Have you updated any software, drivers, any hardware changed? Have you reseated the monitor cables? Changed the resolution? When it's in safe mode the resolution is different, you can check it in Display Properties, by right clicking an open area on the disktop and selecting Screen Resolution, then boot to normal desktop, check screen resolution.
SOURCE: Black screen comes up "windows
You should opt Safe Mode:
If the boot is success full:
If no success then I think its time to re-install your windows.
Please post your feed-back.
Gud Luck
Iqbal
SOURCE: PC won't Start windows normally
You can attempt to undo this through the use of System Restore.
I am going to assume you are on Windows XP, So start your computer in safe mode without networking.
Once you are in the desktop you are going to use System Restore. Choose a date in time on your computer before the incident happened.
For more information on the system restore utility go here:
http://www.microsoft.com/windowsxp/using/helpandsupport/learnmore/systemrestore.mspx
Note : If you have Windows Vista ,read about this utility here:
http://windowshelp.microsoft.com/windows/en-US/help/9f6d755a-74bb-4a7d-a625-d762dd8e79e51033.mspx
SOURCE: windows will not start up
choose start windows in Safe mode, if it starts then everything will look big, don't worry about that for now. Then go to Start>accessories>system Tools>system restore and choose a date when you know that everything was working normally, when it has finished restoring the computer will restart. If asked choose start windows normally.
I hope this helps
SOURCE: Computer monitor stuck in safe mode
the problem is with ur Computer's Graphic card.
u can put a new one in case if it is a built in graphic card Chipset.
check ur manufacturer support page for more details.
plz rate this post as good as u can
SOURCE: Monitor keep going into "sleep" mode
try to reseat the memory modules and restart the computer and computer boots to normal mode/then go to power options in control panel and disable the sleep mode option for the hard disk
