Question about Epson Perfection V200 Flatbed Scanner
Document feed Scanner Glass Scratched
Canon DR-1210C
Our auto document feeder scanner glass is scratched it's a thin rectangular piece of glass that the sheets glide across there is a scratch in it that is puting a line down the middle of the pages.
What is the best way of fixing this? The scanner is worth $500.00.
  • slane481 Jan 14, 2009
    Not really it would require taking the whole scanner apart.
  • Thomas F. Schneider May 11, 2010
    Is the glass not removable?
     Have a new piece of glass cut, and replace it.
    President:
  • 2,692 Answers
If the scratch is not to deep you can polish it out with lots of  elbow grease and cigarette ashes. Their are also products n the market to polish scratches out of glass. A really light rubbing compound like for 3M might work.
Posted on Jan 15, 2009
When I send a fax there is a thin black line from the top of the page to the bottom. Is there a way to make this line disappear?
Hi
if you scan documents through ADF (auto document feeder), open the scanner lid and check / clean the thin strip of glass on left of the main scanner panel. Use windex or similar window cleaner.
good luck
Nov 21, 2014 | Canon Pixma MX922
How to replace a broken scanner glass canon dr1210c
I don't know how the CANON DR 1210-C is assembled but I had an Artec and unscrewing it I could take off the glass.
Oct 12, 2014 | Canon DR-1210C Scanner
When I scan a document in the canon 9080c scanner - the document when printed will print with a black line through the middle of the page or on the left side of the document. I have changed the rollers and...
Try scanning a few documents in full size mode (scannerrs maximum), If you observe a line in the same location in all images, you can conclude that there is either a scratch in the glass (due to stapler pins) or dirt stuck firmly. Try cleaning with Isopropyl alcohol. For absolute emergency, you can wet a cotton bud in after shave and clean the right spot, take care not to touch any other part other than the glass. If glass is scratched, you need to replace it.
S. Mohan, Chennai, India
Sep 14, 2011 | Canon DR-9080C Path-Through Scanner
My canon 6080 leaves a thin black line on everypage scanned. is there a way to fix this?
Clean the glass thoroughly with a damp cloth. Dont use solvents. Check if the glass is scratched, if scratched you may need to replace it.
S. Mohan
Aug 26, 2010 | Canon DR-6080 Path-Through Scanner
What causes a line down the middle of copied pages
There is something on your scan glass. My guess is you are getting the line on your copies when you run the original through the document feeder. If you get lines through the document feeder but not on copies made off the glass then it is a dirty scan glass. There is a thin glass strip where the document feeder feeds the original. Usually something like white out that did not dry smears off an original and ends up on this thin strip of glass. Scratch it off with your finger nail and use some glass cleaner to resolve the problem. The scan glass is about 1/2 an inch to an inch wide and will be on the same side of the machine that the copier feeds the originals in on.
May 24, 2010 | Canon imageCLASS MF6530 Monochrome Laser...
When I make a photocopy I get a dark vertical line down the page. In fact, now I get two dark lines. It has something to do with the scanner, because it happens when I send someone a fax as well. ...
Do you use the automatic document feeder (ADF) when you photocopy and fax? Do you use the platen (lift the cover up) when you scan a document? If so, you probably have some dirt or foreign material in the ADF scanner area, which is a thin glass area to the left of the glass platen. Clean this area with a damp cloth and dry it before trying again. There is a plastic strip covering this area, and if this is scratched it can be removed and replaced.
Jan 19, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Panasonic UF-490 - Two streaks down page
Either the glass is scratched or the sensor has gone bad that is used to scan the image.  Are you using a document feeder or laying it flat on the glass?  If you are laying it flat on the glass then it is most likely a sensor going bad.  If you are feeding it through the document feeder it could be that the feeder itself needs to be cleaned, or the paper path through the feeder.
If it is the sensor you will need to send it out for repair.  There may be an option to re-calibrate the scanner in the software, that may help if the sensor has just degraded and not failed.
I hope that helps.
May 02, 2009 | Panasonic PanaFax UF-490 All-In-One Laser...
Black line on scanned document
Please clean the glass with Isopropyl alcohol. Dont use solvents.
S. Mohan
Mar 27, 2009 | Canon DR-1210C Scanner
Scanner inserts vertical line on some documents
Clean the glass with IsoPropyl Alcohol. Dont use any other solvent. A speck of dust stuck to the glass can give a continuous line in the output
S. Mohan
Sep 29, 2006 | Canon DR-1210C Scanner
Epson Perfection V200 Flatbed Scanner Logo
605 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
