Hi Paul,
This problem is often the result of a loose video cable connection on the computer or an incorrect video signal selection. Most monitors use a cable with "VGA" connector on the end that mates to the computer video port. Other modern computers make use of an HDMI (like the ones used to connect a TV to a BluRay Disk player) or DVI connector instead - either way if it is loose you will get the same "No Signal" message on screen. Make sure these connectors are making good contact with the port on the computer by seating them fully (or better yet - remove and reinsert). In the case of the VGA connector, most have two screws to hold them in the port - you should make sure both are threaded all the way in. You do not need to crank them down, finger-tight is more than enough.
Many newer - flat screen types in particular - do not have the video cable permanently attached. Instead, they use the same cord and connector arrangement found on the computer. It is possible that the connector has become loosened on the monitor end - especially if the monitor is moved / adjusted frequently. You should check the connections at the rear of the monitor just as you checked at the computer, too.
When satisfied that the connections at the computer and monitor are good, check the monitor again. If the message is still present, the monitor may be able to select between an analog input and a digital input via a menu item accessible from the monitor. Check your monitor manual for instructions to change inputs if unsure. If you are using the "standard VGA cable" (the one with the two screws) you should select the analog input. If you're using an HDMI cable, you should select the digital input. If you're using an DVI connector the input may be either analog or digital. When making a change, wait 5 to 10 seconds between toggling between the analog / digital selections to allow the monitor to sync the signal for proper display.
If you're still unable to display the desktop, it is possible that that someone has changed the BIOS options to select a different video card (if more than one is installed) or that the cable is defective.
I hope this helps and good luck!
Testimonial: "Very assuring to hear from a pro."
