Question about Goodman CLQ36AR49 Air Conditioner
Defrost board contacts in relay chater and do not let defrost
Added new board does the same thing. changed the tstat and checked the wiring still nothing. defrost tstat closed i just can't thing about a nother cause?
  • Danny Clark
    Danny Clark May 11, 2010
    What is the original problem?
Is sensor at proper location? try turning sensor ? Ohm sensor as you turn it.
Posted on Jan 16, 2009
Coleman Evcon furnace blower runs w/ no call for heat. Temp is 5+ degrees above thermostat setting. (Programmable tstat)
When you say door are you referring to the front door or the furnace door? If the unit kicks on AND off by itself I would say it's in the tstat or the tstat wire. If it were internal I would think the blower relay or heat contactor/relay were getting stuck AND THE FAN WOULD NOT TURN OFF until you flipped the breaker. Good luck
Mar 21, 2017 | Coleman Heating & Cooling
Main blower runs all of the time.
If you bypass tstat, meaning hot wired blower, does the blower cycle on and off by touching and removing red with fan?? If yes than obvious problem in tstat. I was leaning towards a bad relay but if you can make it work by passing tstat, there's you problem.
Jun 23, 2017 | Heating & Cooling
I have a Duo Therm rooftop AC inb my 2004 General Coach park model trailer. It has a heat/cool thermostat with a slider for t-stat control and hi/low on/auto fan switches. On heat it works fine. ON cool...
Got to be a relay/ contactor that is bad. Tstat is not energizing the relay to bring the compressor on. If you can understand the schematics you need to find where your high voltage stops. If you give direct power to the compressor and it runs then obviously power is not going through relay. Either bad relay or that the relay is not being energized at all by the tstat with low voltage. Good Luck
Mar 11, 2017 | Heating & Cooling
Unit continues to run in emergency heat when shut off.
If you turn tstat off does it still run. If so you have sequencer stuck. Replace sequencer. Also you may ahve abad defrost board out side. When a unit goes into defrost it will bring on heat so you will not get a blast of cold air. Sometimes the defrost board sticks and keps the heat on. Disconnect white wire at outside unit to break circiut. If hat goes off bad defrost board. You can change that yourself. Keep in touch Rus
Dec 08, 2009 | Goodman CPLE24-1 Air Conditioner
My compressor takes about 30 minutes to kick on in my house
that seems like too long at most delays and lock outs that are built into a system throught the tstat and the outdoor systems defrost board should only take about ten minutes. at most twenty if you had a dual fuel system. (heat pump outside and gas furnace inside). check the installer programming on your tstat may have a compressor lock out set too long for some reason.that or possible bad lowvoltage connections or maybe ants in you contacts at compressor outside. could be many things
Sep 11, 2009 | Goodman CKL36AR36 Air Conditioner
Motor good and not running possibly bad relay
hey there, it seems you know a little about the troubleshootig. The first thing you need to do is see if the rela is trying to energize by checking for 24v accross the coil while it should be running. I am guessing that with a 1/8 hp this is the condenser fan motor (outside). If you are not getting 24v at the coil is your compressor coming on? You may have a safety switch with a manual reset (usually red button) on the piping under the fan motor or just a broken wire. If this is a heat pump and the relay is located on the circuit board and the compressor is coming on,chances are the board is bad. If you only have 2 stat wires coming into the unit, check for 24v on them wait for any time delays. If it is there and at the coil replace the relay. If the 24v is not outside at all, check iside or try different collor wires, one may be broken. If still no 24v, take the tstat off the wall, turn off both units to kill power, twist the wires from terminals G, Y and R together. This should bring it on. If this is the only way to bring it on, replace the tstat. Also, there may be a float switch in a condensate pan somewhere on the indoor unit. If the pan is filled with water, it will either kill the whole 24v circuit or just keep the outdoor from coming on. Let me know what you find
seth
Jul 31, 2009 | Carrier 38BRC048 Air Conditioner
Blower fan stays running. Fan relay attached to small circuit board (coil tabs [timer?]). Capacitor on small circuit board had ''fallen out'' of ic board. Tried to get replacement board, and was sold...
If fan runs on 220 you have one constant 110 that always goes to the motor. The other 110 goes through something that will turn it off and on. This being the relay, just like a light switch. This 110 will land on the "N O" (normally open) set of contacts. "Open" meaning the voltage can't pass through. When the relay gets energized the contacts close. This completes the circuit, the motor gets the 220 it needs and it runs. On the relay coil (how it gets it's energy) you need a low voltage common and you need the "G" wire from the tstat. Likely green in color, this is your indoor blower low voltage wire. When the tstat calls for fan, cool or heat, the relay energizes, closes the contacts, fan runs. Good Luck!!
May 16, 2017 | Carrier Heating & Cooling
I have a Rudd ubha and have been using the emergency heat for a couple weeks because the aux. heat won't work. Now I need the A.C. but the unit outside won't turn on. We replaced the control panal and it...
Did you replace the defrost board out in the outside unit? Or did you replace the control board just on the airhandler? You need to check if the board outside is functioning. Also, put the unit in cool and check to see if the outside unit is being called to come on. What could of happened is the unit was the compressor went out and that's why it didn't work in Aux. and only in emergency. I would just recommend checking the outside for issues since the inside unit is operating in emer. It could possibly be the tstat also. Just buy a tstat for a heat pump and follow the instructions. The key is to label your wires with what color is going to what terminal (r,w,g,o,y etc...) and then use the new tstat instructions. Better yet, buy the same brand t-stat. Hope this helps.
Apr 04, 2009 | Ruud UBHC Air Conditioner
Frigerator runs constanly till compresser gets to hot
Sounds like it might be the thermostat
sensor bulb is defective see if you can
turn the refrigerator off with the thermostat
the defrost heater is supposed to heat up
enough to open the defrost thermostat
Make sure the defrost timer works to
turn on lhe heater & turn off the defrost tstat
turn the power off and check the tstat & defrost
heater for continuity check to see if tstat open
and closes when you turn the knob,
if you remove the tstat you can check the
bulb in ice water and warm water aborv 40
to see if tstat cycles on and off
Nov 26, 2007 | Maytag MSD2650H Side by Side Refrigerator
Goodman CLQ36AR49 Air Conditioner Logo
54 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
