Connection to internet
To make an Internet connection
1.Open Network Connections 2.Under Network Tasks, click Create a new connection, and then click Next. 3.Click Connect to the Internet, and then click Next. 4.Choose one of the following:
If you already have an account with an Internet service provider (ISP), click Set up my connection manually and then click Next.
If you have a CD from an ISP, click Use the CD I got from an ISP and then click Next.
If you do not have an Internet account, click Choose from a list of Internet service providers (ISPs) and then click Next.
5.From your choice above, click one of the following:
If you are connecting to your ISP using a standard 28.8 Kbps, 56 Kbps, or ISDN modem, click Connect using a dial-up modem, click Next, and follow the instructions in the wizard.
If your DSL or cable modem ISP connection requires a user name and password, click Connect using a broadband modem that requires a user name and password, click Next, and then follow the instructions in the wizard.
If your DSL or cable modem ISP connection is always on and does not require you to type a user name and password, click Connect using a broadband connection that is always on, click Next, and then click Finish.
Click Next, and then click Finish. Insert the CD provided by your ISP and follow the instructions.
•To create an Internet account using MSN Explorer, click Setup Internet access using MSN Explorer (U.S. only), and then click Finish. Follow the instructions in MSN Explorer. •To choose an ISP, click Select from a list of ISPs, click Next, and then click Refer me to more Internet service providers. In the Internet Connection Wizard, click Create a new Internet account, click Next, and then follow the instructions in the wizard.
connect the router to wan port to the modem and your computer to one of the LAN ports.
On your computer go to start > run > type cmd
In the command prompt type ipconfig /all
post the results.
Thanks.
