Question about Garmin Forerunner 405 Handheld GPS Receiver
Forerunner 405 does not transfer data to computer successfully
Everything says data is transferring and watch says data transfer was successful but computer states data transfer was unsuccessful right at the end of the data transfer. No data is transferred to the computer and no error messages appear.
  • 1 more comment
  • Anonymous Feb 18, 2009
    I have the same problem. Device appears to transfer data successfully to computer, but every time the computer tries to send it to Garmin Connect it says "transfer failed". The tech support people at Garmin couldn't help and transferred me to the software department but I didn't have time to hold another 30+ minutes to wait for help.
  • thedaniels5 Mar 25, 2009
    I'm getting a "transfer failed" message after data supposedly successfully transfered from watch to ANT. I even did a software update to latest version and this didn't help. Someone please help!
  • eapringle Apr 11, 2009
    I have the same problem. Data seems to transfer successfully but at the very end of the process, I get the message "data transfer failed". I was able to transfer new firmware but still the same problem with my data. Please help! What good is this device if I can't look at the data it tracks??
4 Suggested Answers
SOURCE: computer has a problem communicating with my forerunner 205
I just got off the phone with garmin tech. She helped me solve the problem. Here are the steps.
1. Go to http://www8.garmin.com/support/collection.jsp?product=010-00466-00
2. Download "Forerunner 205 Ver. 2.80 as of Nov 12, 2007", unzip it, and browse to the folder you unzip the files to.
3. Make sure your Forerunner is connected to your computer and turn it on. Drag file "048401000280.rgn" and drop it on "Updater.exe". A screen will pop up, select "USB" then click OK. Then wait till the process completes.
4. Go to the website on Step 1 and download "Training Center For Windows Ver. 3.3.4 as of Feb 29, 2008". Install it.
5. Run Training Center. At this point, I am able to send/receive data to my Forerunner.
Hope this helps!
Posted on Apr 02, 2008
SOURCE: GARMIN 305 Forerunner wont transfer data to PC
For Pc users:
Go to Garmin website Updates & Downloads, Training Centre for Windows software version 3.4.1, click on download.
I previously deleted all saved couses on Training Centre, but don't know if this is relevant.
Posted on Jun 02, 2008
  • 3 Answers
SOURCE: I can't update the firmware on my forerunner 405
There are two steps for the firmware update - two bad Garmin doesn't warn people upfront.
The first update is preparing for the ANT stick - it takes about two minutes.
The second step is the core of the firmware(software per Garmin) update which takes about 10 to 15 minutes depending on how busy the Garmin Connect site is.
Since you already got through and got the "unsuccessful" message, I assume you already know how to start the update properly.
To finish it - Make sure you do not interrupt the process, just let it run through the 2 steps mentioned above.  And be patient - the 2nd step follows the 1st step automatically.  Don't touch the bezel and change screen during the update, just leave it alone.  It took me a few times to get it done successfully because after the 1st step finished, I started to flipping screens to find out if it get updated to ver 2.50, before I found out there would be step 2 coming automatically.
If you see the process bar moving after the 2nd step and see "software loading" you are in for good.
Hope this may help.
Posted on Jun 30, 2009
Garmin 405 won't transfer courses
Try running the Garmin WebUpdater program to load or reload the latest software. This will usually fix any bugs or issues.
You may also want to contact Garmin Tech Support for assistance.
1-800-800-1020
Mar 26, 2012 | Garmin Forerunner 405 010-00658-20
When i plug in my usb stick to my laptop and place the watch near same it will transfer the data but how do i read that data (which is now on the usb stick) on my computer? Have the product registered...
It depends on what type of data that is, there are files that can be read by a certain program such as .pdf file it can be read by adobe acrobat.
what is the file type you will need to find that out first to be able to determine what program to use to be able to read the file.
to find out the file type you can right click on the file then select properties check what is the file type then, you can google and search for a program that opens the file from your watch.
also if you watch has a disc that came with it possible that it may have a program that can help you read the file from it.
you menyioned it is in a USB stick try putting the file on your desktop see if it can be read by adobe reader, or right click on the file and select "open with" this will give you the option to select a program to read the file, try using notepad see if it will open in notepad most files will open in notepad if not then try opening the file with adobe or word.
Aug 26, 2011 | Garmin Forerunner 405 Handheld GPS...
I was trying to transfer data from the RC-50 to my computer and pulled out the USB cable by mistake from the computer and now the RC-50 says Data Damaged. I think I may have put the file in the trash in...
Usually in any type of situation when data is being transferred and the connection is prematurely lost there is data lost and or file corruption.
My suggestion:
Connect the Boss Rc 50 to your computer and backup its entire contents to your computer if possible.
Next perform a Hard Reset: While simultaneously holding down the "PLAY MODE" and "LOOP SYNC" buttons, turn the power on. Everything should be restored to factory settings.
If your backup was successful, then you can transfer desired files (one at time) to determine if the are usable. If a file causes errors or malfunction, then most likely it is corrupt.
Hope this helps
Apr 05, 2011 | Boss Rc 50
I receive the following error message, when I power on my Copystar CS 300ci: Machine Failure C1950 Any suggestions
Transfer belt unit EEPROM error No response is issued from the device in reading/writing for 5 ms or more and this problem is repeated five times successively. Mismatch of reading data from two locations occurs eight times successively.
Mismatch between writing data and reading data occurs eight times successively
1. Poor contact in the connector terminals.
- Check the connection of connector YC28 on the engine PWB and the connector of the transfer belt unit, and the continuity across the connector terminals. Repair or replace if necessary.
2. Defective transfer belt speed PWB (inner transfer belt unit).
- Replace the transfer belt unit.
I hope this is helpful,
Shawn
Mar 14, 2011 | Kyocera Copystar CS2540 Copier
I can not get my 405 to do anything when i plug into usb port
To connect the Forerunner to a computer, it is essential that you download "antagent" (free ) from the garmin site.
Have you done this?
You then have to pair the Forerunner with the computer.
If you haven't got the instructions, go to the Garmin web site (www8.garmin.com/support/userManual.jsp) and download the manual.
Jan 17, 2010 | Garmin Forerunner 405 Watch
Updated firm ware on 405
Make sure you have the latest ANT version.
Remove the pending firmwire program that wants to be transfered to the forerunner. (right-click + select delete)
Reset the watch (hold both buttons for 6 seconds, lift upper button, hold lower botton for another 3 seconds)
Then start all over again.
This fixed the problem for me.
Jun 25, 2009 | Garmin Forerunner 405 Handheld GPS...
I can't update the firmware on my forerunner 405 . The watch gives a transfer unsuccesful message, have tried repeatedly.
Hope this may help.
Jun 07, 2009 | Garmin Forerunner 405 Handheld GPS...
Garmin Forerunner 305. Problem receiving activities and courses
This turned out to be corrupt data on my machine. I opened the Garmin traing center, backed up all the courses then deleted them inside the Training centre. I then received from device and all was okay.
Jan 12, 2009 | Garmin Forerunner 305 GPS Receiver
MY Garmin 405 wont download data. It make the connection and gets to the tarnsfer point then "transfer failed. I've one route downloaded last week but none since. I tried: resetting both...
I got the same issue and it was because of a software update to ANT+ agent being not compatible with the 405.
here is what I got from Garmin Support.
This solved my problem:
There is currently an issue that has been identified with the latest
version of the ANT agent where it will not transfer data to the computer
from a 405cx. To resolve this please follow these steps
1. If the device has paired it will need to be removed. Right Click on
the ANT agent, select Device Settings then click Remove Device.
2. Right Click the ANT agent and select Exit to close the ANT agent
3. Go to the Control Panel, select Add / Remove Programs and uninstall
the ANT agent.
4. Reboot the computer
5. Download the previous version of the ANT agent from http://www8.garmin.com/software/GarminANTAgent_221.exe
Run this file once it has downloaded
7. Turn on the pairing on the watch ? to do this go to Menu > Settings
> ANT+ > Computer > Pairing (on).
8. Enable pairing on the computer - right click on the ANT agent icon
and select Pair With New Devices > Enabled (this may already be enabled)
The Forerunner and computer should now pair, please be aware that it can
take several minutes for the computer to find the watch.
May 14, 2008 | GPS
Garmin Forerunner 405 Handheld GPS Receiver Logo
1,478 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
