Question about HP DeskJet 5850 InkJet Printer
Has anyone ever gotten this printer attached to a wireless network?
It works fine attached with a cable....but it's never worked wirelessly....any tips?
    Master:
  • HP Master
  • 188 Answers
I was also having the same problem with my hp officejet pro 2600 printer.I called hp tech support at toll free number- 1-800-585-2494 and they have solved my problem instantly. hope this will help you better as well. for more information you can visit: HP Customer service
Posted on Sep 11, 2016
  • 59 Answers
You know, I have a 2710 hp wireless AIO, and it is really crappy wireless. As far as the "detailed" manual says, you can connect wirelessly via an ad-hoc, or one to one mode. But this knocks out you're current wireless network. Example, I can't print and surf with Ad-hoc. You should however be able to connect to the wireless network though. I can with mine. But only if it isn't secure. Anyhow, look online for hp's utilities, or maybe something thats already in your programs.
Posted on Jun 15, 2007
The printer I use is brother MFC-7840W. It sits next to my computer. I have employees who wirelessly print to the it but in order for it to broadcast wirelessly I have to unplug the network cable from my...
I dont think you have the network set up in the correct way. You should be using a wireless router. If it is a 4 port router, your computer network cable should be in port number 1, the printer can be be wireless or cabled into port 2 of the router. This way you have the internet and can still print wirelessly to the printer and so can anyone else.
Jul 21, 2011 | Brother MFC 7840W Printer
Wps54g wireless failed to connect but works with the ethernet cable Both the print server and the Router are linksys (router= wrt54g) I have all the cds and everything that came with them but nothing...
It sounds like you are using a router, then using a router in series with it. The two networks will most likely not be seen between computers hooked on different routers, although you should be able to get to the Internet. If you need more ports, get a switch instead of a second router. To make the printer work with what you have, use the wireless printer on the same network (that is, from the same router.) If you need the second router for more area coverage, get an extender.
Sep 29, 2017 | Linksys Computers & Internet
Windows 7 and Linksys wireless print server
Step for installing Network print server in windows 7.
Click Windows "Start button"
Select "Devices and Printers"
Click "Add a Printer" button
Select "Add a Network, Wireless or Bluetooth Printer"
Printer wizard will searhc for all network printer including wireless.
Select "The printer that i want is not listed"
Select "Select a shared printer by name"   (Make sure you have shared the printer you want to connect)
Type the IP address of the printer if it ia a printer.
If it is printer that is connected to a PC then type like this below
\192.168.0.50printer shared name where 192.168.0.50 is the IP address of the PC where the printer is connected.
Click Next and if you want to Send a test print you can try that too,otherwise click "Finish".
That's it.
Jan 02, 2010 | Dell Inspiron 1545 Notebook
I am trying to connect my macbook pro 4.1 to a wireless printer. That printer works fine - when on wireless with my wifes windows machine and it works fine if i connect my mac to the printer- just not n a...
IN the case of the Mac what I have had to do in the past was shut down the other laptops and computers, delete the printer program from the Mac and start over. During the setup of the printer make sure nothing is connected to the printer. Only connect what you are instructed to at the appropriate time. It will eventually ask you how you are going to connect to the printer from that particular printer, answer ethernet cable and attach the ethernat cable to the printer from your router, make sure your laptop is connected to the router with an ethernet cable. Always set your computer up to the printer vis a hard line, then onve it is done you can swap over to a wireless setup. Once the setup is complete and a test print is accomplished bia ethernet cable, then disconnect the cable from the laptop to the router. Once you are connected to the network wirelessly, attempt another test page, you have already set the printer up at this point to be your default printing device so the laptop will find the printer on the network and initiate it. You may have to watch close for a pop up window asking to allow the connection or access to the program. Maybe think about dropping the firewall temporarily until the connection is secure.
Nov 29, 2009 | Computers & Internet
Today I bought and installed a Linksys Wireless-N router. Everything is working well (two laptops wirelessly and two TiVo adapters wired), except for my hardwired (via Ethernet cable) HP LaserJet 2420dn...
set the printer up manually with a static IP address. To do so, go to the setup menu under network settings and select manual.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jul 18, 2009 | Computers & Internet
HP P2015dn wirless connection stopped working
There is not wireless netwrok card is HP LJ P2015dn, However as i can understand you r using External Wireless Router or Wireless network or jet-direct card if u r able to work fine on USB than printer printing mechanism is working fine.
If u connect the printer via wired network connection and it keeps on loosing IP address than it may be problem with onboard network card of the printer.
If printer keeps on loosing IP Address than try upgrading the firmware of the printer.
To check the firmware and IP Address of the printer print a configuration page by pressing and holding down green button for 6 to 7 seconds
May 28, 2009 | HP LaserJet P2015dn Printer
SBG900 Wireless not detected
See the other post. Change the "channel" on the online settings and that should work.
Jan 12, 2009 | Arris SURFboard SBG900 Wireless Router...
Wireless Network for my laptop
You must purchase a wireless router. I recommend Linksys. If your laptop has ethernet capabilities this will work just fine. (ethernet ports look like oversized phone cord ports) they are very simple to use and install in minutes. just be sure to make sure your network is password locked!
If this helps, I would really appreciate a FixYa! rating. If not, do not hesitate to contact me. I own a linksys wireless router, and can help you install it, if need be. Have a good day!
Apr 30, 2008 | Dell Inspiron 8200 Latitude C840 Laptop...
HP 7410 can't print anymore
I think I have solved this, any way it worked for me.
Turned off printer and turned off wireless router made sure no computers are on.
Restarted printer make sure wireless settings are installed in printer then restart router.Once router is up and running switch on computer and you should be able to print.
Hope this works for you.
Dec 17, 2007 | HP OfficeJet 7410 All-In-One InkJet...
HP DeskJet 5850 InkJet Printer Logo
514 people viewed this question
Clive
Clive
