provider and explain your problem to them. What is happening is that your router DHCP protocol is not providing you with a proper IP address and they can only fix it on their end if the ipconfig does not fix it.
Don't forget to rate this solution with 4 stars.
Internet will not go through my comtrend CT-5072T modem
Need a bit more background on this.
Did you just go out and buy this device and hook it up to the phone line ?
Are you using ADSL line Filters ?
Did you ring your internet service provider to guide you through setting up the account settings in the modem ?
How are you connecting to the device to your P.C ?
Jan 25, 2015 | Comtrend Adsl2 Ethernet Router Model:...
No ip on comtrend ar-5381u, will not connect to internet
DO NOT INSERT A PAPER CLIP TO RESET THE MODEM! unless you know how to reprogram the router, this includes having complete knowledge of ALL the settings required by the ISP AND having your username and modem password (modem authentication passwords are not usually provided to the customer) Doing a "hard boot" will only return your modem to factory settings
Dec 21, 2012 | Comtrend CT-507 Router
Setting up for use on laptop
ay6dz0yqzpfvaaaaaelftksuqmccconnect the cable on the yellow jack and the other end to your pc.
Oct 27, 2012 | Belkin N150 Enhanced Wireless Router...
Modem will not cnnect through router but only direct to PC. two different wireless routers, same issue.
The issue is that your modem and router(s) have an IP conflict. Contact either your router support, or Internet Service provider. They should be able to help you without a hitch!
Jan 03, 2010 | Comtrend CT 300 (CT-300) Modem
Installation of the modem Comtrend CT-361 under Windows Vista
This appears to be an old model. Their website isn't very user friendly and they list no kind of tech support available. You can contact them here.
http://www.comtrend.com/na/contact.htm
They might be able to help you out if you call them but there is nothing available on their website or anywhere else that I see on the web. The product appears to be older then Vista and might have never had a Vista driver made for the product.
Oct 01, 2009 | Comtrend Adsl Usb Modem (ct-351)
Wireless webcam behind dsl modem/router and a wireless router
What you have to do is ,first covert the modem into bridge mode, then configure the router in pppoe modem by having internet username and password from ISP .. that will resolve your problem
Mar 22, 2009 | Linksys WVC54GCA Network Camera
Thomson SpeedTouch 576 wireless modem router
Connect your wireless modem router Sign on to AOL. Download the AOL Easy Installer for Thomson 576 Wireless Modem Router. When prompted to save the file to a location select an appropriate place (desktop is a good example). Once the AOL Easy Installer is downloaded, double click the file: ST_V1.exe This will launch the modem router installer and show the "Welcome" screen. Click the Start Installation button to continue. If you wish to cancel, click the Cancel Installation button. Read the next page carefully. The text advises to close any running programs, ensure to close your AOL software also. Click Next to continue. Please Note: Connect a DSL filter to each telephone socket that is in use for telephones, dial-up modems and fax machines, etc. If you require additional DSL filters, order online at AOL Keyword Broadband Extras. Notes: Ensure to use AOL 8.0 or above. The AOL account to be used for the modem router set up must be a General (18+) account. This installer is not supported with a modem router containing beta firmware.
Apr 24, 2007 | RCA Thomson Digital Cable Modem (DCM305R)
Computers & Internet Logo
113 people viewed this question
David Payne
David Payne
