TOSHIBA A300D 13C LOGGING OFF ISSUES
When I close down my toshiba laptop it says it is shutting down but just sits there and neve actually closes down. I have to keep my finger on the standby/off button to close it down/
The laptop is only 4 months old and the problem has only been occuring over the last 2weeks
  • 1 more comment
  • andrewward19 Jan 18, 2009
    Hello, thanks for getting back to me so soon
    I have tryed to change the system standby mode no success there
    I have run my antivirus software
    This issue has only been occuring the last couple of weeks
    I will try to restore the computer windows, how do i do that please?
    Thanks Andrew
  • andrewward19 Jan 19, 2009
    I have restored my computer window to an earlier date which has restored the issue
    Thanks for the help with this
    Andrew
  • Thomas F. Schneider May 11, 2010
    And it closed down in the past,correct?
    Step one ; update and run you antivirus software.
    If that does not fix the problem;
    Step two: Try to "restore" the computer Windows " to an earlier date.
    If that doesn't work,
    Step three Reinstal everything using you backup CD
    http://www.csd.toshiba.com/cgi-bin/tais/...
    Genius:
  • 1,102 Answers
Have you fixed this problem
if not go to control panel display
then screen saver then power or power options
make sure you have all the settings correct then press apply
you can put it on never for system standby
let me know how things are going
Posted on Jan 14, 2009
  • DEKR
    DEKR Jan 19, 2009
    anytime
  • DEKR
    DEKR Jan 19, 2009
    maybe go back to the steps I explained find hibernate and remove check from box
    set stanby to never
    set when you close lid to turn of
    IF ALL THIS FAILS and you have recovery or win cd
    put in the drive restart pc as its restarting constantly pressing F7 options will open highlight option to boot from cd or cd/dvd then enter your pc should then boot your with cd
    a black screen will appear asking boot from cd then press enter
    follow the instructions when asks for install instructions click to delete the selected partition then it will ask to confirm after confirmation a new partition will appear press enter
    when asked which formatting do a quick
    then your windows will install
    if you do not have cd let me know
How to reboot toshiba a300d 16c
you reboot by simple shutting down and restarting your computer
Dec 29, 2013 | Computers & Internet
Toshiba satellite L750-iq6 won't shut down or sleep?!?
That is a software issue with the OS. Was it always like this? If not, try a system restore to some time in the past when you know the unit was working fine.
Sep 06, 2017 | Toshiba Satellite L750 Notebook
Toshiba Laptop L650-12Q will not shut down
Windows needs to be shut down properly to keep it stable, if hibernate mode is being used it eventually corrupt windows causing all kinds of symptoms, I recommend you make a backup recovery disc, and disable the hibernate feature to prevent complete window failure.
May 07, 2012 | Toshiba Computers & Internet
Hi guys I have a Toshiba Laptop Model TE2300 on shut down a screen comes up saying END PROGRAM- SAMPLE this stops you shutting down what is the problem and can it be fixed thankyou Kind Regards Mark
the end programs means that some program is running while you are shutting down you have close all the program before shutting down you can just click end program or wit for the process to end by itself to know which program is running while you close press CTRL+ALT+DEl click the file you will see the program which are running go to shut down and click shut down its shut downs and the end program stops coming
Nov 14, 2010 | Toshiba Tecra TE2300 Notebook
Toshiba Equium A300D - 13X laptop black screen.
Hi. try accessing the Start-up BIOS features by pressing F2 or Delete key when you see the Toshiba logo. Check for the Tab that will give you the control for the brightness/contrast of the screen. If that doesn't do anything then most probably the backlight (LED or CFL) must have been busted. and needs replacement.
^_^
May 06, 2010 | Computers & Internet
My Equium A200-1V0 fan stopped working
Hi, just thought I'd let you know that when I got my Toshiba Equium 200-1V0 it was supplied with the User's Manual A210 Series. The manual is just basic and does not go into full depth of how to clean out heat sink etc. The problem you described regarding the shutting down is most probably that the heat sink is clogged up with dust and needs to be cleaned. Toshiba has a lot of laptops (different models) with this problem. I had the same problem with Toshiba A200-1V0 and have now got the same problem with the Toshiba A300D-20R which is only 6 months old! On the A200-1V0 I managed to hoover the bottom of the laptop where the fan is and it worked fine, but with the A300D-20R it has not worked, but fortunately it's still under guarantee so I will be sending it back to Toshiba to do it. Here is a link to download the Manuals. You will find the Manual for A200-1V0. Hope this helps. http://uk.computers.toshiba-europe.com/innovation/download_manuals.jsp?service=UK
Mar 17, 2010 | Toshiba Satellite A100-S8111TD Notebook
Toshiba A135 random shut downs
chect the operating system maybe some files or configuration change.. try to re install the operating system,, save first you data or make back up.. in another drive.
Jul 06, 2009 | Toshiba Satellite A135 Notebook
TOSHIBA SATELLITE LAPTOP a300d-14O TURNS ITSELF ON AGAIN AFTER SHUT DOWN WHEN LID IS CLOSED
Your power management in Windows is corrupted. I would do a system restore to an earlier date.
1.
Click Start, point to All Programs, point to Accessories, point to System Tools, and then click System Restore.
2.
On the Welcome screen, click Restore my computer to an earlier time, and then click Next.
3.
On the Select a Restore Point page, select the date from the calendar that shows the point you'd like to restore to, as shown in Figure 2, and then click Next.
Figure 2
4.
On the Confirm Restore Point Selection page, verify that the correct restore point is chosen, and then close any open programs.
5.
Click Next if you are ready to proceed or click Back to change the restore point.
6.
The computer will shut down automatically and reboot. On reboot, you'll see the Restoration Complete page, and then click OK.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 19, 2008 | Computers & Internet
Computers & Internet Logo
109 people viewed this question
David Payne
David Payne
