Question about Necchi 6011
Zig zag stitch
The zig zag stitch on my necchi 6011 is not smooth. It puckers or is irregular and does not look good on the top side. i feel like I have tried everything. Please HElp
  • 25 Answers
If your stitches do not look good on the top side you have a problem with the bottom thread. make sure you have the correct bottom tension: Is the thread under the bobbin tension plate and when you hold the bobbin and case lightly in your hand the tension should be set in a way that there is little resistance , yet still some, when you pull the thread. After you set your bobbin tension, you may have to adjust your top tension to balance. Also make sure the thread comes off of your bobbin the way your manual tells you, clock or counter clock wise.
Make sure your bobbin (plastic) is not sooooo old, buy a new one.
Posted on May 08, 2009
Elna machine puckers silk on zig zag stitching, Elna 2007
Yes, because a zig zag stitch is creating a wide stitch and the tension on the thread is going to pull the fabric within the seam together, you can't seam thin fabric with a wide zig zag. It will "tunnel together". If you are using this stitch to neaten a raw edge, then try using the serpentine or three step zig zag where the needle pierces the fabric 3 times in each leg of the zig zag, this will give better results.
Jul 07, 2015 | Elna Sewing Machines
What is the difference in Necchi BF and Necchi BU?
Necchi BF is a straight stitch machine
Necchi BU is zig zag machine
Necchi BU Supernova had cams for additional stitches
Jul 17, 2014 | Necchi Sewing Machines
Viking 6360 buttonhole procedure
you start with the broad zig zag stitch bar across the top
then you go down the left side using a smaller zig zag stitch
then you make the the broad zig zag stitch at the bottom
then you make the smaller zig zag stitch on the right side
all the way to the top broad zig zag stitch & your done
the right side zig zag does not go beyond the top broad zig zag
stitch
Aug 01, 2012 | Husqvarna Sewing Machines
I bought a R-2000 never used Necchi at an estate sale. Did not thoroughly read the manual before beginning to sew. Now it will only sew a zig-zag--think I did not use the release knob before changi
since you bought the machine at a state sale it would probably be a good idea to have the machine serviced.
you should be able to go from straight stitch to zig zag with out any problems.
if you move the dials or knob & the machine will not do a straight stitch then it needs to be checked
May 21, 2012 | Necchi Sewing Machines
The bottom stitch is very loose. I've tried tightening and loosening the screw and the problem remains...HELP!
The bottom stitch is affected by the TOP thread tension :) First go back and make sure your bobbin tension is correct since you adjusted it. It should drop slightly when held suspended by danging it by the thread. If it reels out to the floor it is too loose. If it doesn't drop at all it is too tight.
Now that you have that adjusted look at your top tension. If it is loopy on the bottom side of the stitch the TOP tension is too loose. Increase the top tension.
Now take some scrap material and set machine to a wide zig zag, medium length stitch and sew a bit. Compare the top and the bottom sides of the stitch. They should look identical. Remember the TOP side effects the bottom and the BOTTOM tension effects the top side. Adjust accordingly until they look identical with no loose threads or loops and no puckering (puckering means it's too tight).
May 03, 2011 | Brother LX3125 Sewing Machine
My zig zag stitch is puckering fabric. I even went to the multiple zig zag, same problem. I decreased tension. What should I have double. Note: this was on single layer, along edge of fabric so I could...
Check the bobbin tension too. It could be too tight. Make sure you are using the right size needle for the material as well. Sheer, thin fabric needs a smaller needle, thicker material requires bigger needles. Bobbin tension is the typical problem as most think to adjust the top tension but don't check the bobbin tension.
Is your quilt peices cotton? Cotton shouldn't cause as much trouble sewing along the edge but don't use too long of a stitch length else it will seem to gather up. Puckering side to side however is a tension problem usually. With sheerer fabrics that cause a problem sometimes you can put thin paper underneath, sew through both and then pull the paper off after sewing. (thin like the iron on type interfacing type fabric but like paper).
Mar 25, 2011 | Janome Sewing Machines
Only does zig zag stitches, no straight stitches,
make sure the pattern selector is set for straight stitch first. If it is set correct then the machine may be "stuck" is zig zag mode. May need to be de greased and then re lubricated.
Jul 26, 2009 | Necchi Sewing Machines
The zag part of zig zag won't work
i believe your machine is skipping the stitch on the RIGHT side as you sew and this is normally a timing problem. Lower your needle about 1/16 inch and try it . It might work to finish your project but it will need to be serviced to have the timing corrected.
sewman7
Jul 28, 2008 | Necchi 3101 Mechanical Sewing Machine
Zig Zag Skip Stitch
your machine might have a problem with the rotary hook, it might need to get timed by a professional.
Oct 03, 2007 | Necchi 3537 Mechanical Sewing Machine
Necchi 6011 Logo
178 people viewed this question
Top Necchi Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Ellen Den Dulk
Ellen Den Dulk
Level 1 Expert
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
