Question about Kenmore 73932 Gas Dryer
I moved and after hooking up my gas dryer to gas tank it will not heat up....
  • 686 Answers
Were you on propane b4 the move or natural gas? A natural gas dryer will not run on propane nor a propane one run on natural gas
Posted on Feb 26, 2009
Dryer will not blow hot air. only cool. just moved and hooked up dryer. gas is connected and on. what can i do to get it to worl?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jul 22, 2011 | Whirlpool Dryers
Just got it home hooked up and no heat is being produced
Make sure your gas service lever going into the gas assembly is in the on position. Bubble test and make sure you have gas to the assembly. Moving a dryer around can cause the ignitor to crack in extreme rare occasions. Mght be that the ignitor didn't make the trip.
Apr 11, 2011 | Whirlpool WGD5320SQ Gas Dryer
Smell gas dryer will not heat propane tank was empty just filled today
You have an air pocket in there. Shut off gas unhook it then turn on dryer for a min then hook all back up should work fine. Hope this helps
Apr 29, 2010 | Amana LGA90 Dryer
Need to hook up lp gas to dryer .says it is equipted for nateral gas mixed gas and lp gas .I need to hookup lp gas to washer dryer combo stacker.do you need separate gas regulator or hook straight to...
just make sure that the right orifice is in it for LP and as long as you have a main tank regulator you should be fine!! i hold a class 10 licence in Lp/ natural gas which is the highest installer licence you can posses
Jan 19, 2010 | Dryers
Whirlpool dryer newly hooked up and will not heat. Do they have a reset button. Tumbler moves. It is gas. electronic ignition?
Make sure that your gas valve is on, if there is no gas, it won't be able to ignite and therefore no heat. It is possible that the unit is defective as well. If you are sure that you have the gas line hooked up and the valve is on, also make sure you have the proper electrical connection. Most gas dryers are 120V and a standard receptacle is used. If all of that is correct, then I would suggest calling the tech support number in the information on the unit or call the retail establishment you purchased it at.
Oct 27, 2009 | Whirlpool Dryers
Whirlpool gas dryer
check new gas line for foreign objects
May 06, 2009 | Whirlpool LGR5634L Gas Dryer
I just moved and my LG dryer does not heat up.
Your ignitor (glow bar) got broken during the move. They are more fragile than your grandmother's fine china
Dec 16, 2008 | LG DLG9588 Dryer
Does a Kenmore Elite H3 dryer have a pilot Light???
No. They are electronic ignition. just plug it in and hook it to gas and should heat up.
Nov 21, 2008 | Frigidaire FGQ332ES Gas Dryer
Kenmore 73932 Gas Dryer Logo
158 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
