Question about Kenwood KDC-C667 6-Disc CD Changer
Cd cassete stuck in unit
The cd does not come out when you push the button. Is there another way to get it out?
Make sure the disc tray is fully retracted, then some disassembly is required... if you made is this far, there is a metal tab/lever under the top circuit board, at the back of the unit, slide it over gently and the disc shuttle will eject.
Posted on Aug 10, 2007
2 Suggested Answers
SOURCE:
SOURCE: Ford CD Mulichanger cassete stuck in multichanger
There should be a pin-hole on the front of the cassette, just like on a PC cd drive. Push a paperclip into the hole to release the cassette manually.
Posted on Sep 08, 2009
Cd stuck in sterio aparently there is a reset button to push and release cd.were is the button?
I'm not aware of any button on car cd units. Usually when a cd is stuck in the unit, you need to take another cd, open the door and gently lift or pry up the stuck cd to release it.
Dec 04, 2016 | Car Audio & Video
How do you remove a cassete tape out of a1999 toyota corrola tape player?
take the unit out and remove cover try and manually release mechanism
if not its toast
Oct 17, 2014 | 1999 Toyota Corolla
Loaded a cd to upgrade firmware, firmware would not load. eject button would not eject. read manual, says to push eject at the same time you plug in the electric cord,still would not eject. Any...
Please try in this way.
Disconnect power.
Connect power back, and keep REPEATEDLY pressing the eject button while you connect. If still no ject press power on button while you keep hitting the ehect button. You need to press eject on the unit, do not use the remote.
If that does not work, then the unit must be taken apart.
Dec 09, 2010 | Cameras
Cd is stuck inside the player. I moved the unit when decorating and now the unit will not play any cds and there is one stuck inside. I removed the casing to look inside but got scared off when I saw all...
It is safe (except for the lead solder) as long as the unit is not powered ON.
There is a "pin hole" on the front of the CD tray.
With power OFF, use a stylus (straightened-out paperclip) to push the mechanical eject button inside the pin hole. Carefully use enough force to push the CD tray out.
Oct 13, 2009 | Audio Players & Recorders
Cd's stuck in cd player
take the disc cassete out and make sure all cds are strait,if cassete not coming out disconnect the unit take off couple scres on top,the lid will come of and then take out the cd cassete and chech if everthing strait and if theres no cd stuck half way in the player it self,if my info was at any help please comment ,thankyou
Aug 27, 2009 | 2004 Mazda 6
Cd stuck in cd changer
You could take the radio out and take it apart, but you would still have an $1800 CD. Suggest forgetting about the CD, and getting an aftermarket installed for much less.
Mar 07, 2009 | 2005 Suzuki Aerio SX
Feb 07, 2009 | Car Audio & Video
KOSS CDR200
can I record from an outside source, like a casset player to cd, on the cdr200, if so, how, thankyou
Nov 25, 2007 | Koss CDR200 2-Disc CD Recorder
Unit Keeps Powering Off...Will not stay on
The first thing you need to try is unpluging the unit from the wall totally then wait for about 5 minutes then plug it back in and try again,if you get the same results the cassete is probably stuck in the vcr and that is why the it unit shutsdown.It will continuo to do this until thye cassete is taken out without being force.The unit will need to be service by a professional.
Sep 26, 2006 | Philips MRV700VR DVD Recorder/VCR
Kenwood KDC-C667 6-Disc CD Changer Logo
392 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
