Question about IBM ThinkPad T20 2647 Notebook
Computer wont power on.
The laptop will not turn on as the "Z" and hdd light just flashes every time i press the power button. I changed the motherboard and all came back to normal but im wondering if there is a circuit that commonly fails on the motherboard that i can replace and get my old motherboard working again.
  • Radzer0 Jan 14, 2009
    Im a computer repair shop. So i tested other ram. CPU. even minipci combo card (which i have found to lock machines when starting)
    Its not lighting up and nothing coming on the screen. The led's above the keyboard flash but it doesnt ever come on at all. No fan, hdd spin up, nothing.
    Genius:
  • 1,019 Answers
if you,ve changed the motherboard, i,d suggest the problem lies with a faulty stick of ram. or 1 of the memory slots are faulty.
failing this, try a different CPU.
Regards Mike @ compurepair.
Thankyou for using Fixya.
Posted on Jan 14, 2009
  • Mike Waldron Jan 14, 2009
    Thankyou for your appreciated rating.
    If i can be of any further assistance. Please reply to this Post.
    Many thanks mike @ Compurepair.
  • Mike Waldron Jan 20, 2009
    This rating is Disgusting, the rating is not in my opinion Inappropriate.
    You asked questions, and got answers in return.
    If the board does,nt boot. Theres a motherboard problem. Short/ground Fault. the CPU is poorly or incorrectly inserted.
    Or even the wrong CPU. ( Wrong Speed/cache et,c.
    The Ram is faulty, Or of the wrong Type/Speed.
    Unsucessfully flashed Bios.
    **** Please do not rate poorly, until Your Solution is Answered**** Most fixya experts work on a voluntary Basis And Free Of Charge.
    Thankyou for using Fixya,
    Mike @ compurepair.
    ******Post-Ended*****
Dell latitude 10 st2 e wont boot
Hi voyagerbooks,
Request you to try following the below steps which might help:
    (1)Turn off the computer.
    (2)Remove all the external peripherals like AC Adaptor, flash drives, battery, etc.
    (3)Press and hold the power button for 30 sec which releases the static on the computer (if any)
    (4)Put back the battery and plug in the AC Adaptor.
    (5)Let the computer charge for some time.
    (6)Try turning on the computer.
    If the computer doesn't turn on then check if the computer gives any series of beeps or if there are any diagnostics LEDs shown on it.
    Thanks and Regards.
    Kiran Kumar.
    #iworkfordell.
Apr 07, 2015 | Dell Computers & Internet
Stuck sleep mode
The solution to no post on a computer is to remove everything that you can, take out the hdd, the ram, and optical disk and see if it boots. If it does, put the RAM back, then try again, if it does, put the hdd back and try again. It is a process of elimination. If everything is removed and it wont boot, it may be the motherboard. I have also seen bad batteries do this. There is a chip inside the battery that wont let the machine boot when the life of the battery is expired.
Aug 19, 2017 | Toshiba Computers & Internet
Samsung r540 wont boot
lets try something...take the computer and unplug it ..then remove the battery...with the battery set aside plug the wall plug back in and plug that into the wall outlet....then hold down the power button for about 2-4 seconds and let me know if it turns on or if there is any changes
then try a different power cable and if that doesn't work then the problem is with your motherboard....you can attempt to reflow the board by taking it all apart...make sure you remove everything that can be heat damaged...cpu ect.....then take aluminum foil and make 3inch soft balls out of it to suspend the motherboard so that it doesn't touch the cookie sheet pan....then bake at 400 for 10 mins...and after that if it still doesn't work then you need to replace the motherboard
Feb 17, 2013 | Samsung R540 Laptop
Dell Inspiron E1505 fails to boot up. "A" caps light, and the light next to it (downward arrow in lock) both flash, but then the flash ends and the computer doesn't power up. Is this...
Please try to reseat you memory RAM and try to turn ON again.
If you want to retrieve Information on your HDD, you can take out your HDD from your laptop and use USB External HDD case. Please refer to link below :
http://shop.ebay.com/i.html?_from=R40&_trksid=p5197.m570.l1313&_nkw=HDD+case&_sacat=See-All-Categories
Thanks for visiting FixYa. We answer your question for FREE. Please feel free to click on "YES" button in return. Have a good time...!
Thanks
Jul 20, 2011 | Dell Inspiron E1505 Notebook
Lenovo laptop is not able to start since it tells that no bootable connections - insert bootable and press any key
Follow these steps below.
1. Turn the computer on.
2. Keep tapping F12 after pressing the power button.
3. Advance Boot Menu will come up.
4. Using the arrow keys, select HDD as the device to boot from.
5. Press Enter.
6. If the computer boots up normally, we fixed the issue.
If not, it means that the computer no longer detects the HDD. It needs to be reseated and after reseating the HDD it should boot up normally. If still the computer cannot boot, then, replace the HDD as it already has gone bad.
Thank you for visiting FixYa!
Apr 25, 2011 | Lenovo IdeaPad Y430-5242U Notebook
Will not power on
hi
frist chack your Adeptor if it's working then just chack your bettry
if this two devices are wroking then you have to go for technition becoz may motherboard and HDD prob
May 26, 2010 | Dell Latitude D400 Notebook
Laptop wont turn on
Does the power light flash? Try remove the battery for 5 mins with unit unplugged, then reseat the battery and try again.
Feb 21, 2010 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Screen wont turn on
remove the battery and the power from the laptop.....then press and hold down the power button for 20 seconds ...... attach the AC power only and turn on the laptop this should turn on the system.
This drains the capacitors on the system (safety feature of laptops ... quite common)
If this does not work remove the Ram and reseat it ... something has either come loose or the backlight on the LCD has gone bad.
Oct 06, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Dell latitude D600 problem
The flashing caps lock is an indication of a failed POWER on Self-Test (POST)
Remove the HDD, Battery, AC adapter, RAM and Modem
Press and hold power button for 15 seconds
Connect AC, see if you get any beep codes. If you do, power off, disconnect power, insert RAM, connect AC and reboot. If system boots, power off and add hard drive. If it doesn't, replace the motherboard.
If the system boots with RAM, but fails to boot with HDD, replace HDD 1st.
Jun 25, 2008 | Dell Latitude D600 Notebook
Dell D600 latitude will not power up
you can try to replace the motherboard, which is apparently totally UnHappy
Mar 16, 2008 | Dell Latitude D600 Notebook
IBM ThinkPad T20 2647 Notebook Logo
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
