Question about Akai DVDS3500 DVD Player
Tray not ejecting
Got an Akai DVD player at grandma's. Im not sure what the model is though. i put a dvd disk inside, watched a movie, but the tray doesnt eject anymore. It says "open.." when u press it once and "closed" if u press the 2nd time, but nothing actually opensor closes. the disk is alright though, it loads and works correctly. Any suggestions on what i can do?
  • Dash Trt Jun 16, 2007
    does that mean i gotto open it?
    Problem Solver:
  • 9 Answers
Check the door belt wich is placed underneth of the driv mechanism.if the belt is not broken or getting loose in size then check the motor pully then motor. best wishes do with care.
Posted on Jun 15, 2007
What's wrong with my sony dvd player?
I would just replace it rather have repaired even if that's possible , they don't cost a fortune and are easy to fit.
Oct 20, 2014 | Sony Televison & Video
I have a Zenith I played a dvd an it worked fine - put another movie in the dvd player and was going to watch that one and it never read - screen kept saying 'reading'. I tried another dvd and the...
try using a CD cleaner disk..
How old is the system?
DO CDs work when you try them?
Put a disk in... remembering the position it was in..
Then try to play the disk...
Eject if it does not play and look to see if it has moved to a different position...
If not, there is a motor problem or the laser is not sensing the disk being there.
Have you ever opened up the main box of the system?
Has anyone else been inside it?
If yes, then maybe it is time to do it again to observe if there is movement of the laser pickup..
Jun 01, 2011 | Zenith XBS444 250watt DVD/VHS 6-Speaker...
My husband always operated the DVD player. He has died and now I'm at a loss what to do. I rented a DVD at the video store. I tried to put it into the tray on the DVD player. I had to pull the tray...
Hi, Very sorry for your loss. As always the first step is to make sure the player is connected to the wall outlet and turned on. To put a disk in the DVD you should push the "Eject" button to open and close the tray it looks like a home(a triangle over a dash) on the front side of the box down left corner of the tray. You have the same button on the remote marked "Eject". Push either once, put the disk with the shiny side down on the tray and push the Eject button again to feed the tray back into the player. Usually the disk starts automatically and you will see a menu on the TV with alternatives like "Play the movie", "Setup", "Scenes",... you may highlight the "Play the movie" alternative, using "Up", "Down", "Left" and "Right" and then press the "OK" button. Or just push the "Play" button either on the box or the remote control. If you click "Here "you can download the manual in PDF form. To open it in your pc you'll need "Adobe Acrobat Reader" (or any other PDF reader) installed.
I will gladly answer your questions Best Regards Bruce
Aug 23, 2010 | Amphion Mediaworks S99 DVD Player
DVD will not eject from movie player.
On some DVD player there is a little pinhole next to the opening or tray in case the disk or tray won't eject. You can unbend a paper clip and insert it into hole and see if it will eject. If not you will need to remove radio and have it serviced.
Your vehicle is not that old, take it to the dealer and see if your radio is still covered under warranty.
Good Luck!
May 27, 2010 | 2008 Chevrolet Uplander
Philips DVP 5992 DVD player disk tray opens without a disk
it think you should open the unit up.get the cd.then try to play it again.
May 18, 2009 | Philips DVP5990 DVD Player
DVD will not play a disc, when you close the tray, it will eject
Bad Disc.
Try a known good store bought Movie in player?
Still Bad Disc?
DVD unit in your player is bad.
Throw in garbage.
Feb 19, 2009 | RCA DRC8320 DVD Recorder/VCR
DVD PLAYER NOT READING DISC
Well I have been repairing dvd players a while now and the main problem spots are laser ,spindle motor, laser tracking motor and the biggest culprit and un suspecting one the lens cable .....most of them range from the lens cable to the spindle motor though... the constant movement of the lens in watching a whole movie causes the cable to unknowingly and slowly break and if the spindle motor is defective ,on inserting a dvd the disc spins slowly and you may hear the lens chirping ... so you can check those....
Oct 06, 2007 | Onkyo DV-S535 DVD Player
DVD movie won't eject
unplug for 5 minutes then plug back in and try again. should reset itself and work.
Sep 10, 2007 | Philips DVP642 DVD Player
Disk Tray won't open
is there a tiny pinhole to push in a paper clip to eject the tray?
Jun 03, 2007 | Pioneer DVL-V888 DVD Player
Sylvania DVC850C DVD Player
its inside on the play rack or inside om the disc storage platform.. Nowgetting these bugger sout csn be more harmfull then good so if you ca=nt ubnplug the unit and plug back in and then the unit resets My advice would be to let a pro get them out for ya as I've seen a consumer get out a disk and csuse at least double the damage that cause the stuck disk.
Apr 08, 2006 | Sylvania DVC850C DVD Player/VCR
Akai DVDS3500 DVD Player Logo
99 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
