Question about Dell Dimension 2400 PC Desktop
Printer wont connect to the computer
I have tryed reconecting power and usb cable fire wall and trouble shooting
  • Thomas F. Schneider May 11, 2010
    You have already installed the software and the drivers for your version of windows?
    Make and model of printer?
  • 44 Answers
Go to add a printer and tell it you want to add a local printer. It will probably fail. You will then have to select the manufacture and the model or browse to where the drivers are installed.
Posted on Jan 15, 2009
Fax wont send or receive? I can here it ringing though wont send???
Try changing the cable from the phone wall outlet to the fax, when a incoming RING signal comes, with a bad phone cable (it is 90 volts AC) so the power to ring the fax can go through but not DATA, try pluging a standard phone in the wall outlet to see if it work's.... if the standard phone don't work than call the phone company's service desk, if the standard phone work's (initiating a call) than concentrate on the printer's trouble shooting guide...
Mar 14, 2011 | Samsung CLX-3160 All-In-One Laser Printer
Printer will not print shows ready and when asked to print goes offline and doesn't print. Tested cable - ok (scanner works ok) tried with two other machines (PC &Mac) and different cable same result. ...
make sure your fire wall is not blocking. you can also go to device printers and you should see your printer at bottom screen with yellow mark on it right click it then trouble shoot then fix.
Feb 06, 2011 | Canon PIXMA iP4300 InkJet Photo Printer
Paper jam
Hi Good day!! Follow this method to remove your paper jam:
1. Check to make sure that the power cord is securely plugged into an active wall outlet if your printer is not turning on.
2. Make sure that the USB cable connecting your computer to your printer is securely connected if your printer powers on but will not perform a print job.
3. Remove a paper jam if the "Check Paper" light on the front of the printer is blinking. To do this, first turn off the printer and unplug the power cord from the printer. Open the front cartridge door and locate the jammed paper. Gently pull the jammed paper toward you. Plug the printer back in and turn it back on.
4. Connect your printer to a different USB port on your computer if you are experiencing slow printing. The slowness could be due to a connection problem with your computer's USB port. After you've switched the port, try your print job again.
5. Make sure that a phone line is securely connected from a phone jack to your printer if you are having trouble sending or receiving faxes.
6. Clean the scanner surface if your scans are blurry or have vertical white or black lines. To do this, spray the a soft, lint-free cloth with a mild glass cleaner. Wipe the scanner glass with the cloth and then dry it with another clean lint-free cloth.
7. Hard reset the printer if you are having trouble solving your problem. Turn the printer off and remove the power cord from the wall outlet. Wait at least 15 seconds and plug the cord back in. Power the printer on and try your job again.
8. Restart your computer if you can't solve your printing or scanning job. Sometimes restarting the computer can solve an unseen problem.
Don't forget to vote thanks!!!
Oct 28, 2010 | HP PSC 1510 All-In-One InkJet Printer
I've had this HP printer for years with no problem using it most days. just plug it in when i want to print. but for some reason it has just decided that windows does not recognise this USB device. i have...
Disconnect the power cord from back of printer
Disconnect the USB cable from PC
Turn off your PC
Disconnect the power cord from wall outlet
wait for 10 minutes
Reconnect the PC Power cables
Power on the PC
When you see the PC desktop
Re-connect the Power cable to printer
Re-connect the USB cable of Printer to PC
This should resolve your issue
Sep 25, 2010 | Office Equipment & Supplies
When printer connected to pc is showing usb device not recgnised in windows xp
two things to try
  1. try using another usb port ( preferably one on the back of the pc)
  2. switch out usb cable with another
Sep 24, 2010 | Office Equipment & Supplies
It says HP psc1315 printer is offline and won't print. how do i fix? wont change back to online also one document at front of queue wont delete
Reset your printer. To do this, turn off the printer using the power button, remove the cartridges, unplug the power and the usb cables. Press the power button for several times. Connect the power cable and also the wall jack, power on (don't connect the usb cable). While the printer boots up, keep pressing power button several times. Leave it for few minutes and again switch off. Now connect the usb cable as well and insert the cartridges. Shutdown the computer. Power on the printer and also the computer (Note when you power off/on, use only the power button). This will fix your problem. If possible, please reinstall the drivers for your printer before you restart it with the pc. Good luck. Thanks for using FixYa.
Jun 02, 2010 | HP PSC 1315 All-In-One InkJet Printer
I have connected d145 printer to my new dell laptop with Windows 7 but although installed as default printer it won't print
Do you have files in the queue? What is the printer status in Devices and Printers area?
Since this is a USB printer, my usual trouble-shooting starts with checking the USB connectivity. If you are using a hub, try connecting directly to the printer. Change to a new USB cable and try a different port. Check if a known working device will work in the port. Make sure the ports are not disabled for power-savings or security (power savings is adjusted as an advanced option in the same area as setting the Screen Saver, Security shut downs are in the Device Manager).
Frequently, you can reset the printer by unplugging the USB cable from both the computer and the printer and pulling the power cord for a minute. If the items in the print queue cannot be deleted from the queue, use the Command Prompt (run as administrator by a right click - Start, All Programs, Accessories) to empty the queue. Once in the command prompt, type "net stop spooler" without the quotes and then hit <enter>. Then type "net start spooler" (again without the quotes) and hit <enter>. Once the commands have been processed, reboot the computer.
I hope this helps.
Mar 25, 2010 | HP OfficeJet d145 InkJet Printer
Computer won't recognize new Lexmark X9575 printer
Are you conecting via USB? If so, did you wait to connect the USB cable until the installation advised you to? If not, uninstall the software and driver, unplug the USB cable, reinstall the software and driver, and when prompted, plug in the USB cable.
May 18, 2009 | Lexmark X9575 InkJet Printer
When I trouble shoot, it tells methe device is not connected
try to uninstall the driver and software of the printer
then a compete new installlation
Jan 26, 2009 | HP Deskjet D4260 Printer
HP Photosmart 7350 Printer Carriage Cradle is jammed
SolutionStep one: Perform a power reset and connect the printer directly into the electrical outlet Remove all the paper loaded in the main input tray.Make sure that the product is turned off.
Disconnect the USB cable from the back of the product.
Disconnect the power cord from the product.
Disconnect the power cord from the electrical outlet and wait 10 seconds.
Reconnect the power cord directly into the electrical outlet and check for the following.
Make sure that the power cord used is the one provided with the product.
If a computer is connected to the product, make sure that the computer is connected to a grounded (three-prong) wall outlet.
Make sure that the power cord is firmly connected to both the product and the power supply.
Reconnect the power cord to the back of the product.
Press the power button ( ) to turn on the product.
Reconnect the USB cable to the back of the product.
If the issue is resolved, proceed to Step six: Print a self-test page.
If the issue continues, proceed to the next step.
for more information please go to below link>>
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458822&cc=us&lc=en&dlc=en
Jun 20, 2008 | HP PhotoSmart 7350 InkJet Printer
Dell Dimension 2400 PC Desktop Logo
Alun Cox
