Question about Tecmo Inc. Super Swing Golf for Nintendo Wii
Players Can not get the data input to activate more than one player. When I first started using it I could put in player names etc and cannot do that now.
I have not fixed the problem and even if I had you would need to pay me for the it just as you require for advice.
You sold the game I got it with a manual that has no english and you want to charge me for support.
If you can't service your product then I will be sure not to own it.
Thanks for nothing!
Posted on Jan 15, 2009
Where do i enter my activate code link at
When you first start the unit it will ask you to input the code in a box that appears if you are not seeing that box, you need to reset the unit using the reset button on the back/bottom of the Roku unit.
Sep 19, 2016 | Roku Streaming Stick
Cinemanow activation code
  1. Set up the Blu-Ray player and connect it to the Internet with a wired or wireless connection.
  2. Check for, accept, and update the device's software if prompted. Instructions to do this should be found in the device's manual.
  3. Activate your Blu-Ray player on the CinemaNow website. Do this on the Internet from your computer.
    • Create an account.
    • Connect your Blu-Ray player to your account. There are two ways that this can be done.
a) Input the PIN number provided during the signup and activation process.
b) Input the PIN number provided on the application on your device, and then input the activation code into your device using the remote.
4. Select a movie and enjoy.
Create an account.
Jul 20, 2014 | Samsung Televison & Video
How to configure Mitsubishi tv to setup Sony blu ray player
The set should in owner manual have detailed instructions with diagrams etc.
Basic is from player outputs (whichever it uses) HDMI, component etc OUT to the same on the set(usually into a rear input) IN, select that input on the TV and if player good you should have a working system.
When you want to go to use the player select that input (most Mitsubishi sets will allow you to change from input # and label that input DVD etc--that's in the TV setup menu most of the time.
The more things you have connected to the set the more complex it can get.
Dec 21, 2012 | Televison & Video
Hi Guys, Once I was wrongly fornatting my YP-T10 and all the pictures, music etc were gone. Can it be recover? Thanks for any help!
Connect your Media Player into computer.Download a data recovery software to recover your pictures and music.For data recovery program,I have used Tenorshare Data Recovery.It can recover data after deeply scanning your media player to look for lost data you accidentally deleted or formatted. By the way,you can download it and scan your media player for free to preview whether your pictures and music etc. can be recovered.Get it from http://www.any-data-recovery.com/product/datarecoverystandard.htm
Jul 27, 2011 | Samsung YP-T10 Digital Media Player
How do I find out how to put the tv on the right input on an older model phillips tv
Look on the back of the tv, the sockets that various leads are plugged into will have names next to them e.g. SCART-1 or AV - IN or RF IN. Make a note of which socket is used by your DVD player, VHS etc. with the TV on, switch on the device you want to use, let's say you want to watch a DVD. Some DVD players send a signal to the TV and the TV will automatically switch to the correct channel. If not you will have to select the channel manually. On the remote for the TV, look for a button marked "AV", "AV IN", "INPUT" or "SOURCE" press this button and you will either see a list of possible inputs, in which case, choose the correct one for your DVD player - e.g. SCART-1. If you don't see a list, the screen should flicker, go black, blue or straight to the DVD player. Keep pressing the button until you get to the desired input channel. To go back to normal tv, press TV on the remote or you may need to press the input button a few more times - depending on your tv.
Apr 05, 2011 | Televison & Video
I have a hanns.g hw191d monitor which has vga and dvi, how do i switch between the two
Generally speaking this monitor will start up in "auto" mode which will detect which in put has a signal and select that input. If you have both cables connected and active, hit the menu buton and scroll down to select the input.
Dan
Jan 27, 2011 | Audio Players & Recorders
I put a regular dvd into my blu ray player but it will not play. the player just says load and when I push the play button nothing happens. I'm using an hdmi cable and my 42 i.nch widesreen sharp tv is set...
Assuming it will play regular DVD's I'd suggest you connect it by scart also and set your TV input to scart.
I don't think DVD's carry High Def. data, that being the case, your player may auto route the data via scart.
Mar 31, 2010 | Samsung BD-P1600 Blu-ray Disc Player
The player only intermittently recognizes CDs inserted; it does not seem to make any difference whether they are commercial, recorded at home, etc. Sometimes it says "insert disk," sometimes "no disk." ...
A CD tray is usually powered by a rubber strap, the belt can slip through, causing the electronics to miss the input timing, including a microswitch or copper contact which is activated at the closed disc tray so that the laser is focussed to read the table of contents Due to the fact that the spindle motor is activated. And in some players (interchanges there is also a selects witch that can be contaminated. a suggestion to help in the link
How to Fix DVD or CD Player That Won Open
Jun 30, 2017 | Philips CDR950 CD Recorder
Da player shows da time symbol every tym
For a no-name player with no manual, I would try inserting the player into the computer, opening My Computer, right clicking on the drive letter or icon that corresponds to the no-name player, and selecting Format.
Of course, if I am wrong, this could end up rendering your mp3 player useless. It is your decision whether to take my advice for a no-name mp3 player.
-Tha Mp3 Doctor
Dec 26, 2008 | SanDisk Sansa e250 MP3 Player
Hooking up my dvd/vcr playing
The problem definitely lies in your connections. Make sure that the red is in red, white in white and yellow in yellow. If you have multiple sets of these to plug into on the back of your TV, then make sure that look at what that row is named (e.g. AV1, COMP 1, etc...).
Next, change the input on the TV (w/ the remote) to that name: AV1, COMP 1, etc...)
Mar 25, 2008 | Philips Magnavox DVD/VCR Dual Player
Tecmo Inc. Super Swing Golf for Nintendo Wii Logo
Top Tecmo Inc. Video Game Consoles & Games Experts
James Wishart
Are you a Tecmo Inc. Video Game Console and Game Expert? Answer questions, earn points and help others
