Question about Car Audio & Video
Car toad fob immobilliserdoes not work
Car fob is working as light on fob is working but does'nt allow the immobilliser disengage to allow the car to start.The car is an 'N' reg 518 BMW saloon.It may be that the fob got a little wet but the fob still lights up making me think that thats not the real problem.Is there a way to disengage the immobilliser somehow on this make and model
    Problem Solver:
  • 5 Answers
Most newer vehicles that employ a Keyfob armed cutoff also tie it into the door locks. Using the Key to open the door should disable the cutoff signal. While I have seen some that ony allow the drivers door keylock to disingage the cutoff it is your best way to see if the door lock will allow it to start.
Posted on Jan 31, 2009
Fob won't work anymore to unlock immobiliser do I change immobilliser
Take it back to the dealer for a definite fix. Or you can go to a locksmith
Jan 05, 2015 | 1998 Kia Sportage
Brought a1998 Kia sportage fob was working til I changed the battery now nothing for days tried to start the car can not find a code for the car to immobiliser do we disconnect it.and how
is it the key fob battery replaced or the vehicle battery replaced if the fob then it should work unless when you were replacing the battery you may have disturbed the contacts https://www.youtube.com/watch?v=_reliF9rQUU this video shows you how to do both it is common to disturb the contacts when replacing the battery which may be what has happened. hope the video helps it not and you are speaking of the battery being replaced in the actual vehicle then here is one to reprogram the key fob .. hope this helps http://www.ehow.com/how_7650450_reset-kia-after-battery-disconnected.html
Dec 31, 2014 | 1998 Kia Sportage
How does key fob work
Depending on the specification of your vehicle, the FOB generally serves one (or both) of the following functions:
1) Communicate with the vehicle's Keyless Entry system (operates central locking).
2) When inserted into the ignition, the transponder within the key will communicate with the vehicle's Body computer (BEM) to validate entry, before disengaging the immobilizer - allowing the vehicle to start.
When the key fob fails, you may lose functionality of the above systems.
Keyless entry failure - usually due to flat battery in the fob. Reprogramming of keyless entry can be done without dealership assistance.
Transponder/Immobilizer failure - this requires the key fob to be re-programmed by your local dealership.
Hope this helps....
Nov 28, 2011 | 1998 Toyota Camry
My immobilliser is stuck,the central locking wont work when I press the button on the fob,I have to lock/unlock doors with key and when I put the key in the ignition to try and turn engine on the little...
Suggestions
1...Make sure the fob battery is working (Try removing and replacing it again to reset everything )...or try another new battery in it
2...If that fails, try disconnecting the Main Car Battery terminal for 10 minutes, then replace it. This often resets everything as well.
Make sure you have the code for the radio before doing that
Dec 13, 2010 | Vehicle Parts & Accessories
Got bmw wiv toad alarm on battery went in thob put new battery in now dont work it does al my electrics
best advice is to remove the add on alarm ,but if its an add on alarm they often malfunction ,failing which some t`ypes of alarm have a button inside the alarm and you press the button inside and the fob to re programme it
Sep 19, 2010 | 1996 BMW 318
How do i re-program a new toad fob to my car alarm vw passatt
bought a brand new fob on e-bay with instructions on how to reprogramme
Nov 01, 2009 | 2000 Volkswagen Passat 4Motion
Vw passat w registered immobiliser
dealers will reset the codes for you but it aint cheap
Dec 26, 2008 | 1999 Volkswagen Passat
Wiring an 02 Tracker 4x4 2dr as a Toad vehicle
For my 03, I bought two tail light sockets w/ bulbs, drilled a hole in back of tail light lens and installed
the sockets, then ran 4 wire along frame to the front. When not towing, wrapped 4 wire around
ears of tow bar and secured with bungee cords. Worked for me.
Oct 06, 2008 | 2002 Chevrolet Tracker
Car Audio & Video Logo
182 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
