Question about NexxTech USB External Floppy Drive (NEFD2) Floppy Drive
Problem to run the floopy drive
I cant run the floppy. When i try to open floopy always requests format, but previously not it towards. That I can do.
  • 2 more comments
  • Anonymous Jan 26, 2008
    Last year I purchased a new computer with a Windows Vista operating system. I also purchased a Nexxtech external floppy drive. My computer was set up by 'Firedog' computer technicians. I have hundreds of pictures on floppy disks that I would like to transfer but every time I insert a floppy I get the message that the disk must be formatted.
    I read the one solution but did not know what 'domaget' is.
  • Anonymous Jan 30, 2008
    Have the same problem with this usb portable 3.5" drive: Does not read disk and wants to format. Its the same on three different desktops and one laptop with XP and can not find update to driver or how to fix problem. In one case the drive wiped out the data on my disk after inserting it and doing a windows explorer on drive A. I also tried reformating on another working 3.5 system and down loading a known file with the same results.
  • Anonymous Mar 12, 2008
    Windows Vista Operating system. When I insert a disk into the floppy drive it wants me to format the disk. If I do that I will lose my pictures.why won't this floppy drive work?
  • wdisne2000 Jul 13, 2008
    When i insert the disk it says it has to be formated. I dont want to do that because the reason I purchased the external drive was to retrieve the stuff on the floppys. Please help
I had the same thing two years age with a comp-usa drive. Would not work with XP operating system but would work with 98. try and find a 98 machine, add driver and may work there.
Posted on May 31, 2008
Never buy a Nexxtech / Phoenix / Mitsumi product again! Maybe then the manufacturer will provide solution..... Pass the word!!!!!!!
Posted on Jan 30, 2008
  • 3 Answers
There is to reason for this problem : 1- my be the floppy drive is out of order try to use another one. or clean it. 2- your flopy disk is domaget. Thanks ,is you can give me your feed back.
Posted on Jun 18, 2007
SOURCE:
I have a USB portable diskette external floppy drive. It is new. It is supposed to work by simply plugging the in teh usb. When I try to use it, it always tells me to format the disk. i of course, do not...
Try different and empty disk, then format it, when you can open it after you format it, then your first disk is damaged.
If still persist, then clean the drive using floppy drive cleaner, it should work.
Oct 17, 2009 | IBM USB Portable Diskette Drive (05K9276)...
I have western digitial hdd model wd5000aajs the problem i'm having is its giving trouble to format and when its installed in the pc i can't start windows or if i try it in linux i doesn't format i just...
Go here: http://support.wdc.com/product/download.asp?groupid=606&lang=en.
Download the floppy edition of Datalife tools. Follow the instructions to create a floppy disk.
Put the disk in the drive and reboot.
Run a diagnostic to make sure the drive is functional.
If it is, then run the format utility on the disk.
If its not, request an RMA from Western Digital. You have a 3 year warranty and their RMA service is very good.
Sep 07, 2009 | Western Digital (WD5000AAJS) 500 GB EIDE...
Cant install recovery disks after a hard drive reformat!
the recovery disk is designed to repair or restore a system to its previous factory condition and is not a full installation. the formating of your hdd would have erased all the data required for this process to be completed. you can try a recovery utility that may be able to help you at this link. the disk might not have been saved in an .iso format to tell the computer to run it before starting an OS. if this disk is recognized and runs on your system then you will need to attempt a recovery, which is unlikely since the drive has allready been formated many necessary system files may not be able to be restored. at this point a complete new install will be necessary.
Good Luck!
Mar 12, 2009 | HP Compaq Presario C304NR Notebook
Floppy disc not working
Sometimes u can go to a different computer and get the disk to work. Most of the time u can't though. I suggest you try a few different computers (new and old computers) and if you get one to read it get your info off and save it to another floppy or a flash drive or something. I have also tried the format option and it will always say that the disk can't be formatted. I usually toss them in the trash after that.
You may also try running a standard windows scandisk on the disk. A lot of people feel more secure saving their stuff to a floppy, mostly because it's something physical they can hang onto and carry around. But the truth is that they are far too unreliable to use given the wide range of other options available today (e-mail, ftp, jump drives, hard drives, cd-roms, etc.)
Jan 20, 2009 | Sony (1QTY) Beige 3.5" Internal Floppy...
UNABLE TO READ A NEW, UNUSED FLOOPY DISK THAT I PUT NEW INFORMATION ONTO. THE ERROR, AS I CALL IT ASK ME IF I WISH TO FORMAT THE FLOPPY. IT REFUSES TO READ THE FLOPPY DISK WHICH HAS MY INCOME TAX INFO...
The disk may have unrecoverable formatting errors making it useless. Or your hardware could be on the failure.
If you absolutely must , try purchasing or borrowing an external floppy drive and try to save the information to the disk on the external drive. If if formats and works then you know your internal floppy drive is bad.
If it has the same problems as formatting it in your internal drive, then the floppy itself is bad.
If I may suggest , in the future it would be wiser to save all your data to a removable USB Flash Drive. They are very very inexpensive and cost a lot less then a box of floppies :)
Aug 17, 2008 | Computers & Internet
I need Emergency Disk Floopy Content. If any body is having it please mail me.
If you need a emergency floppy disk go to http://www.bootdisk.com/. The emergency floppy disk only has boot files that enable you to possibly fix a windows issue.
Apr 27, 2008 | Compaq Presario 5000 PC Desktop
I have an old G3 and when I power it up it gives me a floopy disk in the middle of the screen with a ? mark flashing I have no start up floopy can you let me create one
You could try to start from the Disk Tools PPC (can be found here; the Disk Copy 6.3.3 utility, and another Mac with a floppy drive, would be required to make a bootable floppy from the disk image). Otherwise, an appropriate version of the operating system on CD will be needed.
Apr 10, 2008 | Computers & Internet
Floopy drive
Sounds like you have a bad floppy drive. If you are unable to read a disk and it wants to format it so it can read it try letting it format a floppy with no data on it or with floppy you don't care about. If it can format and you can read and write to it, then bad disks. If not then you know you have a bad floppy drive. Replace and enjoy.
Feb 12, 2008 | Computers & Internet
Download bios and flash
http://www.pctuning.cz/index.php?option=com_content&task=view&id=5463&Itemid=53
Sep 13, 2007 | Biostar P4M800-M7A Motherboard
NexxTech USB External Floppy Drive (NEFD2) Floppy Drive Logo
189 people viewed this question
Top NexxTech Computers & Internet Experts
Steven Wander
Steven Wander
Alun Cox
Prashant M
Prashant M
Are you a NexxTech Computer and Internet Expert? Answer questions, earn points and help others
