Question about Refrigerators
Salton cf-2001 will not cool
Power goes into main board but not out to fan,cooling control etc,
    Genius:
  • 2,920 Answers
You need to oder a new main board as the power isnt getting past the one that there
Posted on Jan 14, 2009
2001 Saturn L300 300 v6 10 amp fuse blows diagram says controls ignition 1 gas pedal won't do anything when that happens put in new few can drive a few miles blows again
Is this the one ?
CONTROLS IGN 1
Red (10)
Powertrain Control Module/Cooling Fan Control Module/Automatic Transaxle
The wiring or one of these listed above has a short . Disconnect the cooling fan control module and see if the problem goes away , if it does you need a new cooling fan control module . Do you know where it is ?
Jan 24, 2017 | 2001 Saturn L-Series
Control board clicks every 3 sec. No cooling. No fan or compressor running.
Avanb, I can almost assure you that the control board is the problem. I'm assuming that the interior lights are on, but no fans and the compressor is not running. To make sure, first unplug the temperature control harness. (encoder). If the refrigerator starts running, replace the temperature control board (encoder board. If it doesn't start running, replace the main board in back. To remove the control panel, remove the 2 screws located on the bottom. Slide the panel down. Then just disconnect the harness to the temperature control. Catriver.
Aug 03, 2007 | Hotpoint HSS25GFP Side by Side...
Stopped during self clean--already replaced thermal fuse---it appears cooling fan was never connected, and it does not work once connected. All other functions appear to work, except power to the fan
Is the control panel completely dead?? If the cooling fan under the cooktop was not working, in most cases the main control board or control transformer if it is separate will get heat damaged and need replaced. That cooling fan is there to keep everything from over heating mainly during clean but should come on during normal baking if it gets too hot under the cooktop.
Apr 30, 2015 | KitchenAid KESS908SPS Electric Kitchen...
I have a Frigidaire gallery refrigerator with a error code 5y cf I put in new ice maker and a new control board still have same code anybody got any sugstions plase
hello jon;
my name is peter. i am a retired field service refrigeration technician.
cf= cooling fan. is your freezer fan running? is the back wall of your freezer section iced up? is your fresh food section cold?
send me your model number. it is on a label, on the inside wall of your fresh food section near the top.
Jan 21, 2015 | Frigidaire Refrigerators
Replaced main board but still no cooling. now what? the power board?
Compressors cool the fridge, the main controller does all the electrical commands, i'd check if the compressor is cutting in if it does then there is a gas or fan problem.
Nov 29, 2013 | LG LFC23760ST Side by Side Bottom Freezer...
My frigidaire is displaying SY CF
Hello Angela Clark - Typically error code SY CF indicates that the refrigerator has detected a communication failure after power up. Contact a professional to move forward accurately. The wiring between the main control board and user interface board will need to be check and diagnose. Depending on the diagnoses the main control board may need replacing.
Dec 05, 2012 | Frigidaire FGHB2844L
Cooling fan does not run?
At the main fuse and relay box, check the 30A EGI INJ fuse. If OK, the main relay closes to apply power to the cooling fan relay. Next, check the 30A FAN 1 and FAN 2 fuses.If OK, power is being applied to the fan control module. The PCM processes engine coolant temperature sensor input and sends a signal to the fan control module which, in turn, causes the cooling fan motor to operate. Fan failure could be caused by malfunction of the cooling fan relay, the fan control module, the engine coolant temperature sensor, the cooling fan motor itself, or the PCM
Oct 06, 2012 | 2005 Mazda MPV
Salton small counter fridge model CF-2019. stop cooling, fan still works .
If it's an absorption fridge it has no "freon" but an ammonia mix. The usual cause of no cooling is the heater element blown.
Apr 24, 2012 | Refrigerators
My GE PFS22MISBWW stopped cooling suddenly. Lights & power work; sound of light fan but no cooling. Please advise
That main control is known for causing this issue, replace the board it will fix the issue friend
Apr 22, 2011 | GE Main Domestic Board WR55x10656
My Home Ac Unit Is Not Blowing Any Air
This sounds like the fan not turning during cool. You will have to check the fan relay for power during the cool cycle. The fan relay is run by the low voltage side, but still there is hi voltage present. When in heat the power goes thru the relay on one set of points then in cool goes thru the opposite side. You should have a digram present, and then on the main circuit board there is a code light. Check the light for blinking or (flash) read the bottom of the board for the code ( very small print)
May 17, 2010 | Goodman CKL24AR24 Air Conditioner
Refrigerators Logo
221 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
