Question about Brother MFC 420CN All-In-One InkJet Printer
Text is not readable
I can not print clear text. The 1st lines prints like it should but the rest of the page looks more 3 D.
I have tried turning the unit off waiting a few minutes the turning it back on.
  • i_giggle_alo Feb 07, 2009
    we tried this but this didn`t work and there didn`t seem to be any paper in the wheel
    thanks
  • 286 Answers
It sounds like an alignment issue. If the first line prints correctly, there could be something stuck in the print-head path (like a piece of paper) or the "encoder strip or wheel" could be dirty.
Unfortunately the unit would have to be opened and inspected.
Lift the lid and look under the top cover to the extreme left and right to make sure there is no loose piece of crumpled paper stuck inside.
If this doesn't produce any results, try printing out the alignment page. Press Ink, then test print, then alignment. Print the page. There should be two sets of patterns. Zero represents a perfect pattern. Enter the number beside the pattern that looks closest to zero. You can see a line to each side of each pattern. Always choose the pattern where the line looks like one line, and not like two. If all you can see is patterns with two lines beside them always choose the lines that are closest together. The machine will move your selection to position 5. Print out the test again and select the best pattern again. Keep doing this until the checkerboard effect disappears, and the two lines on each side of pattern 5 have become one line. You may have to do this 10-15 times IF the alignment has gotten really bad.
If this doesn't help, or if it gets worse the unit will have to be opened and the encoder strip and encoder wheel cleaned or replaced.
Posted on Jan 22, 2009
WILL ONLY PRINT EVERY ALTERNATE LINE OF TEXT & TEXT BOX BORDERS
Doesn't sound like your printer hardware. Try printing something other than your text document. If the page comes out clean/perfect then it means your printer is having a problem understanding your text document via print program translation. Otherwise try converting your text to pdf and print a sample page, if it works then again problem with software/printer translation.
Nov 24, 2013 | Epson Stylus CX3810 All-In-One InkJet...
I cant seem to print text. i can only print graphics. i recently put in new ink cartridges, tried to print a page of only text and the pages were blank. tried to print another page with text and graphics,...
Have you tried printing text in different colour if that works the black jets are blocked- try running the cleaning cycle to clear (it may not use black ink in graphics)
Nov 15, 2010 | Brother DCP 130C All-In-One InkJet Printer
Printer keeps skipping lines when printing. very annoying
is this a case of the dots are missing for a valid line, or do you mean a line feed is added at the end of a line, ie you get 3 lines of text occupying 4 lines of space , or 4 lines of text occupies 4 lines of space, but one line has no printed dots on it? to make it more obvious, what does a document with say text thats 3cm tall look like? as it sounds to me like contacts need cleaning.. *** note for info: do not rely on printouts from within a BROWSER as that may have unpredictable results. All text will be treated as a large block of PIXELS and Not TEXT. also Non Printer fonts could cause similar issues.
Nov 09, 2017 | HP Photosmart 2710 All-In-One InkJet...
Text is not printing clearly.
Change the photoorganic drum and the cleaning blade,if the cartridge is refill 2 or more time change the cartridge.
Sep 07, 2009 | Office Equipment & Supplies
HP Laserjet 1100, band of unprinted area after new toner install
Hi Friend,
You have mentioned this is a 2nd hand printer,
you have to service the printer,(fuser unit)
if the problem exists after fuser service check Laser Scanner also,
Thanks
Lux5
Nov 28, 2008 | HP LaserJet 1100 Printer
Not printing right
You need to run an inkjet printer maybe once a week or so, depending on the relative humidity of its location. You need to do a head clean, maybe change your cartridges - again.
Dec 22, 2007 | Lexmark X75 All-In-One InkJet Printer
I have blank lines through my printouts
Run the cleaning cycle. If that doesn't work, try to use an alcohol soaked swab on the print head. Some of the jets are clogged.
Oct 27, 2007 | Canon PIXMA MP130 All-In-One InkJet...
Brother MFC 420CN All-In-One InkJet Printer Logo
153 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
