Question about Brother HL 2140 Laser Printer
DO YOU KNOW QHERE IS THE RESET BOTTON IN THIS HL-2140 PRINTER?
  • 258 Answers
There is no reset button,
so I would suggest using the power switch, on/off
Posted on Jan 14, 2009
Tip
Resetting Blinking Toner Light HL-2140
Here is the procedure for resetting the Toner flashing light on Brother HL-2140 (sources for other answers here and self testing - specific to HL-2140)
  • Open the front cover and leave open.
  • Turn the printer off.
  • Hold the "white button" while turning the printer on. (All panel lights should be on.)
  • Release the "white button".
  • Press the "white button" 2 times (Pause, wait for all lights to come on.)
  • Press the "white button" 5 times. (All lights to come on again, then go out.)
  • Cancel "maintenance driver" install, if prompted
  • Close cover.
  • Power cycle printer.
This will:
  • reset the toner light (stop blinking)
  • restore the printing darkness (when toner light flashes, printer prints lighter to save toner)
  • keeps the printed page counts and drum life info
on Mar 06, 2011 | Brother HL 2140 Laser Printer
I HAVE HL 2140 PRINTER. INSTALLED NEW TONER BUT NOT PRINTING GETTING WITH DRUM ERROR
It is possible that the drum needs replacing.
Print a lifetime status page, and see if it says "drum 0%". If so, replace the drum and RESET the counters by using the reset button combination.
Mar 14, 2011 | Brother HL 2140 Laser Printer
Where is the reset button on my Brother HL-2140 Laser Printer?
Describle your problem better : you need to reset Drum or Toner
Jan 28, 2011 | Brother HL 2140 Laser Printer
If im going to print my document the selection for printer HL - 2140 series 2 was lost and replace by the printer generic how can I reset the printer bask to HL - 2140 inorder to activate?
Brother HL - 2140 Drivers
Visit the above link from Brother Official Support. Select the Operating System and download the drivers. After in stalling the drivers, go to the Control Pannel - Printers, and set HL-2140 as default printer.
Hope it helps! Good Luck!
Don't forget to convey your feedback
CreativeTECH
Jan 24, 2011 | Office Equipment & Supplies
My hl-2140 still displays toner problem after i change it to new.
The cartridge reset gear most likely miss the switch in the printer and it didn't reset the printer, common enough. Look at the cartridge gear side in front of you, there is a big 'window on the right, is there a white or black "tab" in the window? (if not it can't reset the printer). Is the tab on the left side of the window (down)? If it is on the left you can open the cover and very carefully reset the tab to the right the up position.
Nov 23, 2010 | Brother HL 2140 Laser Printer
I recently installed the Brother HL-2140 to my computer, everything came through, but I am not able to print. Rose
Set your new HL-2140 as the default printer. Go to Control Panel, Click Printers and Scanners tab, and set your Brother HL-2140 as your default printer. You may have other printer as the default printer currently. Check your connections again. Connect it to another USB port as the current port might not be responding due to connection contact problem.
Oct 05, 2010 | Brother HL 2140 Laser Printer
How to fix hl 2140 drum ERRORS
You need to open the front cover of the machine and remove the cartridge (drum and toner) On the top right there is a tab that you need to slide from left to right about 20 times, then bring back to home position
Apr 14, 2010 | Brother HL 2140 Laser Printer
Brother HL-2140 Error light is flashing
Try to unplug the power from the print, wait 1 minute then plug back in.
This may remove the error.
Sep 26, 2009 | Brother HL 2140 Laser Printer
Reset botton in this HL-2140 PRINTER
There isn't a reset button, try power switch.
Jan 14, 2009 | Brother HL 2140 Laser Printer
Brother HL 2140 Laser Printer Logo
245 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
