Question about Brother MFC-9420CN All-In-One Laser Printer
NO OPC BELT on MFC-9420cn
I have a MFC-9420cn which had a print error.  After fixing it it said to replace the OPC belt.  I reset the opc belt and it then it said NO OPC Belt.  I have swapped it out with the opc belt from my HL-2700cn and the the 2700 works with the old 9420's opc belt but the 9420 again say no opc belt.
  • 15 Answers
The opc sensor is not sensing the belt. Open the front cover and remove all the toner trays. You will see the green OPC and the sensor is located in the left upper corner. Also open the top cover and remove the OPC. Clean the sensor with a soft bristle brush. Also make sure the OPC left side is free of toner deposits. This may incorrectly trigger the OPC position sensor. Hope this helps.
NO OPC BELT on MFC-9420cn - no-opc-belt-mfc-9420cn-grua3dqrdj4m0mpexfswu5ak-2-3.jpg
Posted on Nov 24, 2015
  • 81 Answers
SOURCE: MFC-9420CN All-In-One Laser Printer Install OPC belt message
Perhaps your OPC belt is at the end of its life and needs replacing
Posted on Aug 22, 2009
sir fixalot
  • 146 Answers
SOURCE: MFC-9420 Replace OPC Belt message stays on after replacing belt
As far as the OPC belt - don't replace it until you start seeing ghosts and image defects! Reset it by:
Press 1 and 7 at the same time
Press 1 to reset the life counter.
Posted on Jan 03, 2008
SOURCE: Hl 2700 cn 'no opc belt' error
You need to go into the settings and reset the counter once the new belt is in.
Posted on Oct 02, 2008
gremlin11
  • 78 Answers
SOURCE: what is opc belt 2700 CN printer
the opc belt is the optical photo conductor belt in your printer. It is the bright green shiney belt you see when you remove a cartridge. You can access it through the top of your unit. You will see a cover where the paper comes out. Inside there are two green clips that push outward. These release the opc belt.
You can purchase a replacement opc belt from most good stationary and consumable suppliers, however, be ready for a shock. the price of the opc belt is almost as much as the unit is worth.
Posted on Dec 13, 2008
eitan
  • 291 Answers
SOURCE: OPC belt sensor
try again
Posted on May 21, 2009
How do I reset the OPC belt on MFC-9420CN using the menu?
hl-2700" OPC Reset
press GO and "+" at same time
press "+" until OPC BELT appears
press "SET"
that will reset the counter on the expensive OPC.
Since the "MFC-9420CN" is build on the same chassis and engine, the "OPC belt reset for the 9420CN" is as follows:
Oct 20, 2010 | Brother MFC-9420CN All-In-One Laser...
I have a MFC-9420 CN that is giving me an "unable to print message" after I cleared a paper jam. I have turned it off and on several times, as that is the only help the user guide gives. I've read...
To reset on this machine you press the 3 and 9 together and scroll thru the options to reset. Unable to print without an error code doesn't tell me where your error might be.
Jan 28, 2010 | Brother MFC-9420CN All-In-One Laser...
OPC belt has 78% left -cant rid the problem
Look at the OPC belt edges, there's a shiny spot that passes thru a sensor, a can of air should blow out the sensor, carefully! When the sensor can't see the timing spot you get that error. You may have to replace the OPC since companies are imbedding a chip that tells the machine when they're used up.
Sep 01, 2009 | Brother MFC-9420CN All-In-One Laser...
OPC belt is replaced and has 100% life but the OPC
make sure all components are properly seated. also try turning the printer off and waiting a few minutes and turn back on.
Aug 19, 2009 | Brother MFC-9420CN All-In-One Laser...
Apr 07, 2009 | Brother MFC-9420CN All-In-One Laser...
OPC Belt needs replacing
Try pressing 1 and 7 at the same time
The LCD will show "OPC belt 1. Reset 2. Exit
Select 1 to reset the life counter.
This is supposed to be done when replacing the drum unit...but I've found that I can get 1.5 to 2 lifespans from a single unit.
Jan 31, 2009 | Brother MFC-9420CN All-In-One Laser...
Brother MF 9420CN is asking for troubleshooting and routine maintenance 'unable to print'
Via the control panel (This is a Factory Reset)
  1. Make sure the machine is not operating, then disconnect all the cables from the machine (except power cable).
  2. Press the Menu or Menu/Set key on the control panel.
  3. Press up or down navigation key to select LAN and press Set or Menu/Set.
  4. Press up or down navigation key to select Factory Reset and press Set or Menu/Set.
  5. Press 1 to select "Reset".
  6. Press 1 to select "Yes".
  7. The machine will re-start, re-connect cables once this is complete.
Jan 21, 2008 | Brother MFC-9420CN All-In-One Laser...
MFC 9420CN
Jan 03, 2008 | Brother MFC-9420CN All-In-One Laser...
Dec 06, 2007 | Brother MFC-9420CN All-In-One Laser...
Brother MFC-9420CN All-In-One Laser Printer Logo
525 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
