Question about Palm Treo 650 Handheld
Battery indicator/charging defect
Hi, i've been using my treo 650 for over a year now and in the past couple of weeks my battery indicator and/or charging seems to bahave strangely. i used to be able to fully charge my battery in just about 2-4 hours. now, my treo is plugged in more than 24 hours and the battery still won't get full. the most i got was about 51%. what was more strage was when it was at that percent, the led indicator was solid green telling me that it's fully charged. i tried to unplug the charger from the phone and from the wall and try to hook it back in again. but after a few minutes, the led indicator became solid green again with only about 51% battery life! another strange thing is that whenever i plug in the charger to my phone it would take a while for the phone to start charging and when it did start to charge, after several seconds, the battery life would drop about 10%. that's all while the treo is plugged in and charging! and when i do a soft reset, the battery life would add back that 10%. also, whenever i plug in the charger, the keyboard backlight flickers. what i have tried: -i tried to replace the battery with a brand new one but it still did the same thing -i already did all the resets possible. soft reset, hard reset, battery reset, etc... -even deleted some programs but it still didn't work -i tried to contact palm tech support but they were no help at all what do you think it could be? please help and thank you in advance!
  • charles jett Feb 11, 2008
    i need some instructions on how to replace the battery in my palm treo 650 how do i access the battery?
We have seen the same thing. It appears to be a connection problem with the power connector. Our solution may be to trash the palm and get something that is mechanically reliable.
Posted on Aug 11, 2007
    Problem Solver:
  • 5 Answers
Do you have a Treo desktop charger/sync cradle where you can drop the battery into the charger?
Posted on Jun 15, 2007
5 Suggested Answers
  • 11 Answers
SOURCE: Palm Treo 650 charging port loose and will not charge
I had this on mine, it seems to be a wear and tear issue, mine has gone back to Palm for a paid repair as it is out of warranty:-(
Kevan
Posted on Nov 18, 2007
  • 537 Answers
SOURCE: Receiving MMS on Treo 650
This device should be compatible with MMS.
I found this thread which might help you set up MMS on your Treo 650. Look at the 2nd entry:
1. Start, Settings, Connections, and then tap the Connections Icon
2. Under "My Work Network" tap Add a New Modem Connection
3. Name it Picture Messaging and under Select a modem select (GPRS,3G)
4. Under Access Point Name type: wap.voicestream.com
5. Username, Password, and Domain is left blank and then click Finish
6. Now, go into Proxy Settings and check "This network connects to the Internet" and check "This network uses a proxy server to connect to the internet"
7. Under the Proxy Server box type: 216.155.165.050
8. Tap the advanced button and tap on the HTTP line. Make sure the HTTP settings shows 216.155.165.050:8080. If not, change it.
9. Click the OK button a few times to get out of the settings completely.
10.Now go to Start, Messaging, Menu, then Options, Advance, then Click Manual, and then the Edit button
11. Message center number +12063130004
12. Email center number is 500
13. MMS gateway address is 216.155.165.050:8080
14. MMS URL is http://216.155.174.84/servlets/mms
15. Finally under Network Profile select: My Work Network and then click ok.
Posted on Dec 13, 2007
SOURCE: Palm Treo 650 Unlock Code.
do u have a unlock code for your treo 650?can u share me a code so that i can unlock my treo 650 here is my messenger and email account respetadong_pogi@yahoo.com i hope you can help me too.
Posted on Aug 16, 2008
  • 228 Answers
SOURCE: Is there a way I can revert my Palm Treo 650 back
Factory Reset for Treo 700p and 680 smartphones
If you've set a password on your smartphone, any hard reset will automatically become a Factory Reset. With this method, you'll enter a password and then perform a hard reset.
On your smartphone, launch the Security application.
2.If the Password box says "Unassigned," tap the box and create a password for your smartphone.
3.Once the password has been set, disconnect your smartphone from the AC charger and take off the battery cover. Do not remove the battery yet.
4.Hold down Power/End .
5.While holding down Power/End , remove the battery. Then insert it again.
6.While still holding Power/End , the screen will show the Palm logo and a progress bar. Then the circular Palm Powered logo will appear. Release the power button when you see the Palm Powered logo.
Keep holding the Power button during this screen. When you see this screen, you can release the Power button.
7.A message will appear warning that you are about to erase all the data stored on your smartphone. Press UP.
8.If you performed this reset correctly, the screen will go blank after several minutes, and you will not be able to turn on your device. The charging LED will not light up. (any other activity - such as the Palm OS logo and then the Applications launcher appearing - means the reset was performed incorrectly; try again) 9.Your device will appear "dead." To wake up your smartphone, perform a soft reset.
if u like plz comment
Posted on Mar 11, 2010
WHEN I CHARGE MY TREO 650 THE RED LIGHT AND CHARG...
Charging circuit cause trouble due to heat, please see a technician or first use "restore factory settings"
Regards
Marshal
Dhaka, Bangladesh
bdman2010@hotmail.com
May 20, 2010 | Palm Treo 650 Handheld
Battery does not charge.
hi dear
try this
BACK UP your Treo 650 software and data BEFORE doing the following.
1. RESET the Treo 650 back to default set by holding power buttom following by reset the treo.
2. There is a way to reset the voltage regulator in the Treo ; believe is by holding the RESET for > 3 seconds. Believe need to take out the battery in out during this process. Can't recalled the correct steps. This could could reset the Treo's power regulator.
3. TRY reinstall your palm software with minimun software or 3rd parties one, this software could be running in the back ground which drain the battery.
Try above steps might help.
Mine also got the same problem last two weeks, my treo could felt there is kind warm sensation if it took out from my waist pouch after leaving it for sometime on the table. BTW, the battery could felt quite warm also.
If yours also behave the same which I believed the Treo got some kind of contact problem which draw more power then usually does.
Now, mine got no more warm sensetion after carry out above steps. It gets better as Compared to last two weeks ago BUT not that good as compared previously when it can last 3~4 days after a full charge.
oke
or just try to use
http://mytreo.net/archives/2005/09/charge-your-treo-650-spare-battery-with-seidios-innocharger.html
oke
cropp
Mar 26, 2008 | Palm Treo 650 Handheld
Help please
hi dear
Good luck
Mar 17, 2008 | Palm Treo 650 Handheld
My palm treo 680 turns itself off repeatedly
hi dear
Good luck
Mar 15, 2008 | Palm Treo 650 Handheld
Buttons not working properly
hi dear
Good luck
Resetting to Power Off
hi dear
Good luck
cropp
Mar 07, 2008 | Palm Treo 650 Handheld
Outlook Calendar synchronization failed in palm treo 650
hi dear
Good luck
cropp
Feb 24, 2008 | Palm Treo 650 Handheld
Treo 650 cell phone
buy new battery nimh in ther sit so long loses full charge cant get back .
Feb 05, 2008 | Palm Treo 650 Handheld
Palm treo 650
Hi Sandra Bunch,
Could you inform us which treo do you use? If you use Treo 650 or newer, than you could buy desktop charger beside ordinary palm charger. But if you use Treo 600 there's no alternative than buy the ordinary palm charger. It's easy to get this accessories on the net, you could try MyTreo.net or TreoCentral.com
Nov 10, 2007 | Palm Treo 650 Handheld
Palm Treo 650 Handheld Logo
117 people viewed this question
Top Palm Computers & Internet Experts
Marvin
Marvin
JC Meredith
JC Meredith
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
