Question about Apple iPod nano
Everything is working except..
When I choos e asong and press play nothnig happens, it comes up onscreen as it should but the timer is not moving and the file is not playing. I checked all of teh settinsg as well as the earphones.. any suggestions?
  • 64 Answers
Reboot! Hold the menu button and the center button together until it reboots. This fixes just about everything other than a real hardware problem.
Posted on Jan 17, 2009
Perego Choo Choo will make noise, but won't move
the sounds are run off of a different battery source, check the battery under the seat and make sure that its connected
Apr 06, 2012 | Peg Perego Choo Choo Express Train Set
Hi. I have a IBM Wheelwriter 1500. Everything works except for the "e". When you press the button, nothing happens. the arm won't move or hit the paper.
If this happens in upper and lower case the keyboard is going bad if it only in one of the other the printwheel has a broken spoke and needs replacement.
DickyO
Mar 14, 2010 | IBM Office Equipment & Supplies
My ipod plays but no sound comes out
May be the settings is on headphones. Do this.Press Menu Go to settings and press Go to clicker and put it on 'both' by pressing the center.
Feb 09, 2010 | Apple iPod classic MP3 Player
Standby light is flashing 10 tims Model KV-HR36
Try unpluging your T.V. for 5hours+, then turn it back on. Worked for It's called a "hard reset" by sony.
Otherwise
Do the following steps
  1. Check the Sony remote for a button labeled "Sleep." This allows you to cycle through the sleep settings and determine how long you want the TV to remain on.
  2. Step 2 Press the "Sleep" button. You'll see a number come up onscreen: usually 15 or 90. When you press it again the number changes, moving up and down in increments of 15. This is the number of minutes the TV will remain on before it goes to sleep. As you cycle through it, you should see a setting with the words "Sleep Off" appear onscreen. If you leave it there, the sleep setting should cancel, allowing you to turn the set off when you like. If you miss it, just keep pushing the "Sleep" button. It will continue to cycle through the options until "Sleep Off" appears once again.
  3. Step 3 Access the timer function to shut off the timer by pressing the "Menu" button, then cycling through the onscreen options until you reach the "Applications" setting. Press it, and then cycle through to the "Clock/Timers" option.
  4. Step 4 Highlight the "Timer 1" setting and press the "+" button. If it's showing a given time, you'll need to deactivate it. Use the up and down arrows and move through the possible options until you come to the "Off" setting. Leave it there; that should shut the timer off.
  5. Step 5 Repeat the process with the "Timer 2" setting, a little further down the "Clock/Timers" menu. Set it to the "Off" position just as you did with the "Timer 1" setting.
  6. Step 6 Press the "Menu" button when you are done to exit the menu and return to the screen. You should be able to view the Sony TV as normal with no danger of it turning off.
good luck
Aug 08, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Technics cassette deck M260 w/o pressing any button keep working
Try rebending the plate back and restoring everything to proper condition/orientation and see what happens. Worth a shot.
Aug 28, 2017 | Sony TC WE435 Stereo Dual Cassette Deck...
Whirlpool gas model LGC8858EQ1 dryer works fine except the timer does not move.
ckd for wire from thermostat on rear of blower or high limit might be easier to look at wiring diagram wire is usually orange they have been known to come off voltage is feed to timer motor during auto setting from a thermostat
Jul 30, 2008 | Dryers
My samsung ht tx72 is working just fine besides this one MAJOR issue. the sound is coming out perfectly, except for when people onscreen are talking... this is consistant with the dvd player and when my...
You TV probably has a virtual surround sound setting in the menu to make movies sound like they are 3D, BUT when listening to a Football game, you can only hear the crowd. This was what happened to my parents big screen Toshiba tv.
Apr 25, 2008 | Televison & Video
RCA VR601AHF
I just had this same problem. I thought that the timer was stuck and was the reason why the VCR wouldn't play. I just moved and thought the unit got broken in the move. However, I think it was just not hooked up properly to the TV. I unplugged it, plugged it back in, and got it hooked up properly and it started working again (I tested the connection with a DVD player first). The flashing timer light went off as soon as I reset the clock. It seems odd that having it not hooked up properly should stop the VCR from playing, but that is what seemed to happen in my case. Hope this helps.
Aug 16, 2007 | RCA VR622HF VHS VCR
Apple iPod nano Logo
20 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Computer Repairing
Computer Repairing
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
