McCulloch 26cc Gas Blower Mcb3208 Logo
A
Anonymous Posted on Dec 17, 2012
Gas mixture for McCulloch Super Airstream IV Gas Blower/vac #16 103848
DROPNDEAL
Level 3:
Top Expert:
  • McCulloch Master 2,931 Answers
  • Posted on Feb 21, 2018
DROPNDEAL
McCulloch Master
Level 3:
Top Expert:
Answers
2931
Questions
0
Helped
932495
Points
21770
Gas mixture ratios can be downloaded using the provided links:
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
User manuals
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
McCulloch Service
McCULLOCH PARTS ACCESSORIES
I trust this information has proven beneficial.
Gas mixture for McCulloch Super Airstream IV Gas B - helpful-rwwceix4simen0bu2pand4lt-2-0.png
3 Related Answers
Anonymous
  • 76 Answers
  • Posted on Jan 06, 2009
SOURCE: McCulloch 32cc blower, what is the fuel mixture, gas/oil
Do a 40:1 ratio to start, if it smokes cut it back alittle but 40:1 should be ok. Better to be alittle high on mix than not enough.
Anonymous
  • 437 Answers
  • Posted on Nov 02, 2009
SOURCE: What is the oil/gas mixture on a McCulloch Model
I would use 40:1 (3.2 oz of 2 cycle oil to 1 gallon of gas)
Good Day.
rycgl
Roy Cagle
  • 1545 Answers
  • Posted on Dec 10, 2010
SOURCE: My MCCulloch super airstream IV blower has only
Iam going to refer you to the Zama carburetor tune-up and adjusting guide for all this instruction.
http://www.zamacarb.com/tipspage.html
I need the flywheel for an Airstream I blower
Contact us
User manuals
McCulloch Service
Mar 13, 2014 • Garden
Fuel line is leaking gas on a McCulloch Super Airstream IV gas blower
Yes it may take some disassembly to get there, but yes.
Super airstream iv gasblower/vac mod.no.400048-04
Awesome! So what exactly do you need help with?
Contact us
User manuals
McCulloch Service
Super airstream iv gas blower/vac
Please refer to the resource links below:
Contact us
User manuals
McCulloch Service
Where can i get a carburetor for my mcculloch airstream 30cc backpack gas blower?
I recommend contacting your local authorized service center for assistance.
Contact us
User manuals
McCulloch Service
Craftsman leaf blower wont start
The air gap for the ignition coil core to flywheel is adjustable on some engines and the gap does vary.
On a Stihl, I used a matchbook cover first, then doubled it and got the engine to start. That amounts to 8-10/1000ths (0.008-0.010") as measured with a digital caliper after-the-fact.
I'm troubleshooting another engine currently from a McCulloch Airstream IV that only has ~12 hours and no spark but the coil measures roughly as it should; around 1K Ohms. Was surprised to find the company went bankrupt in '99. Another one killed by Asians and fairly poor design.
1helpful
How to adjust the carb on a McCulloch super
There is no set adjustment on any blower or chain saw. If it were that simple there would be no need for adjustments. The problem is that most equipment manufactured in the past 10 years can not be adjusted by the user. Carburetors are now equipped with either adjustment limiters which limit the adjustment to less than half a turn or with adjustment screws that require a special tool to make the
adjustment. More than likely you will have to take it to an authorized dealer for those adjustments.
If you do have an adjustable carburetor, then gently close both needles and open each on 1 full turn. This should allow the engine to start and the final adjustments can be made at that point. If it still will not start then open each needle 1/8 to 1/4 turn and try again. If this still does not work then most likely your carburetor needs a good cleaning and a rebuild kit.
Sep 20, 2009 • Garden
Top McCulloch Garden Experts
Jay Finke
Jay Finke
Floyd Rogers
Floyd Rogers
Level 1 Expert
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
