Question about Acer Aspire 5610-4648 Notebook
Frozen mouse hi its a laptop not a computer to plug a mouse into,ive restarted it like u suggested an its still the same
    Master:
  • 413 Answers
If there is a button that has a picture of a mouse (it will be a different color than the letters and numbers. Press the Fn key and the F - key (with the pic) at the same time
Posted on Jan 14, 2009
Dell inspirion n5030 laptop
Are you using the touchpad, or a regular mouse plugged into the laptop. If you are using the touchpad on the laptop, make sure it is enabled. There is a button to the right of the F12 key to enable/disable the touchpad. If you are using an external mouse connected to the laptop, try restarting the computer by pressing the power button once (that will initiate a shut down).
Nov 23, 2013 | Computers & Internet
My acer 15.6inch the cursor is frozen wont move
Which mouse are you using? Is it the integrated mouse or the USB mouse?
If you are using the USB mouse, then try checking if it's plugged in correctly.
If it's your integrated mouse, then restart the computer and when it's up. Try moving your mouse. Restarting it usually does the trick.
If restarting it won't fix the problem, then restart and boot to safe mode. While restarting, tap F8 until you see the options to boot to safe mode. Highlight safe mode by using the arrow keys and hit enter. When you are in safe mode, try moving your mouse. Works or not - update the mouse driver. You can use RadarSync. If no go, then you might need to do a system restore. If worse comes worst, do a complete operating system reinstallation.
I hope this helps!
David
Mar 25, 2013 | Computers & Internet
Mouse frozen which keys to use instead my lap top works how I am able to write now. My Desk top computer mouse is frozen?
If you were using a physical mouse (instead of a track pad), then try a different mouse.If you were using the track pad, get a USB mouse and plug it in. If it works, then continue to use the USB mouse. If no type of mouse will work at all, it is a software issue. If rebooting doesn't fix the issue, you may have to reinstall windows. If you are using a mouse with a driver that was installed using a disk, try uninstalling that driver from the add/remove programs window (programs and features wind on vista and later).
Apr 29, 2011 | Computers & Internet
The mouse pad area has stopped working and the cursor is frozen on the screen. However we can use the computer by plugging in a mouse to the usb port. Please advise best course of action. Thanks
get a reg. computer mouse plug in your port then go to start then go to programs and files tool bar put the mouse in you will see 2 mouses go to your lap top mouse click on now change settings around then restart laptop.
Feb 04, 2011 | Acer Aspire One Netbook 8.9" Notebook
The Mouse and Keyboard are frozen and will not work. Pressed unlock mouse button but did not respond. What do I do?
Restart by pressing the Start button and keep pressing until it shuts down. Then restart.
Here is more on this subject:
http://www.computing.net/answers/windows-xp/hp-pavilion-is-frozen/162636.html
Jan 07, 2011 | HP Pavilion dv9000z Notebook
How to unlock the key pad on a dell latitude D600 laptop
Hi. Please do troubleshooting steps below:
1. Check to be sure your "Number Lock" or "Function Lock" keys aren't lit. These can lock out certain parts of your keyboard. If either of these is lit, press them to unlock the locked portion of your keyboard. These can be found at the top right on a laptop and between the number pad and main keys on a desktop keyboard.
2. Save all open programs using your mouse. Use your mouse to restart your computer. This will only work if your computer isn't frozen. If your mouse doesn't move, press the power button on your Dell until the computer turns off. Press it again to restart. If the issue was lack of memory or a locked program, this will unlock your keyboard. Continue to Step 3 if the keyboard is still locked.
3. Shut down your computer using your mouse or power button. Don't restart. Unplug your Dell.
4. Remove the battery if you're using a laptop by turning the laptop over and sliding the battery release latch. Slide the battery out and replace after one minute.
Have a good one!
  • Step 2 Save all open programs using your mouse. Use your mouse to restart your computer. This will only work if your computer isn't frozen. If your mouse doesn't move, press the power button on your Dell until the computer turns off. Press it again to restart. If the issue was lack of memory or a locked program, this will unlock your keyboard. Continue to Step 3 if the keyboard is still locked.
  • Step 3 Shut down your computer using your mouse or power button. Don't restart. Unplug your Dell.
  • Step 4 Remove the battery if you're using a laptop by turning the laptop over and sliding the battery release latch. Slide the battery out and replace after one minute.
  • Read more: How to Unlock a Dell Keyboard | eHow.com http://www.ehow.com/how_5063232_unlock-dell-keyboard.html#ixzz0uguUk4bZ
    Jul 25, 2010 | Dell Latitude D600 Notebook
    Mouse pad frozen
    Please try the following to fix the problem,
    1.) Did we accidently press the button to 'enable/Disable' the touch pad/mouse?, for most of the machines its fn-f9.
    2.) Try plugging in an external mouse to see if you can get back your mouse functionality.
    3.) There can be a problem with the touch pad, try reinstalling the drivers again.
    Please let us know if that was helpful enough.
    Good Luck & Thanks
    Shiv.
    Aug 13, 2009 | ASUS Eee PC 900HA Notebook
    Plug-and-play mouse
    Hey there Sash Marie,
    I suggest you leave the mouse plugged in, and turn off your computer completely. Wait a couple of minutes and restart. Upon restarting it should rescan for all connected peripherals, and get things going. Alternately, if you are running vista, your mouse may not be vista compliant. Also there is the chance your mouse is faulty. I suggest you rule this out by plugging into another machine to test if it works.
    Good luck and let me know howit goes.
    Nov 05, 2008 | Acer Aspire 5100 Notebook
    Frozen screen and mouse pointer gone
    unplug the mouse then restart the computer then on the first 2 sec press the F8 key and select last good know configurations and press enter
    Jan 01, 2008 | Dell Inspiron 2200 Notebook
    Acer Aspire 5610-4648 Notebook Logo
    19 people viewed this question
    Brian Sullivan
    Brian Sullivan
