Question about NetGear WGX102 Repeater
I have sat. internet at my home, which is 500 to 600 feet from my business. How do I get a better signal to my business. Right now, I get about 15% outside the building, which by the way is a metal building.
  • 258 Answers
I use Netgear dg834g and linksys wireless-G routers (blue and black) or modem/routers as these give the best signals ove long distances.
Also the edimax usb dongle has incredible connections for me over long distance
http://www.amazon.co.uk/Edimax-EW-7318Ug-Wireless-Adapter-802-11b/dp/B000KLQY8G/ref=sr_1_2?ie=UTF8&s=electronics&qid=1231971718&sr=8-2
I also put in static LAN IP addresses and these help with connection
see http://www.howtofixanything.co.uk/howto-269.html
good luck
Posted on Jan 14, 2009
Which type of advertisement is better for a small business?
Using Outdoor LED Signs are the most beneficial type of advertisement for all types of business.
This type of advertisement has been used by numbers of businessmen across the world.
It helps a business to grow faster and to increase the sales by up to 15% annually.
aaeaaqaaaaaaaaenaaaajduzzjrmy2uwlwjimmitndqyoc04yzk4ltrhmdk5zdk3mjk1za-he3odkd5e1hcafgllo2cwsmh-3-0.jpg
Sep 05, 2017 | Better Computers & Internet
Is the at-home-job "Ericsuccessplan.com" a scam or not?
better business bureau is the way to go
if they ask for money to get jobs , you are better off not becoming involved
Jun 22, 2017 | Computers & Internet
I want to place the webcam 20/25 feet away from PC to view the function conducted in hall,by using USB extn cord. When I use a cord of 15 feet it works and when I aqdd one more extn of 15 feet PC is not...
Unfortunately, without amplification, signal through USB cable will be lost after about 6 meters (approx. 20ft).
To solve this limitation, use a USB signal booster...
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Best regards and good luck,
Pelu.
Dec 10, 2010 | Microsoft LifeCam VX-1000 Webcam
Wii lost connection to internet how to reconnect
FIRST, you want to check and make sure that your router is working and sending a network signal. When you find that it is and your Wii still won't connect, try moving your router to a better location where the wii can receive the signal more clearly. Then go to the Wii "Options", then Wii "Settings, Scroll through screens to "Internet" option, then "Connection Settings". Choose your Wireless Connection that you were using and do a "Connection Test". Sometimes it's only a matter of a couple of feet and the signal won't be strong enough, especially if the Wii and the router are in seperate rooms. If all else fails, simply clear the settings for the wireless connection you were using and start from scratch by re-entering the connection settings for your home network. Hope this helps!
Nov 30, 2010 | Nintendo Wii Console
It seems that the signal is strong next to the router, but drops to 1 bar within 30 feet away? What is the most likely solution.
Routers generally have a strong signal for up to 10 meters. However no obstacles should be in the way. 30 feets is about 10 meters so the router is loosing its signal strength. If you would like to extend the strength of your router you can buy a range expander. This device acts as a repeater of the signal so from 10 meters you can go to 15 or 20 meters.
Mar 08, 2010 | Hawking Hi-Gain 802.11g MIMO Wireless...
Strong signal but no connectivity
ya thata right even if u move ur laptop upto 50 feet that will show the speed is good>and try this one try to change or upgrade the driver for ur pcmci card>and change the channel on teh w/l router try using 1>or 11>and rate me solved if its help full
Oct 23, 2007 | D-Link DI-624 Air Plus XtremeG Wireless...
Maximum advertised distance
D-Link Air lets you access your network from anywhere you want. However, keep in mind, that range is limited by the number of walls, ceilings, or other objects that the wireless signals must pass through. Typical ranges vary depending on the types of materials and background RF noise in your home or business. The key to maximizing range is to follow these basic principles: 1. Keep the number of walls and ceilings to a minimum - Each wall or ceiling can rob your D-Link Air Wireless product of 3-90 ft. of range. Position your Access Points, Residential Gateways, and computers so that the number of walls or ceilings is minimized. 2. Be aware of the direct line between Access Points, Residential Gateways, and Computers - A wall that is 1.5 feet thick, at a 45 degree angle, appears to be almost 3 feet thick. At a 2-degree angle it looks over 42 feet thick! Try to make sure that the Access Point and Adapters are positioned so that the signal will travel straight through a wall or ceiling for better reception. 3. Building Materials make a difference - A solid metal door or aluminum studs may have a negative effect on range. Try to position Access Points, Residential Gateways, and Computers so that the signal passes through drywall or open doorways and not other materials. 4. Make sure that the antenna is positioned for best reception by using the software signal strength tools included with your product. 5. Keep your product away (at least 3-6 feet) from electrical devices that generate RF noise, like microwaves, Monitors, electric motors, UPS units, etc. 6. If you are using 2.4GHz cordless phones or X-10 (wireless products such as ceiling fans, lights, and home security systems), your wireless connection will degrade dramatically or drop completely. Anything using the 2.4Ghz frequency will interfere with your wireless network. For the average home, range should not be a problem. If you experience low or no signal strength in areas of your home that you wish to access, consider positioning the Access Point in a location directly between the Residential Gateways.
Feb 16, 2006 | D-Link Air Xpert DI-774 Wireless Router
Feb 16, 2006 | D-Link Air Xpert DI-774 (DWL-774) Wireless...
Range problem
Feb 16, 2006 | D-Link Express EtherNetwork DI-604 Router
NetGear WGX102 Repeater Logo
142 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
