Question about Baumatic B904SS Stainless Steel Electric Double Oven
Bottom oven not working
Top oven grill ok,bottom grill works ,orange temp light comes on,fan works but oven does not work.it tripped switch on main fuse box
  • 1 more comment
  • jdhke Jan 17, 2009
    thanks for help ,up and running again
  • Anonymous Mar 22, 2014
    oven will not heat up nor will the grill ,light not coming on . cooling fan working
  • Anonymous Mar 31, 2014
    2nd oven works ok
    President:
  • 1,214 Answers
A tripped breaker or blown fuse on an electric oven or cook-top, combined with an element that has stopped working, is usually a sign of a shorted, then blown (if the fuse or breaker no longer fail) element.
If you know how to use an ohmeter, you can pull the element, disconnect the wires from each end, then measure the resistance between each end of the element, and each element to the outer sheath.
A good element has just a few ohms of resistance between the wire connection points, and infinite resistance from the wire connection points to the outer sheath. Any readings other than that means the element is bad and need's to be replaced.
Posted on Jan 14, 2009
Neff U1422 bottom element faulty, is it needed?
the only problem might be hat the oven will not come up to proper temp with out that element .
Oct 16, 2015 | Neff Ovens
Switched bottom oven on, then noticed it had tripped fuse for cooker in main fuse box. Swithed it back on and it wouldn't heat up. The fan and light were ok! Top ove? grill works ok still.
sounds like you have a heating element burned out. Look real close at the heating elements and you may see a hole burned in the metal tube. This is a sure sign of a bad element. Some elements are easy to unplug. Others a real pain. Always unplug and or turnoff breaker prior to unscrewing anything. If you fine the bad element just unplug and other element may work OK. Best to get your model number and search net for new element.
May 30, 2011 | Ovens
Bottom oven not heating up
If it is a fan assisted electric oven and the fan is working o/k, and the temp indicator lamp is lit, then you need to replace the oven element, located at rear of oven compartment behind removeable cover.
Please rate my solution.
Thanks.
Nov 24, 2009 | Zanussi Ovens
Neff U1452 tripping electrics
Hi
sounds like you have a faulty new element. sometimes depending how long you supplier has had the element they get damp and when they get hot they go down to earth. if i was you i would take it back and get another one and try that. hope this helps you .
regards dan
Mar 19, 2009 | Neff U1452 Double circotherm plus Electric...
SMEG DO4SS-5 double oven not heating up
If the fan is running, then it is safe to say that the oven element has gone.
Replace with a new one,(element that is).,
Plz rate this solution.
Thanks.
Dec 15, 2008 | Smeg Ovens
Top oven (and Grill) have stopped workingMy 3 Year old AEG Competence D2100-4 Double oven has malfunctioned.  Bottom (main oven) works fine but top oven and grill have ceased to function.  The fan will run...
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Nov 12, 2008 | AEG D2100-4 Electric Double Oven
Baumatic B904SS Stainless Steel Electric Double Oven Logo
1,007 people viewed this question
Top Baumatic Ovens Experts
ashburton
Starnley Johnwells
Starnley Johnwells
Are you a Baumatic Oven Expert? Answer questions, earn points and help others
