Question about Sanyo DS25390 TV
Tv will not turn on
This is a 36" sanyo tv picture tube type. i checked fuse and it is fine any help at all will be greatly appreciated.
    Scholar:
  • 56 Answers
Greetings!
Depending on the model number, there are a number of things that could be wrong. Even within a given model number there are a number of possibilities. I have seen everything from rectifiers to horizontal outputs to bad electrolytic capacitors to bad solder connections kill these things. If you are skilled and experienced these are a few things to check. If you do not have repair experience then please stop, put the back on it and get it to a repair facility. I rarely have estimates declined on these because you can not replace it for less than most repairs will cost.
Rob
Posted on Jan 14, 2009
I have a Philips/Magnavox Smart Series CRT Tube TV. It has no picture at all (black screen-no menu-nothing) THE SOUND IS FINE. Set was working fine night before...:? Purchase in 1999. Is there something I...
Hello
If the picture tube must work properly, the LOT [Line Output Transformer] must be functional. In your set, now the line output transformer is not working. Check whether the 3 filaments in the neck of the picture tube are glowing. If it does, the LOT is working, because the filament voltage are dertived from one amoung the LOT windings. If it does not, the LOT said above is not woking. There are many reasons for this fault. If line output transistor has damaged LOT will not work. LOT is one which is a step-up transformer, ofcourse, which in turn supplies all the voltages needs to the picture tube. It has a long wire connected to the top of the picture tube body, with a clip and a rubber boot. You ahve to check all the voltages to that component, and the frequency of horizintal out put transistor. Just pull out the board, turn it upside down, and note carefully if there is any loose or bad solderings at the LOT side circuits. Resolder most of the soldering joints there, by applying a little more sodler, becuse the components of these side will heat up while working, and there is possibility to get the soldering points to get loose contacted. Check this first. If it does not help you, get it repaire by any experienced service technican. If you have some knolege in the fundementals about how a TV works, you yourself can do it at home. Wish you good luck. OK>
Jul 05, 2011 | Toshiba 36A43 36" TV
SanyoTV-blk screen w/thin line of light across screen great sound
Your Vertical Amp is probably Blown (bad) , but before you change that check all capacitors around the vertical amp IC and / or resolder resistors and diodes around vertical amplifier.
And NO it is NOT the Picture Tube
Good Luck
JG
Apr 18, 2009 | Sanyo DS27820 27" TV
SANYO MODEL#3659G TV 36"
Thomas,
How did you check the fuse? Just by looking at it or do you have a multimeter?
If you have a meter check the secondary diodes on the power supply and the horizontal output transistor. Perhaps one of them is shorted.
Feb 02, 2009 | Sanyo AVM-3659S 36" TV
No picture only sound, Toshiba 36A 36" TV tube type
my friend if you open the tv carefully look to see if the tube itself has light, or if you have high voltage i coulbe many different things.wish luck!!
caypianan@yahoo.com
Aug 10, 2008 | Toshiba 36A50 36" TV
No picture, sound ok
Rca has been known to have bad solder joints in the deflection circuits. Usually around the flyback and transformers.. check it over real good. Just be careful as you can still get shocked after the powers removed the capacitors and picture tube will hold a charge in them.
Jan 21, 2008 | RCA F36649 36" TV
Sanyo T.V.
take the back off the tv and where the power cord hooks into the tv check the fuse there on the board if this isnt blown then you are probably looking at a power supply problem look at the board for anything that looks black and burnt or dark brown spots on the board. this will tell you where the problem is if it has any. but it just might be the fuse.
Dec 22, 2007 | Sanyo DS31590 31" TV
Sony KV36XBR200
Picture tube is bad, time to retire this one!.....T.
Oct 22, 2007 | Televison & Video
Jvc model av36230
you know its in vertical section, try to look for a capacitor and changed it, this is more of a capacitor problem.
May 16, 2007 | JVC AV-36320 36" TV
Sanyo Flat Screen (DS27910) "Grey" Screen
dont know for sure but i think that the tube is going bad. Have one in my shop doing almost the same thing.Taped on the tube and it does strange things. My tube tester wont test this kind of tube that is in these sets.Not much help but it is a start.
Sep 17, 2006 | Sanyo DS27910 27" TV
Televison & Video Logo
51 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
