Question about Canon PowerShot SD300 / IXUS 40 Digital Camera
The camera zoom got jammed
The camera was working fine until yesterday. Then the zoom suddenly got jammed. It is jammed out of the camera, which means it can not come back to the normal position. Beside when I turn the camera on it can not start. After 3-4 seconds it switches off. Any idea what the reason might be?
    Novelist:
  • 107 Answers
This can be caused by several different situations. Most commonly the camera has experienced some kind of impact which knocks an element out of alignment, preventing the lens from rotating normally. Symptoms of this include: *you may hear no mechanical sound at all when the camera is turned on *you may see visibly mis-aligned components of the lens *you may hear a loud "snap snap" sound as the camera tries to move the lens when the camera is powered on The second most common cause is a particle of sand getting stuck in the focus motor drive gears. This prevents the focus element from moving normally and causes the camera to shut off to prevent damage to the lens assembly. Symptoms of this include: *A loud "buzzing" sound when the camera is turned on, followed by the beeping and shutdown. Finally the third most common cause of this problem is a broken tooth on the zoom motor drive gears. Symptoms of this include: *the sound of the running motor with a regular "click click click" sound for several seconds. This will not be a "snap snap" sound, that is a different problem. *the lens will move in and out easily by hand as if free from any resistance. All of these problems require disassembly to repair. The charge is around $125 at my shop. Broken drive gears are generally This can be caused by several different situations. Most commonly the camera has experienced some kind of impact which knocks an element out of alignment, preventing the lens from rotating normally. Symptoms of this include: *you may hear no mechanical sound at all when the camera is turned on *you may see visibly mis-aligned components of the lens *you may hear a loud "snap snap" sound as the camera tries to move the lens when the camera is powered on The second most common cause is a particle of sand getting stuck in the focus motor drive gears. This prevents the focus element from moving normally and causes the camera to shut off to prevent damage to the lens assembly. Symptoms of this include: *A loud "buzzing" sound when the camera is turned on, followed by the beeping and shutdown. Finally the third most common cause of this problem is a broken tooth on the zoom motor drive gears. Symptoms of this include: *the sound of the running motor with a regular "click click click" sound for several seconds. This will not be a "snap snap" sound, that is a different problem. *the lens will move in and out easily by hand as if free from any resistance. All of these problems require disassembly to repair. The charge is around $125 labor at my shop.
Posted on Jun 16, 2007
SOURCE:
My camera wont zoom
I had a similar problem on a Kodak Easyshare camera. The gear merchanism for the Zoom had jammed. I know it sounds drastic, but I fixed it by pushing in on the lens assembly until is snapped back in place. It could be a bad motor or bad motor driver circuit too.
Jan 14, 2012 | Sanyo VPC-T1060 Digital Camera
Showing zoom error.
I'm not sure if this will work as I have yet to try this for my self. But according to others who have had this problem pulling lens out while camera is off and then restarting camera works. If this does work please notify. Or just tell me what happens when this is done
Mar 28, 2009 | Fuji FinePix A350 Digital Camera
Zoom doesn't work anymore
camera lens is malfunctioning and needs repair
Jul 10, 2008 | Olympus FE-280 Digital Camera
None of the buttons work
You could see if any buttons are jammed and take the batteries out by moving them. See if one of them is jammed.
If that doesn't work, I would take into a shop and have them inspect it.
Jun 15, 2008 | Canon PowerShot A75 Digital Camera
Casio EX-Z700
I think, Charger is out of order and battery used all its charge, now charger is not functioning, so battery is not being charged. I mean no power from either side to camera.
Try to use another charger to charge battery.
Jun 01, 2008 | Casio Exilim Zoom EX-Z700 Digital Camera
Zoom error
worked on allot of fuji's. first detease, a gear is slipping in the lens retract assembly due to a crack or wear or jam
2nd guest .. zoom errors means its really stuck tight
the gears can be ordered and replaced and one more possibility is that the motor that drives the gear is bad
Also if dropped or zoom lens jammed hard... lens assembly needs total realignment or replacing..
May 23, 2008 | Fuji FinePix F460 Digital Camera
Olympus Camedia C-740 Ultra Zoom Digital Camera is not powering on
Battery contaxcts probably- clean the contact inside the chamber and the cover. In side use the eraser on the end of a pencil. Also when switch on -press in the cover - it is possibly a loose contact.
Jun 28, 2007 | Olympus Camedia C-740 Ultra Zoom Digital...
Blury Display on FE140
It sounds like your lens's focus element is stuck. Given the events you describe it is possible that a grain of sand has worked its way into the focus motor's gearing and jammed it up. Normally the small motor moves the focus optic in and out to achieve proper focus, if its movement is limited or completely jammed you will experience blurry pictures. The camera will have to be disassembled and the sand cleaned out to restore normal function. There are repair providers you can find online who can work on your camera. David Millier Advance Camera Repair
Mar 20, 2007 | Olympus FE-140 Digital Camera
Zoom problem
Ive seen this three times and everytime its been something differant. Fist was the rocker switch was jammed. easy fix as dirt was in there. Second was a small serface maounted capacitor in the zoom interface circuit. An third never found the problem as we thought it was a limit switch in the lens itself but the customer never paid for a new lens assy so we didnt order it. Good luck
Jun 21, 2006 | Canon XM1 Mini DV Digital Camcorder
Canon PowerShot SD300 / IXUS 40 Digital Camera Logo
205 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
sathish kumar
sathish kumar
Are you a Canon Camera Expert? Answer questions, earn points and help others
