Question about Whirlpool LGR7646E Dryer
Belt too loose
I have a 2yr old maytag gas dryer, I just replaced the idler pulley and now the belt seems really loose I can lift about 2 1/2" loop above the drum?
  • 5,911 Answers
Are you sure you have the belt routed correctly? You can verify by going to repairclinic.com and clicking on the "Repair Help" link at the top of the page. On the following page is a link entitled "Dryer Belt Diagrams" under the "Special Features" section. You will need to view diagram E for Maytag. NOTE: There is a tension spring on your idler. Make sure the tension spring has not come loose or fallen off. I hope this helps you. If you have questions, please let me know.
Posted on Jan 14, 2009
I have a Maytag gas dryer model #LDG8420 and the belt broke. I need a diagram on how the new belt goes back on.
Go to this website and view the pictures of your dryer belt routing
http://www.applianceaid.com/images/belt-config.JPG
If you hear a loud bang while your dryer is working, and you notice that the
drum has stopped turning, chances are the drivebelt has snapped.
Fortunately, replacing the belt is a fairly straightforward operation that
can be handled with a few simple tools.
First, unplug the dryer. Lift the lint-screen cover and pull out the lint screen
If your dryer has a lint screen on the inside of the door, skip this step.
Then remove the two screws that are under the cover. To unlatch the dryer top,
insert a thin-blade putty knife between the top and front panel,
about 2 1/2 in. in from one corner. Push in on the knife to release the locking
clip, lift the corner, then release the clip on the other side. Swing the top
up and lean it against the wall.
Next, move to the lower toe panel. Slip the putty knife between the lower panel
and the door panel at one side and twist the knife to release the clip
Then release the opposite clip and lift the panel up and off the hinge springs.
To support the dryer drum while the belt is being replaced, place scrap wood
under the front of the drum.
Loosen the two screws at each side of the bottom of the front panel.
Move to the top of the panel and remove the screws from the inside of the
cabinet that hold the front panel to the sides.
Slide the old belt off the drum.
Installing the belt
Lean the front panel out slightly and allow the drum to rest on the scrap wood
support. Drop the new dryer belt between the front panel and the drum, and
loop it over the drum. Then, lift the drum slightly while pushing the front
panel back into position.
Replace the screws at the top inside of the front panel, tighten the lower panel
screws and remove the scrap wood from under the drum. Check to make sure that
the rear drum seal fits properly over the lip on the rear bulkhead.
Position the new belt where the old belt was, with the grooved side of the belt
facing down.
Now, move to the motor area and pull out the old belt. To route the new belt
around the idler and drive pulley, first pass the entire belt, doubled up,
under the idler pulley. Then, push the idler belt toward the motor, slip the
belt around the motor pulley and release the tension on the idler pulley.
Open the dryer door and rotate the drum counterclockwise a few times to make
sure the belt is tracking properly. Lower the top and press down at each
corner to engage the clips. Lift the lint-screen cover, replace the two screws
and reinstall the lint screen. Finally, secure the lower front panel and turn
on the dryer for a test.
This is a FREE answer
Please RATE me
Dec 31, 2010 | Maytag Dryers
Dryer stopped spinning. Opened top and found thin broken belt. How do you reattach new belt to drum and pulley?
Installing the belt
facing down.
Please RATE me
Dec 27, 2010 | Maytag PYE2300AY Electric Dryer
Belt does not go back on with enough tension.
Are you replacing a broken belt? If so then the belt should go flat side of belt in toward drum. Make sure the belt is not in the slight channel in drum put belt from right under guide around idler then insert loop under idler and attach loop to motor. Should end with ribbed side of belt on pulley.
Nov 20, 2010 | Maytag Dryer Idler Pulley for Large...
How do you replace the belt on a Maytag clothes dryer
frist unplug dryer then take front panel off dry then take lint housing off there 4 screw on both side take that off remove broken belt put new belt on around dryer drum an loop belt over white idler pulley an around motor pulley idler pulley put tension on the belt
Apr 24, 2010 | Dryers
New Maytag dryer belt too loose
is the idler pulley have enough tension on it,the tensioner on these can get bad and not put enough tension on the belt,push on it,it should take some force to move it,if you can get your fingers under the belt around the drum without much effort then replace the idler pulley and tensioner
Jan 31, 2010 | Dryers
A constant clicking noise near the motor of my maytag dryer. seems something is slipping as occasionally the drum and belt slow down
It sounds as if the idler bearing has started to fail see this picture http://sites.google.com/site/sublimeappliancerepair/_/rsrc/1246721031553/washer-will-not-spin/agitator-woes/dryer-will-not-work/how-do-i-get-inside-my-dryer/gas-dryer-quits-heating/more-gas-dryer-enlightenment/gallery-of-dryer-parts-locations-and-diagrams/frigidaire-gibson-kelvanator-dryer-101/kenmore-whirlpool-englis-roper-dryer-notes/ge-dryer-repair/maytag-norge-amana-crosley-basic-repair-info/Norge%20dryer%20with%20drum%20removed.jpg
The idler pulley in the picture is behind the motor.
I would check the ilder pulley to see if it rotates freely and does not have any odd side to side movements. If it does then replace the idler pulley and belt.
Belt: http://www.appliancepartspros.com/part_details.aspx?part_id=4043963&rdr=%2fpartsearch%2fmodel.aspx%3fmodel_id%3d47809%26diagram_id%3d681078
NOTE: Before you remove the idler pulley and belt note carefully the installation position of the belt, idler arm, spring and the idler pulley. For a first timer trying to do this it can be quite frustrating to get them all positioned correctly.
Idler pulley:
http://www.appliancepartspros.com/part_details.aspx?part_id=4373393&rdr=%2fpartsearch%2fmodel.aspx%3fmodel_id%3d49146%26diagram_id%3d673577
I hope this has been useful information to you. Good day.
Jan 06, 2010 | Washing Machines
Drum not turning
pull the loop down at the bootm of the drum feed that loop through and under the pully wheel then catch the loop on the motor pully you can lift the idler pully slightly to get more slack
Oct 18, 2009 | Estate TGDS740JQ Gas Dryer
Install dyer belt MAYTAG
Hello there
Here is a detailed instruction for you ok
  1. Remove the two screws that hold the control console to the dryer; they are located on each end of the console. Turn the control console forward onto its face. Disconnect the wiring harness from the dryer to the console. Press in on the locking tab and pull the connectors apart. Set the control panel out of your work area. To remove the top, insert a putty knife between the front and top panels. Locate the retaining clip and push in on it to release the corner of the top panel. Lift up on the corner and release the opposite retaining clip. Set the top panel out of the way. Two screws that attach the front panel to the sides are located at the top corners. Remove the screws and swing the top of the front panel out so that you can access the door switch wiring harness. Disconnect the wiring harness from the door switch and lift the front panel away from the dryer.
  2. Replace the Belt
  3. Locate the idler pulley by reaching behind the drum and motor assembly. Using your hand, push the idler pulley to the left to release tension on the belt2.gif. Notice the routing of the belt around the motor and idler arm for reference when attaching the new belt. Remove the belt from the motor pulley. Lift up on the drum slightly and remove the belt from the drum.
    With the rib side pointed inward, lift the drum up and set the belt around the drum. Route the belt through the motor pulley and idler pulley. Pull the idler pulley to the right to reapply tension to the belt. ok?
  4. not too hard
  5. hope this is verry helpful for you
  6. Best regards MIke
Oct 15, 2009 | Maytag PYE4500AY Gas Dryer
Dryer belt broke on my dryer.
I use a putty knife to press against the spring clips to pop the top. Then I use a quarter inch nutdriver to remove the screws holding the front panel on. I remove the wires from the door switch and lift out the front panel. I remove the drum and put the dryer on a work bench or a tailgate. I inspect the blower wheel(most of the time they get loose). I get the ball of lint out of the front panel filter housing. I vacuum out the dryer with my shopvac. I oil the rollers and idler and inspect the drum slides for wear. I loop a new belt rib side down to the drum and set it back in the dryer. With my left hand I drop the belt under the motor pulley and raise up the idler looping the belt on it and let the tension hold the idler. I manually slowly turn the drum to make sure the belt is secure and not twisted. I place the front back on. Snap the top down and give her a try. Piece of cake.
Jan 11, 2009 | Maytag PYE3300 Dryer
Which wa does the belt on a Maytag Atlantis dryer run around the motor and idler pulley. I have the belt groove side down, which is the way it goes in the Atlantis, but I couldn't find a schematic for the...
Hi you're correct in putting it groove side down. Now make a loop, like when you first started tying your shoes with the slack around the drum. Push the entire loop just beneath the idler pulley through the metal channel and apply pressure to the idler pulley assembly. pushing it towards the motor pulley until you can get the loop you are holding over the motor pulley and Waa Laa you've installed your new belt. Good Luck!
Dec 10, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Dryers Logo
119 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
