Question about Dryers
I have a CTD85 dryer which is showing F-10. I have just tried to take off the back panel but I didn;t see anything that matches the desciption on here! any ideas??
  • abzjones Jan 14, 2009
    People Have saidn on here that with the CTD85 model you can take off the back panel and there are 3 thermostats, and when you put a pin in the brown on it clicks and this sorts out this problem. When I took the back panel off mine, I saw the heating elements but did't see a brown thing or anywhere to put a pin!
  • Bill Dickerson
    Bill Dickerson May 11, 2010
    Get your manual out and see what it says. Call the mfr. and get help from a tech support. I am not familiar with these codes. What is the dryer not doing?
  • 979 Answers
I am not familiar with this either. You may can go to google search and type in model and the code and someone else may have had a similar problem and a solution as well.
Posted on Jan 15, 2009
Heating element will not heat , the element is ok
GOD IS STILL GOOD !!!!
ELECTRIC Dryer no heat or little heat, or shuts down to fast:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective or has a short if its grounding out? Which in turns causes blown fuses or thermostats or overheating.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.html
Sep 09, 2014 | Hotpoint Belt for CTD00P, CTD40, CTD80,...
No power to myctd80 dryer
if i remember rite ctd40 has three stats over heater 1 has pin hole in top push needle in hole to reset it and take needle out then try ive done this on sum
Apr 01, 2013 | Hotpoint Belt for CTD00P, CTD40, CTD80,...
Timer counts down too quickly
Possible there is fault in the timer unit . check for loose connections or loose joints to the unit, if not this needs a replacement.
Jan 12, 2013 | Hotpoint Belt for CTD00P, CTD40, CTD80,...
Faulty control board hotpoint ctd85
You can remove the panel and check for fault in the connectors and the line to the display, use a hair dryer to warm and dispel any moisture on the board and panel. If there is no result then the panel has to be replaced.
To remove click : control panel
Jul 26, 2012 | Hotpoint Belt for CTD00P, CTD40, CTD80,...
MY CTD85 CONDENCER DRYER IS MAKING A NOISE WHEN DRYING LIKE A SCRAPING NOISE DO YOU THINK THE BEARINGS HAVE GONE?
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Nov 14, 2010 | Dryers
How do you take the back off a Hotpoint Ctd85 tumble dryer . I have taken all the screws out and the top of the machine and the two bottom corners are still holding the back on tight. I cant see anything...
most dryers you cant remove the back, you remove the front face then the top, then drum and this is how you get into the rear dryer area
Oct 31, 2009 | Dryers
CTD85A dryer showing F-10
You have to remove 2 screws that secure the heater element to the rear cover, there you will find the thermostats located.
Be careful not to damage the element as it is very fragile, and is easily broken.
Plz rate my solution.
Thanks
Jan 14, 2009 | Dryers
Can't take the back of hotpoint CTD85
my son worked it out, we had taken it off properly but didn't know what we were looking for.
All sorted
Dec 14, 2008 | Dryers
Dryers Logo
62 people viewed this question
Top Dryers Experts
