Question about NorStar T7316E Corded Phone
My phone won't ring, when a call is coming thru the light flashes
I have a Nortel T7316 Admin phone with 4 lines, and it will not ring, when a call is coming thru the light flashes on the display screen to indicate a call is coming in, and I keep missing them. How do I get my lines to ring again. Thanks!
  • 2 more comments
  • Julie Stinard Feb 18, 2009
    Three of our Norstar T7316E phones will not ring when someone calls. I can not find a solution to this in any of the manuals.
    My Nortel T7316E will not ring when someone calls. I can not find a way to fix this online or in the manuel.
  • NeiltheChef Feb 25, 2009
    I have the same problem, I found in the manual (on the CD) that you need to program a group for ringing service. It says to press the SHOW key which I do not have.
  • george  peters
    george peters May 11, 2010
    belinda,
    did this phone ring before? if not the extension might have to be programmed to ring
SOURCE: Remote Voicemail - How do you do it T7316
Call the phone system.
When you hear the voicemail greeting,
Press "* *" (thats 2 stars)
then just like sitting in front of the phone.
Posted on Nov 20, 2008
SOURCE: Template for T7316 Phones
Go here, http://support.nortel.com/go/main.jsp?cscat=SWDETAIL&SoftwareOID=147467, and download the Desktop Assistant. It will allow you to create custom labels for that particular phone and a few others in the 7000 series.
Posted on Jan 07, 2009
  • 10 Answers
SOURCE: Forwarding Calls to Outside # for Nortel T7316
You can set divert for the calls to another number. Do check for the call settings and activate the divert based on situation like.. When busy. Not reachable.
Posted on Aug 20, 2009
ynotphone
  • 192 Answers
SOURCE: We have Nortel T7316. I have been locked out of
How do I reset a password on a Norstar Voice Mail mailbox?
Press Feature 983.
Enter the System Coordinator's Mailbox number (default is 12, 102, 1002, depending on length of extension numbers) followed by Password (default 0000).
Press MBOX.
Press CHNG.
Enter the mailbox number that is giving you troubles.
Press RESET. The password has been reset to default (0000).
Good Luck.
Posted on Sep 04, 2009
  • 45 Answers
SOURCE: looking for a manual for a Nortel Telephone -
http://www.wedophones.com/NorstarManualsLead.htm
Hope this helps you.
Posted on Feb 23, 2010
Nortel t7316 admin console
You should be able to enter programming from any T7316 or M7310 or M7324 phone. Does this happen at the other phones which can be used for programming. If it does, try a power reset of your phone system.
Jan 13, 2014 | NorStar T7316E Corded Phone
I am using a Nortel T7208/T7316 sets (BCM 450 PBX) system, and I want to program a phone to ring when someone calls the main line. Most of our phones only ring when you type the extension internally. I...
The phone must be programmed with the target line assigned to the number you wish to have ring at that phone. This can be done with the BCM Element Manager interface. If your BCM450 is running version 6, I think this can even be done directly from the phone, but I'm not sure of that process.
Nov 09, 2012 | Nortel Business Series Terminal T7208 -...
I just wanted to ask how to shorten the number of rings before it goes to voicemail on a t7316 and t7208 phone. Thanks
You may need a tech if unsure of programming, passwords and navigation.
In Config or Admin under Sets/Capabilities you will see Forward No Answer, that needs to be pointed to the voice mail ext # (F985 to see what that is), then after that setting is the ring count....4 is recommended for average office staff.
Aug 06, 2012 | Nortel T7316E 2-Line Corded Phone
We have nortel t7316 phones in our office. one
Programming is done on M7310, M7324 and T7316 sets.
To set up ringing you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt,
press the show key (top right arrow).
The display should now ask for an extension number. Enter extension number you wish to program ringing on.
Press the show key (top right arrow)
The display should sat LINE ACCESS
Press the show key (top right arrow) .
The display should say LINE ASSIGNMENT.
The display ask for a line number. press list
The display should say line 001: appear & ring
press the Chng key till it says appear only
press next key (lower right arrow)
The display should say line 002: appear & ring
repeat the procedure the same as line 001 for the remaining ringing lines
press the release key when finished
Apr 16, 2010 | NorStar T7316E Corded Phone
Call forwarding
Your options are...
Option 1: Hit 7 then 2 then #. You'll hear an interrupted dial tone. Then dial the number you're forwarding to.
To cancel hit 7 then 3 then #.
Option 2: Hit * then 7 then 2. You'll hear an interrupted dial tone. Then dial the number you're forwarding to.
To cancel hit * then 7 then 2.
Jan 29, 2010 | Nortel Norstar 16-Line PBX Speakerphone
Aug 19, 2009 | Nortel Norstar 16-Line PBX Speakerphone
Nortel t316e phone only rings 2 times
You could have a CICS, and MICS or a Nortel BCM. Which do you have?
You will need to access admin programming, do you know how?
Jun 26, 2009 | Nortel T7316E 2-Line Corded Phone
Call forwarding on t7316 nortel system
turn on feature 84.... turn off feature # 84
Jun 16, 2009 | Nortel T7316E 2-Line Corded Phone
How to remove the old corporate greeting in T7316 Nortel?
Press Feature 983 enter admin password
press AA
press Grtg
press Grtg again
press 1 then ok.
Greeting 1 is usually for day and 2 is usually for night depending on the tech who set it up.
May 17, 2009 | Nortel T7316E 2-Line Corded Phone
Changing names on Extensions
Press "Feature **ADMIN", go to NAMES, Then go to Sets, and from their its just like texting
Aug 05, 2008 | Nortel Norstar 16-Line PBX Speakerphone
NorStar T7316E Corded Phone Logo
3,129 people viewed this question
Top NorStar Lands Phones Experts
Oloyede Monsuru
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
