Question about AutoCommand Remote Car Starter Add-On
Remote start doesn't always work
I recently had an auto command remote start installed on my dodge stratus...not sure of the model number, but it also has unlock,lock and trunk pop as well as remote start feature. The lock, unlock and trunk pop work normally, but the remote start is somtimes problematic. It is almost like the reciever doesn't recieve the signal all the time. Sometimes I can push the button(requires 2x to remote start it) and it will start and sometimes i will push it 3 or 4 times and can't get it to work. Do you really have to push the button exactley right all the time for it to work? Is this normal to all of these systems? It seems like it should be more responsive than that. Can any one help me out
Thanks in advance
  • 15,935 Answers
It is that way because you wouldnt want the car starting when you have it it in your pocket or purse.
Sounds like the keypad contacts may need cleaning, or have been bent/broken/etc.
Have you tried another (backup) keyfob?
Please do this and report back.
If you are having problems, the installer should troubleshoot for you for free.
Posted on Jan 14, 2009
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
01 dodge stratus small red watery puddle after car warmed up
Under car puddle would possibly mean heater or radiator hose. Is the antifreeze in radiator red or green?
Jan 07, 2014 | 2001 Dodge Stratus
Hi Guru/Master, I have a 2006 Dodge Stratus SXT, 2.4L Engine. It has AIRBAG light on, and horn doesn't work. I guess it is the clock spring needs to be replaced. I couldn't find the part/model...
I don't believe this part is available aftermarket. I recently was looking for the same part on an 01, and could only find it at the dealer. It was right around 135 dollars. Have your vin number handy when you call them, they will probably ask you for it.
Aug 21, 2011 | 2006 Dodge Stratus
When should i change the tranny fluid & filter i my 03 dodge stratus auto transsmission the car has 100000 miles
I would always change Auto fluid & filter every 50,000 miles irrespective of what the manufacture states - it's cheaper than a new transmission!
Nov 13, 2010 | 2003 Dodge Stratus
My 2005 dodge stratus sedan just today, the engine
A fuel pressure test will tell you if the pump is performing as it should, the first step would be to scan the computer to see what the code or codes are. Has the vehicle had a tune up recently if ever?
Mar 17, 2010 | 2005 Dodge Stratus
I need to locate the cam sensor for dodge stratus 3.0 2004 model
Please tell us your NOT replacing a cam sensor because someone told you to get a code read at some auto parts store. This is like the flu spreading on this site. Codes DO NOT always mean a sensor is bad. Test it before you throw parts at it.
Feb 08, 2010 | 2004 Dodge Stratus
Motorola cable box/dvr/remote problem.
I have the same problem. Any solutions out there?
Dec 09, 2009 | Motorola Televison & Video
View of strut assembly of 2001 dodge stratus
My advice;
1.Check your local library in the Reference section, for an auto repair manual for your 2001 Dodge Stratus.
2.Purchase an auto repair manual from your nearest auto parts store.
3.Go to AutoZone.com, become a member, (Free), and view the Vehicle Repair Guide for your 2001 Dodge Stratus.
Sep 12, 2009 | 2001 Dodge Stratus
Remote start is intermittent working
the problem is your car is equiped with a passlock system you need a by pass mod. part number 555-L this is a dei part number this is the only company i use. it is a simple three wire hook up. if you got this far you will not have any trouble. one other thing to check is your ignition wirers make sure they have power when they are suposed to.if your still having problems or need more info on getting part let me know. i have alot of exp. with auto starts and keyless entry.
Jan 09, 2009 | AutoCommand Remote Start and Security with...
AutoCommand Remote Car Starter Add-On Logo
1,817 people viewed this question
Top Design Tech Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Design Tech Vehicle Part and Accessory Expert? Answer questions, earn points and help others
