Question about Toshiba Satellite A135-S4427 Notebook
Me sp 6050 has got bad bio
Iv tried changing ram an harddrive an reloading windows but it dont seem to work how can i get it working please help cause i need it for me work
  • Thomas F. Schneider May 11, 2010
    BIOS clips are a seperate item and usually available as a separate part from the manufactor or
    I have see a website that sells only BIOS chips also.
    When you reloaded the windows , it went through the whole process?
    You cannot get to the BIOS screen?
  • LaptopsPlus May 11, 2010
    What doesnt work?
    Champion:
  • 203 Answers
Chek to see if the ram and harddrive is compatibile for your laptop, check the speed of your hard disk
Posted on Jan 16, 2009
Cant flash bios a1410n
Try simple first. When booting, AND BEFORE the XP logo, press f8 repeatedly until you see the boot options menu. If you miss it, you will see the xp loading logo, if so, restart and try again. From the boot menu, try the "boot with last known good configuration" option. If that doesn't fix it, re-boot, f8, and try the "safe mode" option. If it boots with any of these methods, do a full shut down and re-start again normally.
If that doesn't get it to boot normally, I would do the following. (I would, but you should only try this if you have a good understanding of windows and needed programs installing, ram replacement, hard drive repair/replacement and internal computer wiring)
Now, if your computer worked fine, then suddenly started this loop, I dont think it a bios problem. I expect you might have a hardware problem. Did you change any hardware very recently? Sometimes that stops windows from loading. Or, you could try changing the ram and retry, could be bad ram. But I think it is a hard drive issue. I think you will have to reload windows and/or replace the hard drive.
To safeguard your info, you should replace the main hard drive with another drive, load windows fully on it, then add the original drive back in as a slave/secondary drive, and retreive your personal info and files from it. Your needed programs will have to be re-installed on the newer windows drive. When you get all your files copied over (use copy and paste, not cut and paste), you can format the old drive and use it as storage, or just format and keep for the next time, or sell it. I would also run a "drive fitness program" to test it for bad sectors.
Or, if you dont need anything from your windows, you could format and install from the xp install cd. If it loads and runs, the drive is probably ok (I would still test it for bad sectors), or, if it cant load because of errors, the drive is probably bad. Retry with a new drive.
Jul 16, 2013 | HP Pavilion a1410n (ER890AA) PC Desktop
My Dell Latitude has Video issues please help
what kind of computer do you have ?
first try opening the case and re-sit the graphics card and then boot
Jan 22, 2013 | Dell Latitude D620 Notebook
I have this xact same problem,long beep then stops then long beep agen. iv tested multiple different RAM cards but my MB doesnt seem to read any of them. wat could be the cors of this?
as i always say:
intercept all of cables of your PC case and even power cable of your monitor.
evolve battery of bios then wait for 25 minutes then connect all of cables and try turning on your PC:
1- with battery of bios
2- without battery of bios
it should work.
(this works cause the motherboard reset it's bios and start correctly again).
Jan 13, 2011 | Gigabyte GA-8VM533 Motherboard
My self built computer is down. The CD drive and DVD drive wont take a reload of XP.I keep getting error messages that dont make any sense, they change everytime. I feel that the P4S8X motherboard is where...
You are on the right track... although one other thing you may try is replacing the RAM.... Bad RAM can cause random weird errors such as your describing.
Oct 30, 2010 | ASUS P4S8X Motherboard
Ok i have a Northgate Computer that has a Ram Issue i can't afford more ram. But i have a newer computer that is better then this one im on. And i need to switch the BIOS on the newer one from Sata to IDE....
i think you have the worng idea but ill try to explain it IDE and SATA are connections mainly used for harddrives and disc drives but if you want to use a IDE harddrive then its just as simple as plug and play you just plug it in to the motherboard plug a power connector in and switch on the machine as soon as it gets to bios the motherboard automaticly changes the IDE to the main drive and the SATA becomes 2nd. hope this helps
Sep 24, 2009 | ASUS P5RD1-VM Motherboard
My acer 5100 laptop keeps shutting down. Will not start windows at all.
Its behaving as if it has a virus try this format the harddisk program might be corrupted can't start .
Secondly do check the RAM if is seated well on there slots (swap the rams )
good luck
Sep 08, 2009 | Acer Aspire 5100 Notebook
Intel® Desktop Board D915GUX
Yes it seems ur RAM are faulty..try to change it...
Dec 11, 2008 | Computers & Internet
How to install XP over Vista (BIOS can't disable SATA native mode)
make new xp with nlite software and inbuilt achi and ICH9 driver. then try to install xp.
Nov 05, 2008 | Intel Gigabyte GA-8IDX 845 AGPset P4...
Sata harddrive
You need to enter the BIOS and check to see if the sata drives are enable cause if there aren't then you'll always get that response and seems as tho you waste your money.
Also you must have the sata drive on primary.
Get baC @ ME!
KJ
Apr 22, 2008 | ASUS P5LD2-VM Motherboard
BIOS not starting
my problem is this my motherboard recently started to not open the computer at all so i take the rams out and put it back in and it works after two days from shutting down dead silent this process happes almost on weekly basis now one day it just doesn't want to open and i have to leave it for a couple of days and remove the rams and put it back in then it works and two days later stops and so on u get my point ..
one more thing started to happen the dvdrom and cd rom connected to the MB stops working also and i don't no what to do should i change to msi 945 or anyone recommend another type of motherboards or is this fixable? thanks
replay to me on buzzz_forever@yahoo.com much appreciated
Aug 16, 2006 | Intel SuperMicro SUPER Motherboard - 810...
Toshiba Satellite A135-S4427 Notebook Logo
91 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
