Question about Intel D865PERL Motherboard
Replace my D865PERL Motherboard
I have to replace my motherboard with an up to date motherboard
  • 3,267 Answers
I really dont know why u need to replace ur MB? Was it giving problems, like overheating? or u want better processor therefore u have to have a MB compatible for that processor, then you'll have to. Otherwise kindly clarify the nature of ur problem..........sodeep
Posted on Mar 28, 2009
Remove fan d865perl
It depends. You usually must replace the entire heatsink/fan assembly. If you have the standard 'Intel' heatsink/fan that came with a retail boxed Intel processor, you flip the levers in opposite directions to loosen the assembly, and then you slip a thin piece of metal under each of the four hooks that attach it to the mobo, but you do them one at a time. You just pry a little bit and lift up on each one. After the last hook is freed, you pull the unit completely off the board.
There's also a power connector. Don't forget to unplug it. There are at least 100 different styles of HSF for that mobo. You also want to twist a little to work the thermal-transfer compound loose. Otherwise you might pull the processor out with the HSF.
Jul 05, 2012 | Intel Desktop Board D865PERL...
I have a D865perl MB some times for no reason my computer shuts down. It is a pain to restart, i have to turn it on and off atleast 20 times
That looks a hardisk failure.
Set the BiOS to "max. default operation", save upon exit. If you still got the same problem replace the HARDiSK.
Try to replace the hardisk and install your favorite OS.
Hope that helps!
Dec 02, 2011 | Intel D865PERL Motherboard
Have a Intell D865PERL getting either 6 or 7 beeps when booting, can't be sure which. System will not boot but just beep with PS2 keyboard installed but will boot with keyboard removed. BIOS is version...
It's likely a bad keyboard- try using either an usb keyboard or another ps2 keyboard- if it works and boots normally with a different keyboard, the issue was the bad keyboard. If not, then the ps2 port has gone bad. (you could still use usb)
Feb 01, 2011 | Intel D865PERL Motherboard
I need sound driver foxconn 1437a at biltin motherboard d865perl
Normal 0
You can download the motherboard drivers from Intel WEB site. Select your model motherboard/device, and make sure you select the Windows XP or Vista version of the drivers that matches your Windows operating system.
Please click on this link and select your model motherboard : -
http://downloadcenter.intel.com/default.aspx?iid=gg_support-au+home_downloadctr
Oct 10, 2010 | Intel D865PERL Motherboard
D865perl not boot
First test your CPU or replace it then tast all leads that are attached to your hard drive sounds like a faulty lead of some sorts then
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
good luck
Sep 02, 2010 | Intel Desktop Board D865PERL...
I have just purchased a second user motherboard MANUAL D865PERL - Skt 478 itel and i need a instlation and operation manual help
Here is the manual in pdf format:
D865PERL Manual
For reference, here is the main support page for your motherboard that has lots of other info and links:
D865PERL Support
Thanks for using Fixya.
Jun 17, 2009 | Intel Computers & Internet
Motherboard
Hi renjithr, the Intel D865PERL motherboard doe not use an integerated video (onboard). The D865PERL board uses an AGP add in card. AGP 8x & 4x 1.5v graphics card. If you are not receiving video, you can try removing the AGP card & clean the copper contacts by using alcohol on a cotton swab. (Allow contacts to dry). Use canned air & blow out the AGP slot. Re-seat the AGP card. If the card still does not show video than your AGP card is defective & you will need to replace it.
Click on the link below for a new AGP 8x-4x compatible video card. http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=321119&prodlist=celebros
This XFX GeForce will function in you're Intel system.
The XFX comes with a Lifetime warranty.
Have more questions, please feel free to ask.
Good Luck!
Mike
Apr 21, 2008 | Intel D865PERL Motherboard
D865 Perl with 80 gb sata plus 1024X2 400Mhz DDR Ram
-check your reset button if its not stucked. -else try resetting your CMOS settings to default. -try using your old memory sticks.
Sep 13, 2007 | Intel D865PERL Motherboard
Intel D865PERL Motherboard Logo
211 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
