Question about Maytag LSE7806A Top Load Stacked Washer/Dryer
Maytag LSE7804 stackable w/d blows fuse
My Maytag washing machine blows the fuse. I opened machine up! Inlet valve solenoids read about 750 ohms resistance across each coil.
What is the most like culprit?
  • 6 more comments
  • jschee Jan 14, 2009
    If the lid switch is defective is the problem most likely open? If so open won't cause fuse to blow. The inlet valve solenoids both test the same - but the second I pull the switch to on position it blows the 5A fuse.
    Washer will not fill - nada nothing happens. both fill solenoids test about 800 ohms resistance. First solution suggestion lid switch. Question is will lid switch cause blown fuse??? If open it won't fill but wouldn't cause blown fuse!
  • jschee Jan 15, 2009
    Still soliciting advice. The only way I see that inlet valves are causing problem is if they are mechanically stuck and that causes electrical overload. However, what do I know?? Anyone else wants to weigh in on this - I welcome the advice!!
    I still need some advice on the blowing fuse problem. The circuit only has inlet solenoids, lid switch,level switch & water temp sw and a couple of timer contacts. I replaced inlet valve even though I didn't really think it was the problem. IT wasn't! One of you said the problem was in lid switch! What do the rest of you think?? That doesn't seem to me to be something that would blow fuses!! But what do I know???
    In answer to your query, it is a 5 amp AGC internal fuse in the washing machine. Only a few other things in the path = fill valve solenoids, timer contacts, lid sw, check sw, temp sw, & level sw. I replaced fill valve - still blows fuses.
    After reading latest questions from you, I need to clarify. Problem is washer does nothing- won't fill. As soon as I pull the switch out to start wash cycle the 5 Amp AGC internal fuse blows.
  • jschee Jan 16, 2009
    I have checked lid switch and check switch with ohm meter. Both check good. I get continuity through temp sel sw, load sel sw & pressure switch when I am supposed to. I don't measure any shorts. WHAT GIVES????
  • jschee Jan 19, 2009
    Problem is fixed, albeit maybe temporarily. while ohming out path of inlet valves through lid switch, check switch, temp sel switch and level switch, problem disappeared and it's working fine now. Only thing I can think of is a chafed wire! Oh well! Thank you folks, Jim
  • Maytag Master
  • 19,396 Answers
Let us know if you fixed , if not , test and eventually replace wiring harness, that is the last thing remaining.
You find parts and diagrams by entering model number here.
Posted on Jan 23, 2009
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, almost always, there is a tech sheet with electrical wiring diagram at the bottom/kick panel. Possibilities are:
  • detached connector touching the body (most likely) or burned wires/connectors in the terminal block;
  • crimped, bared, stripped wired touching the body (likely)
  • shorted diode(s) in the control board (least likely).
Check and perform preliminary visual or necessary inspection. Pls post back result(s). Good luck and Thank you for using FixYa.
Posted on Jan 16, 2009
    Sergeant:
    Champion:
  • 435 Answers
The only component which can consume more than 5A to blow fuse could be the defetive motor in it. Else, it has to be a short circuit. You need to trace the circuit from the fuse to find the culprit.
    Master:
  • 413 Answers
You have a short. Look for any wires that have been rubbing against any metal components. The most vulnerable place would probably be where the power cord enters the machine. If all the wire look good check the outlet providing the power.
Posted on Jan 15, 2009
    Brigadier General:
  • 8,619 Answers
Hi!
What was the voltage at the out let? To test go from line to the ground the round hole in the outlet see what the voltage is then go from netural to ground see what it is do you know how to do a voltage drop test using a multimeter if you have one
Posted on Jan 14, 2009
  • Rylee Smith
    Rylee Smith Jan 14, 2009
    the machine is pulling to much power.check to see if it is on a 15 or 20 amp outlet. you said you replaced the fuse. the amp size should be on it. if it is a 15 amp fuse,plug the machine into a 20 amp circuit and see if the fuse blows then.
  • Rylee Smith
    Or you have plugged something else into a receptacle that it is sharing with on the same circuit such as a ac, freezer, refridgerator etc, and when it's motor kicks in it overloads it and throws the breaker..or as mentioned above, the washer is pulling more amps than what your fuse/breaker allows.
    And if all this doesn't help then there must be a fault in part of the cycle when it starts to spin(or when it starts to heat) something causes your motor coils to short that blows your switch.
    Ask for any clarifications.
    Sergeant:
    Novelist:
  • 326 Answers
    Sergeant:
  • 221 Answers
No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped?
Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.
Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
My stackable unit quit filling with water. It still spins and drains. I have cleaned the screens out for the water hoses. I have unplugged it for a few. What else can I do to fix my washer?
Use a meter to test the water valve solenoid coils, make sure nobody turned the supply hoses off without you knowing. Did you recently replace the fill hoses or have work done on the machine? Maytag Washer Dryer Combo Water Inlet Valve WP22001274
Jul 29, 2016 | Maytag LSE7806A Top Load Stacked...
My wjre55502kww ge washer will not fill.
You will need to replace the water inlet valve. Here is the part you need.
Oct 15, 2012 | Washing Machines
Kenmore HE2plus not getting cold water. Tap on and water in hose, washer just will not wash with cold water.
Hello, Your unit is not getting cold water most likely due to the water inlet valve. There are two to three screws located on the rear top that secure the cover to the unit. If you unscrew these screws and then slide the top panel towards the rear of the machine and remove the top cover off the unit this would give you access to the water inlet valve. Assure also that there is no debris where the hose connects into the back of the water inlet valve on the cold side. Sometimes calcified water can leave deposits in the valve preventing water from flowing into the machine. Here is a video of how to test a water inlet valve in a top load washer the test is very much the same the units are different though click this link http://www.youtube.com/watch?v=2Zc6NCTAF1U if you have any further questions message me back and please remember when our chat has fully concluded to rank how this opinion has helped in your appliance situation it allows me to continue helping others in similar situations. Thanks
Rick
Sep 08, 2011 | Kenmore HE2 Plus Front Load Washer
I have a Maytag lsg7804aae stackable unit. The problem I am having is that the washer will not agitate or fill with water, however the unit will work on the spin cycle in all modes. Opened front panel of...
timer is good, if you tried it on all the different cycles, must be the water inlet valve, does the hot water work, if you set to warm or hot..if so the cold water valve is shot
Dec 19, 2010 | Maytag LSE7806A Top Load Stacked...
My washer continually blows a fuse
If your machine is the Maytag stacked washer/dryer combo, there are a couple of areas I would look at. The first is the lid switch assembly. The fuse is a safety device designed to blow if the lid switch malfunctions. The two lid switches interact and if they don't both switch at the same time it can blow the fuse.
The second thing to try is to wash a load on cold water only and see if the fuse blows. See if there is a water supply issue. Check the water inlet valve. Remove the water supply hoses and check the small screens in the water inlet valve. Make sure they are clean and clear of rust or debris. Use a mulitmeter or ohmmeter to check the solenoids for continuity. A lack of continuity would indicate a faulty solenoid and the water inlet valve assembly will need replaced. These are a couple of things to consider. Hope this helped and best wishes.
Aug 15, 2009 | Maytag LSE7806A Top Load Stacked...
Maytag performa PAV2200 - cold water fill does not work, but hot does
Check the solenoids at the water inlet valve. They can be checked using a multimeter or ohm meter for continuity. If either solenoid has none, it is defective and the water inlet valve assy will need to be replaced. I am attaching a photo for reference. Hope this helped and best wishes.
Aug 04, 2009 | Maytag Performa PAV2200
Machine will fill but not complete any cycle. suspect timer
If the washer will fill on all cycles except rinse, it indicates a cold water supply problem. (Cold water is what is used in the rinse cycle). This normally would be caused by a faulty solenoid on the water inlet valve. Here is a picture. The solenoid can be checked with an ohm meter or multimeter. If the solenoid reads zero ohms, it is stuck open and the inlet valve must be replaced. Hope this helped and best wishes.
Jul 28, 2009 | Kenmore HE3T Washer
Kenmore top load washer-- water will not turn off even after machine is turned off. Please help
It sounds like faulty water inlet valve solenoid, Replace water inlet solenoid valve assembly. Check them for continuity. If the meter reads zero ohms, the solenoid is open and must be replaced. Hope this helped and best wishes.
Jul 28, 2009 | Washing Machines
Maytag LSE7806A Top Load Stacked Washer/Dryer Logo
99 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
