Question about HP Photosmart D7160 InkJet Printer
HP D7160 tells me photo drawer not pushed in, which it is!
It will print test page but nothing else
    Genius:
  • 1,605 Answers
This is copy from HP web site.
The paper might not be loaded correctly. Use the following steps to load paper in the printer:
  1. Lift the output tray and extend the photo tray. Figure 1: Lifting the output tray HP D7160 tells me photo drawer not pushed in, whic - c00693708.gif 1 - Output tray 2 - Paper-width guide 3 - Paper-length guide
  2. Slide the paper-width and paper-length guides to their outermost positions.
  3. Load up to 20 sheets of paper into the photo tray with the side to be printed facing down. Verify that the stack of paper fits loosely under the tab on the paper-length guide. NOTE: If you are using tabbed paper, insert the paper so that the tab is closer to you. Figure 2: Photo tray c00693709.gif 1 - Paper-width guide 2 - Paper-length guide 3 - Photo tray grip
  4. Adjust the paper-width and paper-length guides inward until they stop at the edges of the paper.
  5. Push in the photo tray.
  6. Close the output tray.
Posted on Jan 14, 2009
  • HP Master
  • 19,396 Answers
Try puttong more paper into the photo tray.
If it still does not fix the problem , follow instructions below:
» The Printer Does Not Pick Up Paper from the Photo Tray
    Sergeant:
    Novelist:
  • 326 Answers
For hp printer drivers
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=305980&lc=en&cc=us&dlc=en
 just get your drivers loaded again from this site and then try printing.
    President:
  • 2,110 Answers
Set printer to mfg mode
press *# together
press 127
change from user to mfg mode
shut down restart
press power button after a graphic screen
see rainbow screen
press power button again
    Sergeant:
  • 221 Answers
Check out if the drivers are proper or reload the drivers and check out again.
    Genius:
  • 1,847 Answers
Have you installed the driver for the printer?
HP D7160 Test page
Give it from contol panel / printer.
Jan 01, 2013 | HP Photosmart D7160 InkJet Printer
My calibration page printed on plain white text paper
When you calibrate the 5100 AIO, first, you push in the photo paper drawer until it CLICKS. Next, print an alignment sheet. It will use the photo paper. Pull the drawer out, put the printed sheet in the scanner bed, with the arrow in the right hand corner, closest to you. Press start and it will scan and print a sheet on full sized paper.
If your initial scan doesn't print onto photo paper, you don't have the drawer pushed in the whole way. There is a definite click and the green light will turn on.
May 14, 2011 | Kodak EASYSHARE 5100 All-In-One Printer
HP d7160 won't print black, New cartridge. Goes through the motions - but nothing hits the paper. Colors print fine. What gives?
1. Turn printer off and disconnect the USB cable from the PC to printer
2. Uninstall the printer driver and software-->here's how.
Navigate here for printer driver and software .(Select your Operating System and click next)
Install the printer driver and software -->here's how
Feb 23, 2011 | HP Photosmart D7160 InkJet Printer
D7160 error messages showing put the papers facing down , its correct selection from our side but keeps showing the messges
Print a self-test report. See the section on how to use these solutions at the beginning of this document.
  • If the self-test report prints , try printing the original document again. If the issue is resolved, there is no need to continue troubleshooting.
  • If the self-test report prints, but the original document does not , continue to the next solution in this document.
  • If the self-test report does not print , try printing the report again. Listen for the rubber paper-pick rollers; you should be able to hear them rotating. Then, try slowly pushing the paper farther in until the roller engages to pick up the paper. Be careful not to push the paper in too far, which can cause paper jams.
    • If the self-test report does not print when slowly pushing the paper farther in , repeat the previous steps to clean the rollers again. If the issue continues after repeated cleaning, skip the next solution in this document, and then service the product.
    • If the self-test report prints when slowly pushing the paper farther in , try printing the original document again. The paper might not have been loaded far enough into the product. If the issue is resolved, there is no need to continue troubleshooting.
    • If the paper only feeds through the product when you slowly push it farther in , repeat the previous steps to clean the rollers again. If the issue continues after repeated cleaning, skip the next solution in this document, and then service the product.
Nov 18, 2010 | HP Photosmart D7160 InkJet Printer
How do i clean the rollers on a hp photosmart d7160
  1. Remove the power cord from the electrical outlet. Open the printer cover and expose the printer rollers.
  2. Remove the paper from the "in" tray and any paper you may have in the "out" tray.
  3. Hold the wet cloth against the first roller with one hand and use the other hand to manually turn the roller.
  4. Replace the paper in the in tray. Plug the printer in and print a test page. The rollers should take the paper from the in tray. If not, repeat the process in Step 3 to make sure you remove all of the dirt.
A HELPFULL IMAGE:---- 261257_thumb.jpg OK. thanks.
Aug 14, 2009 | HP Photosmart D7160 InkJet Printer
Ink not printing the same image quality that is on computer
Issue When printing directly from a memory card, the printouts have an abnormally high red tone.
NOTE: This does not affect the prints that were originally sent from the computer. Solution Press the Photo Fix button to turn off the Photo Fix feature before printing from a memory card. Cause The Photo Fix feature was originally designed to reduce/enhance printed pictures by making colors more vibrant. However, it can also have a side-effect to make some prints have more red tone than desired. In the HP Photosmart D7100 series printer, this feature is “ON” by default.
Dec 15, 2008 | HP Photosmart D7160 InkJet Printer
HP D7360 prints in magenta instead of black. Both cartridges are
Check your other colours. Anything other than a True Type Font is printed in colour shaded with black, so it sounds like you have a problem with yellow and cyan. Either the ink cartridges are out or the print heads have a blockage.
If the cartridges are not empty or v low, try sitting the print head over a folded paper kitchen towel damped with hot water for 10 minutes. Remove it and try your diagnostic again.
Dec 11, 2017 | HP Photosmart D7160 InkJet Printer
Poor print image
You use your printer settings to set quality of image.
Jan 31, 2008 | HP Photosmart D7160 InkJet Printer
Hp photosmart d7160
hp photosmart d7160
how can i print 4x6 photo paper ? it says load paper in the main tray its only printing with large plain paper , even if its set to photo tray , and if i put the 4x6 in the main tray it says wrong paper zize ...
Nov 10, 2007 | HP Photosmart D7160 InkJet Printer
HP Photosmart D7160 InkJet Printer Logo
57 people viewed this question
Ben Johnson
