Question about RCA MM52110 52" Rear Projection HDTV-Ready Television
FL231 Fuse Post
My TV seems to suffer from the fuse description you posted. The only diff. with my set is it will play for about 15 min just fine before the screen goes wacky. Mine is an RCA MM52100 in the main menu under SCREEN, ADJUST PROJECTION TV, there is three convergence options AUTO, RED, BLUE.
Do you still think I have this problem, and if so why will it play for 15 min?
  • 1 more comment
  • Carter Bennett Jan 15, 2009
    I'm sorry for the description(wacky). It is just as you described in the Fl231 post. Double image/color bleed (like a 3D movie without the glasses), with the screen bowing down on the top and up from the bottom. The only difference is it plays fine for about 15 min. first then like a light switch boom 3D screen with bowing. Power it down for 20 to 30 min and then fine for 15 min.
    I hope this helps, I used to repair NCR cash regs so I'm not spooked by it, just not sure what to do next.
    Thank you for the reply.
  • Carter Bennett May 24, 2009
    You were right about it being a heat problem. I took the lower back
    panel off and laid a small 10 in by 10 in box fan blowing down on the
    components, and the TV has never messed up again. I know this is not a
    factory fix, but it works. For a TV that could not run 15 min. without
    going wacky, now it runs for 8 to 18 hours a day and never skips a
    beat.
    beat.
    Genius:
  • 1,030 Answers
The fl231 problem is unique to the rca itc222 chasis the model mm52100 is not this chasis. wackey? describe the picture. You may have a solder problem or a compnent overheating.
Posted on Jan 15, 2009
RCA TV Model No. MM52110. Green light comes on, however TV does not. (No audio or video signal) Using remote button when pressed only a click, click sounds is heard. Can't find fuse location. Removed back and cleaned out dust. Same results occured.
Posted on Oct 21, 2009
Does the rca 52950 have the fl231 fuse? If so where is it located? If not which fuse controls the convergence. I fixed my newer model tv with the fl231 fuse but I dont see it in this tv.
no the fl231 fuse is only for model itc222 rca's . these older set unfortunately do not have that fuse convergence is contolled by a sepreated cuircit board. also these set have no stk ics that are common for most set that control convergence. it uses a series off transistors.
Jan 03, 2011 | RCA P52950 52" Rear Projection Television
No picture, sounds fine. Fuse blown
This set, I am sorry to say has no bulb and has no ballast circuit. There are three picture tubes inside this TV set. What exactly was the part you pulled out? Can you post a picture of the Part you pulled out?
Jul 29, 2007 | Toshiba 46H84 46" Rear Projection...
RCA mm52100
Ok thanks for the info Now this is an indication of convergence issues(3d effect) the bowing issue idicates a complete loss of convergence power. which possible could be the convergence ic or the actual power feeding them. im feeling like it might be the ic overheating these get very hot. now the bad news. this is a set that is very difficult to work on. Rca has compiled a long list of problems with this set. getting to the chips is a chore. i cannot recommend repairing this set. I know no one likes to hear this.
there are several rca issued suggestions. the top one isChange C19542 on the Digital Convergence PCB from a 10uF 63WVDC capacitor (214698) to a
470uF, 25WVDC capacitor part number 214746.
Also change the 24V zener diode CR19720 (226446) on the Convergence Power Supply board to a
30V 500 milliwatt zener diode, part number 231211 this
but as i said this may or may not be the best solution
Jan 15, 2009 | RCA MM52110 52" Rear Projection HDTV-Ready...
Hd52w59 convergence fuse
you jumperd the fl231 fuse? did you resolder the flyback connections. if these are not resolder the oscillation can still cause probklems
Nov 27, 2008 | RCA HD52W59 HDTV Projection Television
RCA R56WH78 picture quality is blurry/3D
rubber cap? i dont feel you have the correct fuse. fl231 is a small rectangular brown fuse next to flyback. I have written detail instructions on the replacement of this fuse. look under willtab profile under tips in tricks section. intitles the fl231 fuse problem. this also help you indetify if this is the problem.
Nov 22, 2008 | Televison & Video
Fl231
you can get the replacement fuse FL231 which is a 400ma 125v micro fuse at the following link under the RCA parts category.
http://servicemanuals.vstore.ca/
Sep 05, 2008 | RCA HD52W59 HDTV Projection Television
Fl231 fuse compatibility
yes, thats the replacement fuse for your set. However unless you have replaced the convergence power supply also chances are the fuse will blow again, as the power supply shorting is what causes the convergence to get out of alignment and it will then blow FL231 thereby removing the convergence option from the menu.
Sep 02, 2008 | RCA HD52W59 HDTV Projection Television
Double print and curve screen
this is an indication of convergence problem. from your description the curved screen indicates complete loss of covergence. First question is in setup menu do you have the convergence option? if no then it will be the fl231 fuse problem. common to these set and if you can solder. its not a difficult repair. if you do have the option. then it can be any or all of three cuircit boards. let me know and i will do my best to see if i can help you fix it
Aug 31, 2008 | RCA HD52W58 52" TV
Convergence menu not available on my RCA HDTV. Model R52WH74YX58
So the set is completley without convergence? bowed and the 3d effect.]
There is a small brown rectangular fuse fl231> it is common for this to blow due to poor solder conections on what is known as the flyback. IF this is your problem then it not a difficult repair. i do them all the time at the shop in about 15 min. Getting the fuse is the most difficult thing.
Mar 03, 2008 | RCA R52WM24 52" HDTV Projection Television
RCA 52w59 projection fuse fl231
Instead of taking the board out, I just soldered two wires to the old fl231 fuse on the underside. Installed a fuse holder with a half amp fuse. And I re-soldered all of the flyback points. My tv is working like new. thanks for everyone's help.
Dec 28, 2007 | RCA HD52W59 HDTV Projection Television
RCA MM52110 52" Rear Projection HDTV-Ready Television Logo
296 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
