Question about IBM ThinkPad R51 Notebook
R51 will only start on battery.
If i charge the battery in another computer it will come on. But only will run off of battery. I changed out the jack with the good one from the machine i was charging the battery on and it still doesnt come on with wall power.
I read there is a battery fuse that would prevent battery charging but it would still work on wall power. Any sugestions are welcome.
  • Radzer0 Jan 14, 2009
    When i said the jack what i ment was the port on the computer.
    Also im a computer repair shop so i have alot of cords and other things around. Usualy i would just replace the motherboard and not try to repair it. But this computer is for my little cousin as he took really good care of it and his stepdad broke it on him.
    Im really looking for info if there is a fuse on the motherboard somehwere between the jack connection and where the power gets dispursed on the motherboard to the battery, cpu, chipset, etc.
  • Anonymous Jan 15, 2009
    There is a fuse on the motherboard too. I did find it but its fine. Thats the battery to jack fuse i found.
    Problem Solver:
  • 8 Answers
Well it sound pretty much like power is not reaching the laptop components so neither the computer turns nor charges the battery using the power adaptor. You mention that you used the power adaptor from other laptop (hopefully same model he he) so it is clear that the fault is not it.
It might be the power "inlet" , I mean the socket where the plug is inserted, it can always get broken.
Another theory is that it might be the power regulation circuit on the mainboard.
In both cases it requieres to send the laptop to be repaired.
A home made "solution" might be to dissassemble your laptop and test the power on the mainboard using a Voltmetter, this requieres some skils so if you decide to try it be cautionous.
Good luck!!
Posted on Jan 14, 2009
  • angav Jan 14, 2009
    Mhhh... Fuse is on battery, not at the mainboard. :(
Thinkpad R51 will not boot
Try remove ALL media DVD.CD,USB,etc. Shut down, unplug, remove battery, plug in, reboot. Do you get anything on the monitor? Can you access the restore/recovery software? Open the Memory bay and reseat the Memory, open the HDD bay reseat the HDD, Reboot. If no change remove HDD, test, replace if necessary. Have you changed the CMOS battery?,
Jan 18, 2013 | IBM ThinkPad R51 Notebook
Asus UL50VT always shows charging
Either your battery or the power cord has an issue. Does the battery ever fully charge and make the charging light disappear or turn green? If not the battery could be bad.
Try running the computer off the battery by removing the power cord. if the battery starts losing charging strength real quick then your battery is bad. I've see bad batteries that say they are 100% charged but as soon as you remove the power cord it gets down to 5% i a matter of minutes.
Try running the computer on just the power cord. If it stays on and lets you operate without any problem then the power cord is good. A good power cord will not charge a bad battery.
If the laptop does not let you stay on long with the power cord, then either the power cord is bad or the DC Power Jack where the power cord plugs into the laptop is bad. If either of them is bad they will not charge a good battery.
Check your DC Power Jack which is where the power cord plugs into the computer is bad. Take an ink pen and push the tip inside the jack and see if the little pin wiggles, if so the jack is bad. You'll have to take the laptop apart to fix it. Most times it is soldered onto the motherboard, so you will have to desolder the old and solder a new one.
Jun 06, 2012 | Computers & Internet
Asus always shows charging
Jun 06, 2012 | ASUS UL50Vt Notebook
Computer is not charging the battery.
Your DC connector is probably loose from the system board:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by re-soldering DC-IN jack on the system board. If it
Jan 05, 2011 | ASUS F8Sn-C1 PC Notebook
My R51 will boot up but will then cycle through windows welcome to desktop and shut down returning to the think pad screen over and over when I use the battery. It doesn't do this when on ac power. I...
The charging device is part of the main motherboard and consists of a six pin SMD chip that controls the voltage and current feeding a switching transistor that feeds the battery to charge it.
I have replaced a few with good results but if you are not and electronics engineer with IR de-soldering equipment, don't try it as you may damage the board.
Aug 26, 2017 | IBM ThinkPad R51 1830 (1830AHU) PC...
HP zd8000 will not charge battery or run on power cord
check the dc jack probably is loose that cause the batterie dont get charge
Aug 13, 2009 | HP Pavilion zd8000 Notebook
IBM r51 battery won't charge. How to confirm if battery is good?
once u hold the battery and see it has to be cool,if not it as to be changed it has become old.
thanks
Jan 31, 2009 | IBM ThinkPad R51 Notebook
R51 2887 NQ2 Thinkpad (not under warranty) not powering on. The problem appeared 3 months ago for the first time, but going through some forums, the problem got temporarily solved by removing the...
First, the simple things need to be checked. Is the power supply line, from the wall socket to the computer input socket, in good condition. Best test is to try it on a known working Thinkpad or with a multimeter if one is handy.
Second, connect to an outside monitor to rule out faulty laptop monitor. If the known working monitor paired with the R51 works perfectly then you know it is your screen.
Third, does moving or flexing the computer by its base when running exacerbate the problem?
That will get some preliminary data.
Jan 24, 2009 | IBM ThinkPad R51 Notebook
My BAttery Won't Charge
The issue is most likely with the power jack within the back of the laptop. Many laptops have problems with the solder joints that connect the jack to the motherboard cracking or the jack itself failing. It can be replaced, but it involves disassembling the computer down to the motherboard, removing the old jack, and installing a new jack. eBay is a good source for new jacks, but it's best to have the old jack in hand before purchasing the new one, for comparison.
Dec 08, 2008 | Dell Inspiron 1300 Notebook
IBM ThinkPad R51 Notebook Logo
182 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
