Question about Microsoft Xbox 360 Console
How do isolve error 73 code 1021?
Lower right led comes on when av or hd/audio plug inserted
  • 2 more comments
  • mikeegee2004 Jan 14, 2009
    over 12 months old ,not sure if covered by warranty
  • mikeegee2004 Jan 15, 2009
    cocktail sticks to stop fans !!!!!!!!!!!!! it only bloody worked. thanks mumma_1
  • Anonymous Feb 23, 2009
    Very sceptical about this at first, but it actually worked!!!
    Thanks for your help.
  • skatingrulez Mar 25, 2009
    My xbox had the same error.
    i messed with it and broke the light off the outside.
    It works now but if i try to play a game it stops.
    It also never turns RED!!!!
I had install the game fifa o9 but it does not work its want the new registration code can you give the new code to activate the game ,please
Posted on Sep 05, 2009
  • 903 Answers
E73: General Hardware Error: Ethernet port... this error is caused by a problem with the Ethernet port
1021 (not yet known)
info from http://www.llamma.com/xbox360/repair/Xbox-360-error-codes.htm
I have read on some forums that this is caused when the motherboard is not seated correctly so the ports are not exactly where they should be. Some have opened up the console and resat the motherbaord.
However, I do not recommend this as your warranty will automatically be void if you attempt to repair it yourself. If you have still got any warranty left on your console you need to contact xbox support about getting your console repaired, they will not charge you. http://www.xbox.com/en-GB/support/ go here for contact details.
I hope this helps
Posted on Jan 14, 2009
  • 2 more comments
  • Debs
    Debs Jan 14, 2009
    I don't know if you want to try a do a fix yourself, I came across this video on youtube http://uk.youtube.com/watch?v=-jF-Sz49kw... which is quite interesting. You could try that if you want or check out some more of the vids on youtube on fixing the error.
    Or you can contact xbox support and seek some advise from them. If they cannot repair it because the warranty has expired they should still be able to guide you on fixing the problem.
  • Debs
    Debs Jan 14, 2009
    After much searching I was finally able to fix E73 on my Xbox 360.
    I cannot guarantee that this will work for everyone and personally it was a last resort for me but there don't seem to be many options to fix it.
    Remove the A/V cord from the back of the XBox 360. Stick two sticks into the fans to prevent them from spinning. This will cause the system to overheat within five minutes. You will know its done when the first and third quadrants light up red on the system (indicating the system has overheated). Unplug the system, plug it back in and turn it on to see if it was successful.
    this solution was put on by bscholar from fixya, he is actually suggesting the same as the video on youtube that I guided you to, so it might work.
    Let me know how you get on
  • Debs
    Debs Jan 15, 2009
    you are very welcome :) happy gaming!
  • Debs
    Debs Jan 15, 2009
    would you rate this as a fixya so that the rating is locked. Thanx :)
I have just brought a rx-v367 av reciever and have connected it to my tv/ speakers. speakers work fine when testing set up. however there is no sound coming out when connected to tv. also it keeps coming...
Hi, Yamaha audio-video receivers are equipped with a variety of connecting jacks for hooking up different types of electronic equipment. Component AV cables are typically used for hooking up the receiver to a cable TV box. Component cables can also be used to connect the Yamaha receiver to an HDTV, although a High Definition Media Interface (HDMI) cable offers a simpler connection if the receiver is equipped with HDMI (all HDTV sets are equipped with the distinctive, six-sided HDMI jack). The connections should take less than five minutes.
Instructions
Things You'll Need:
* 2 sets component AV cables
* HDMI cable
Check the back of the Yamaha receiver to determine if HDMI is available. The six-sided jack contains 19 holes set in three rows. If the receiver is equipped with an HDMI Out port, use an HDMI cable to connect to the TV by inserting the plug straight into the jack with the wider end turned upward.
Insert the red, green and blue plugs on a set of component AV cables into the Video Out jacks on the cable TV box, matching the plug colors to the jacks.
Connect the plugs on the other end to a set of Video In jacks on the back of the Yamaha receiver. Make a note of which jacks are used for the connection. Each set of jacks is labeled on the receiver.
Insert the audio plugs on the component cables into the Audio Out jacks on the cable box, using the white plug for the left channel and the red plug for the right.
Attach the plugs on the other end to the Audio In jacks on the Yamaha receiver.
Use a second set of component AV cables to connect from the AV Out jacks on the Yamaha to the AV In jacks on the HDTV only if an HDMI cable was not used.
Feb 18, 2011 | Yamaha RXV367 Receiver
When I tried to update the Realtek HD Audio drivers for my ASUS F5GL Notebook I got a message coming up saying "Install Realtek HD Audio driver failure !!" with the error code 0x00000103. Thanks...
Nov 28, 2010 | Computers & Internet
How do i connect an x box 360 to a HD ready tv please explain simply
Every xbox comes with the HD av cords. However they are not only the standard red, white, and yellow. But they also come with green, blue, and red av cords. These are the HD cords.Your HD tv should have green, blue, and red outlets on the back of the tv. It also has a another red and white outlet under it. So you have to take the HD cords and plug them into the appropriate outlets and then take the red and white cords from the other set of avs and plug them in right under those cords so you will have sound when you turn your xbox on. On my tv the red and white outlet is right under the HD outlet. But your tv may be different. And make sure that the "box" on the cord that reads either TV or HDTV is flicked toward HDTV.
Aug 27, 2010 | Microsoft Xbox 360 Console
E73 xbox
When turning on the Xbox 360, a red light would be flashing at the fouth section of the Ring of Light. You should then recieve a ghost screen indicating an error E 73.
You recieve a screen error E 73 and section 4 of the RoL flashing red. This type of error was caused by a General Hardware Error relating to the Ethernet Port not functioning correctly or became faulty and unable to operate even with or without an Ethernet Cable connected to this port. The secondary code would be identified as 1021 for faulty ethernet port. I believe that there is no fix at the moment. If you encounter this error, I would suggest call 1-800-4MY-XBOX or visit www.xbox.com/support
The specific type of hardware error can be determined by these hidden codes:
0001, 0002, 0003, 0010, 0011, 0012, 0013, 0020, 0021,0022, 0023, 0030, 0031, 0032, 0033, 0100, 0101, 0102, 0103, 0110, 0200, 0203, 1000,1001, 1002, 1003, 1010, 1011, 1012, 1013, 1020, 1021, 1022, 1023, 1030, 1031,1032, 1033, 1100, 1444 and up
More information about these codes and errors, visit this webpage:
http://forums.xbox-scene.com/index.php?showtopic=484726
  • Note: There is known to be a temporary fix for this problem but is not recommended if the device still has available warranty on it. Doing so will avoid it's warranty, thus for you will pay $100 if sent for repair.
The Sticks Method:
  • Requirements: Xbox 360 (Power Cable and Composite/Component/HDMI Cable), two sticks (Like toothpicks, swabs)
1.) Turn off your Xbox 360 and unplug everthing.
2.) Get two sticks (Something like toothpicks or something that could fit in the back of the Xbox 360.
3.) Insert each stick to jam the two fans at the back of the Xbox 360 to prevent it from spinning.
4.) Plug back cables (Power and Cable connecting to TV; the RRoD will not appear unless the cable to the TV is connected).
5.) When RRoD appears (One Red Light), wait for about 10 to 15 minutes or maybe less for the Xbox 360 to overheat.
6.) At this point, you should get two red lights (Resembles Overheating Error) so remove the two sticks so that the fans will spin in an increased speed. After a few seconds, the Xbox 360 will turn off to cool down (RRoD will still appear).
7.) Unplug only the cable connected to the TV. You can unplug the power cord if you want to. Then let it cool for about 30 minutes or so (Feel the Xbox 360 if it's cool or still warm)
8.) Replug all wires and turn your Xbox 360 on.
The Xbox 360 should now be able to boot to your Xbox Dashboard. I don't know how this fix works but it's only temporary. Note that doing this continually would cause it to now work even if you try to redo this fix again and again. Doing so would make other hardware components to fail permanently such as the GPU for example.
If this first temporary fix did not work, do the second method: The Towel Trick. You can find the tutorials in Youtube. Again, this is not recommended if you have warranty left and never do this continually. Your Xbox 360 would completely and permanently fail after that. if it doesnt help after all this....I suggest sending it to Microsoft for repairs
Apr 02, 2010 | Microsoft Xbox 360 Console
Which wires doi use to connect up my xbox with my
In order to connect your Laptop with Xbox 360, you will have to use the ethernet cable that came along with the Xbox 360,
For connecting the Xbox 360 to TV you would be having a HD AV cable if you have a Xbox 360 Pro model, you would have to insert one part of this cable with 3 colored wires red,blue and green to your composite video port behind your tv with similar color coding, and on the Xbox 360 HD AV cable you have an option to choose either TV or HD video output based on your TV make, also this cable has two more wires red and white meant for audio connectivity which would go to audio port behind TV with same color code ports
If you have got a normal AV cable with Xbox 360 then it would be a a wire with one single yellow colored wire for video and two wires Red and White for audio
Nov 23, 2009 | Microsoft Xbox 360 Console
I have the lower right quadrant flashing red error e 73
This is a AV problem. Try changing the position of the HDTV/TV switch on your AV cable.
Aug 11, 2009 | Microsoft Xbox 360 Console
E73 error or 1021 error code
here is what the error code means
E73: General Hardware Failure: Ethernet port... this error is caused by a problem with the Ethernet port.
and cose 1021 is a ghost code they have no idea from what i have found out
Nov 16, 2008 | Microsoft Xbox 360 Console
X box 360 error????
I cant get into xbox live my ip address works but xbox live doesnt
Sep 29, 2008 | Microsoft Xbox 360 Console
Philips 42pf7320a/37 dead
Error 7 is a power related problem. This is what u need to do.
Remove back cover.
Plug in power when tv goes into error protection, check power supply and see how many times the led flashes. Right below the flashing green led there is a list 1-13 of error codes and what they mean. Your problem will probably be an error 7or 8 VSET or VSCAN . Which ever error code it gives you VA VSET or VSCAN or whatever it indicates look at the cable connectors to the power supply unplug that connector and the TV will stay on. And there will be your problem.
May 06, 2008 | Philips 42PF7320 42 in. EDTV-Ready Plasma...
Microsoft Xbox 360 Console Logo
3,468 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
