Question about Canon PIXMA iP3000 InkJet Photo Printer
Streaks on photos
When I print photos on my Pixma IP 3000 I always get streaks.
  • Anonymous Dec 21, 2008
    Pretty much same problem but I have a an i550.
    Prints fine when printing on normal paper but when I try to print a picture I get yellow greenish verticle streaks. I have tried cleaning multiple (>5)times, no better no worse. Then I had to replace tanks still the same.
  • Anonymous Mar 16, 2014
    There is a streak on the right side of my photos. Is there a way to clean the printer head?
    Scholar:
  • 77 Answers
Sorry, but your cartridges are only tanks. The problem is in your printhead. First, call up the Canon utility - CLEAN your printhead 2 or 3 times. If that does not help, then replace the printhead. Ed
Posted on Jun 16, 2007
  • 186 Answers
Take out your ink cartridge and clean off the bottom of it with a damp cloth.
Need to print a mirror image on my ip 3000 model printer. Do you know how i can do this.
Irfanview is a *great* free (donations accepted and this program is very much worth supporting )graphics program that can do a lot to your images before printing. In your case you want to use horizontal flip to get a mirror image.
Feb 17, 2011 | Canon PIXMA iP3000 InkJet Photo Printer
Canon pixma ip 3000 error message printer is offline
If the orange lamp blinking only it's the print head is not installed, or it is not properly installed.Open the cover remove the print cartridges then remove the print head and put back it on.If not help the print head is defective and need replace.
If the orange lamp blinking with green alternately it's ASF (cam) sensor error.The problem is in sheet feed unit.
Oct 15, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Installed printer will not print
I found a vista driver for a Pixma ip 2600 and downloaded it. My printer now works but the black ink doesn't. Don't know if it's a driver issue or otherwise. It might be worth a try for you. There are no available vista drivers for the ip3000.
Aug 08, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
When I print photos, they have uniform vertical streaks.
Issue: Banded or streaked prints
Solution: Change the Print Quality Settings (Windows)
Change the Print Quality Settings (Windows) The Quality setting controls how finely ink droplets are placed on the printed page. Depending on the type of paper being used a higher Print Quality setting does not always insure a better print. Print speed will decrease as the Print Quality setting is increased. Follow the instructions below to change the print quality settings in the Canon printer driver for the Windows operating system through a printing application.
  1. Click 'Properties' in the Print dialog box.
    Note: Depending on the Application software, 'Properties' may be displayed as 'Preferences'.
  2. Set the desired print quality in the 'Print Quality' section.
  3. Select 'High', 'Standard', or 'Draft / Fast'.
To set more detailed print quality settings, follow this procedure:
  1. Select 'Custom' and click 'Set'.
  2. In the Set Print Quality dialog drag the slide bar from 'Fast' to 'Fine' to select the print quality.
    Note: There are five options in 'Quality'. However, selectable options are limited depending on the media type.
  3. Select 'Auto', 'Dither', or 'Diffusion' from the 'Halftoning' section.
Apr 22, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Pixma ip 3000
I think that if you use the bottom tray to load the paper, you can use the different sizes of paper to print. Make sure to click the second button inside the lid that shows the direction the paper is fed into the printer. hope this helps!
Jan 15, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Wide black streak on back of printed paper
it is not directly coming from the head. Probably you are printing your photos without borders. This means that the printer prints slightly beyond he paper. As a consequence is sprays ink on the mechanics and after a while it starts to smear on the back of the paper.
This phenomenon is even mentioned in the printer manual (kind of caution when selecting borderless printing).
There is a menu item in the printer utilities that lets you clean the printer mechanics with a folded paper. I tried this, but it helps only little.
I have the same effect on a pixma IP 4500 , and I live with it.
Cheers
Critter
Dec 29, 2008 | Canon PIXMA MP530 All-In-One InkJet...
5 flashes amber pixma ip3000 5 AMBER FLASHES PIXMA IP 3000
Try this link http://www.fixyourownprinter.com/forums/inkjet/27412
Stanr
Oct 02, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Canon Pixma Ip 5200
Dear all,
Hmm, it seem that some ink incidentally dropped in the roller. You need to remove the cover and clean it manually with a clothe. If you cannot do this just take your printer to the nearest service center.
Regards,
Source:
Canon Inkjet Printer Forum
Sep 20, 2008 | Canon PIXMA IP5200 InkJet Photo Printer
Problem with the color - Canon Pixma ip 3000 Ink Jet printer
go 2 printing preferances and make shore all your setting are on normal or higher and try again
Nov 28, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
Canon PIXMA iP3000 InkJet Photo Printer Logo
165 people viewed this question
Clive
Clive
old marine
old marine
