Question about Archos 405 Digital Media Player
Code 104 turned on new archos and got recover cde 104 cant get any further than that any one help?
Recovert code 104
would you like to recover your system?
NO
Repair disk
Format disk
P.S. pressed the OK button on the device and its telling me to
connectto your divise to my PC and install an update file DONE
then the devise reapear back to recovery code 104
Posted on Jan 16, 2009
Recovery (code 104)
From Archos' support website FAQ:
When I switch on my Archos device, the following message is displayed: "Would you like to recover your system?" What does it mean and what should I do?
You are on the recovery mode screen. It means that your hard drive has been damaged and must be repaired or formatted.
With this system recovery mode, you will have to select between "Repair Disk" and "Format Disk".
Start by selecting "Repair Disk" and follow the instructions displayed on the screen. See the full PDF manual (available on the Archos web site) on how to use the Repair and Format options.
If repairing the disk did not work, try formatting the disk by selecting "Format Disk". Note that the formatting will erase all data.
If you still cannot restart your Archos after trying a system recovery, you should contact Archos technical support.
http://www.archos.com/support/support_tech/faqs/en/faq_Archos405.html?country=us&lang=en
Feb 17, 2011 | Archos 405 Digital Media Player
Archos 405 blijtf gaan om de hertel [code 104] wat moet ik don
http://www.archos.com/support/support_tech/faqs/en/faq_Archos405.html?country=nl&lang=en
See:
It means that there is a hard drive error due to damage. The hard drive can be repaired by selecting 'Repair Disk'.
I tried to translate this for you using Google Translate, but Fixya would not allow it.
Good luck from Detroit, MI, USA.
Jan 05, 2011 | Archos 405 Digital Media Player
My archos 605 wifi is stuck in recovery
I fixed my son's 605 4 GB had Recovery code (104) on it These are the steps i followed
* Use the computer for this process that you always used for this archos
* Download the firware Upgrade 2.1
* Plug the Archos to Pc
* When the white screen comes up do format
* Wait until all done then put the firmware in to the root sector of the Archos
* Safely remove the usb for Archos from your pc first and then unplug the cable.
* Do not pick any option on the Archos screen
* Just turn it off from the power button by holding it until it turns off
* Wait about 5 minutes and plug in back to pc
* it will come up with white screen again but this time it will start Update you will see the progress bar moving wait until it is all done and it will shut off. Turn it back on Your archos will be back to normal.
When you go to download from Archos site it will explain how to download depending upon how your device pops up on your Pc.
Hope this helps
Jul 29, 2009 | Archos 605 WiFi Digital Media Player
Recovery code 104 appears on my archos 605 wifi 4gb
recovery code 102 and 104 appear in archos screen. it doesn't work.
Jun 07, 2009 | Archos 605 Wifi Portable Multimedia Player
My archos 605 has got recovery code 102 and i cant get it to conect to my pc to fix it can u halp
I fixed my son's 605 4 GB had Recovery code (104) on it. This might work for other error codes too. These are the steps i followed
* Use the computer for this process that you always used for this archos Archos should be plugged in toPc before starting the process.
* When the white option screen comes up pick the format disk
* Wait until all done do not pick any option on archos after format is done Pc should recognize your archos in 5 seconds
* Put the firmware in root section of the archos not in any folder.
* Wait about 5 minutes and plug it back to pc
* it will come up with white screen again but this time it will start Update you will see the progress bar moving, wait until it is all done, it will shut off. Turn it back on and  your archos will be back to normal
Mar 19, 2009 | Archos 605 WiFi Digital Media Player
It shows-recovery error-102 & error-104
Hi
i had same issue. nothing worked until i saw a guy who fixed his by dropping it on floor?
i dropped my archos in the protective case from 2 feet off floor. the bloody thing when came back to life, 100% good. i think the hard drive was stuck and the fall fixed it!! it cannot hurt as yours is broken still i guess. hope it works for you to
Jan 07, 2009 | Archos 605 WiFi Digital Media Player
Recovery code 104 for the archos 405 mp4 player
go to archos firmware and download version 2.1.04 to your pc or laptop and save it in a folder then get ur mp4 turn it on and go format you will get a screen that says done leave it on that and connect to your pc or laptop it will recognise your mp4 then go in my computer and open 405 and open your save file and drag the save file into the 405 but NOT into a folder below them and after it has\copied turn the 405 off and start it up should be as good as new
Dec 27, 2008 | Archos 405 Digital Media Player
Pi would like to get my player back,pls...
hi!
go to archos.com click on downloads then click on firmware and follow the instuctions !! =].. i had the same problem!! all my music got deleted but it works again !!!
Feb 29, 2008 | Archos 405 Digital Media Player
Recovery code 104
Same issue on my Archos 605 wifi 4GB
The Repair didn't work so here's what I did.
1) connected via USB and got all my Picture, Videos and Music to a safe place.
2) Downloaded firmware update.
fouund it here - http://www.downloadplex.com/Drivers/Firmware/Archos/Download-Archos-605-Wifi-4GB-Firmware-2.1.04_109044.html
3. Copied update to root of archos drive and rebooted
4. Archoes installed the update and rebooted and came up to desktop again
5. reinstalled plugins (thank god I saved them) copied plug-in to root.
6. Back on the road again
Feb 23, 2008 | Archos 605 WiFi Digital Media Player
Archos 405 Digital Media Player Logo
404 people viewed this question
Top Archos Audio Players & Recorders Experts
kaiserh1
 Grubhead
Grubhead
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
