Hooks to pc ok. click pc grouping to open Cell phone/ gets (internal memory) only I don't find the folder DCIM
According to FAQ it states : "Navigate to the Photo location, inside the my_pix (or my_flix)
folder, using Windows Explore"
So it could be My_Pix or My_Flix. Run a search for them and see what pop up.
Ref: http://www.samsung.com/us/support/owners/product/SCH-U370XKZVZW
SOURCE: Need to transfer photos from Samsung Sync phone to PC with Windows Professional
check Bit Pim at www.bitpim.org, I have the same cell phone but I don't have the usb cable.
Good luck.
SOURCE: unable to transfer photos from cell phone to pc
If you're using Windows xp you will need to use MS ActiveSync or Samsung's own software. If you're using Vista you need to use WMDC
SOURCE: Transferring photos from phone to PC
right you need to get the Samsung software and a Cable, then you install the drivers and software onto the PC and reboot, then plug in and turn on phone, Windows will detect and install it. Now you open up the Samsung Phone software and do whatever you want from there. Also after you have done this the Phone will "Show Up" as a "Drive" in My Computer, as such you can also Cut, Copy & Paste, whatever, wherever, on your PC.
SOURCE: how can i transfer photos from my cell to my pc
Below is a detailed solution to your problem;
STEP 1.
Most mobile phones nowadays come standard with a USB data transfer
cable and bundled software utility. Check the box that your mobile
phone came with for the cable and CD-Rom. If not provided with the
software, it may be available as a free download from the manufacturer’s
website.
STEP 2.
Once you have located your software CD, check the system
requirements necessary to run the software such as hardware
specifications, operating systems supported etc. Install the software
following on-screen instructions, but do not plug in the USB data cable
or phone in just yet, unless the software requests you to do so during
the installation process.
STEP 3.
Once the installation is complete, the software would usually
require a reboot of the PC before plugging in the mobile phone for the
first time. Then connect your mobile phone to the data, and the cable to
the USB port of your PC. Several phones may display a message on the
mobile display that the phone is now connected to the PC, but if not
don’t worry just yet!
STEP 4.
Once connected, start up your mobile phone’s software, and browse
through the interface. Most manufacturers offer some form of phone
browser where you can browse through the content on your phone, copying
files onto, or taking files off the mobile. The software utility may
also offer a separate tool for transferring photos and video shot with
your mobile, if this is the case use the utility!
STEP 5
.Use the software’s browser or photo utility to
transfer your photographs to your PC. Some software tools provide image
editing tools as well that will enable cropping, rotation, and
sharpening of images once transferred to you PC. Don’t be afraid of
referring to the software’s help file incase you get stuck.
The above guide will be of great help to you,as a note of warning;Remember
never to unplug or disconnect the data cable from the phone during a
data transfer or you could end up damaging your phone or loosing all
your data.
Thanks and take care
SOURCE: I have a samsung s3500 phone but am unable to
Please get it at www.software112.com/products/samsung-pc-studio.html
