Question about Kenmore Elite 45986 Front Load Washer
Kenmore Elite he3 washer door will not unlock after a FH error
I had the water off and then forgot to turn it on before starting the washer. The washer ran and then there was FH error, which I found out means no water. Now it won't cancel out or let me open the door. Can you help me?
  • 1 more comment
  • Anonymous Mar 02, 2009
    same problem. When I press Pause/cancel nothing happens. The motor is still running. I have unplugged it for two days and it still wont reset.
  • dhinagilbert May 05, 2009
    I do getting FH error.
    My washing machine model is KENMORE ELITE HE3t 110-42936
    Any idea how to fix this problem?
    It is a not going to spin?
  • Anonymous May 23, 2009
    IT WAS LIFESAVING!! THANK YOU!!!
    LOVE, DAVE
I had the same problem. The manual is useless and hitting the pase/reset button did nothing for me. The wife called the help line and they said they would be out on Monday at $75.00 to check it out. Oh, but the good part is that the $75.00 would go towards the part (if needed). If you forget to turn the water on, and the washer stops working, it seems that it should be smart enough to shut off and continue working when water is put back on.
Anyway, knowing that nothing was broken I decided to pull off the cover. Disconnect the power cord 1st. You ill need a "star" type screwdriver (its a 6 pointed tip). Probably a couple dollars at the local hardware dept. Take the 3 screws off located on the back/top of the cover. Slide the cove back & then pull it off. I then plugged the washer back in. Same humming noise & still locked. I pulled off the connector labeled "D P 21". It is located near the middle of the CPU box and it has 2 black wires coming out from it. You should have the humming noise stop. Wait a few minutes to see if the washer shuts down. If it does then the door will be unlocked. I then had the wife start a new cycle and all is well.
*Note: If you unplug D P 21 and after a few minutes it still doesn't shut off, try pressing the reset button twice and wait again.
Sears can now kiss my **** for wanting to charge me $75.00 for something that was never broken!
Posted on Mar 28, 2009
  • 1 more comment
  • Jarhead John Sep 16, 2011
    This solution worked! And was soooooo easy to do. Thanks Junk! And I'm with you on Sears. GE too! My model: Kenmore Elite 110.4596*
  • junkmail67 Sep 19, 2011
    No problem Jarhead!
  • Elite Training Nov 26, 2011
    It worked for us too! Sears can also kiss our a**! Thank you for the help!
I used Junkmail67's solution and it worked great! Thanks.
Posted on Apr 30, 2010
  • 66 Answers
Unplug for 30 min to reset. some times 2hr. It has a computer in it.thats like rebooting.
Posted on Jan 14, 2009
2 Suggested Answers
jsrock516
  • 5911 Answers
SOURCE: kenmore elite he3 flashing FH
The following link explains the "FH" error:
http://www.fixya.com/support/r615354-fh_error_code_whirlpool_duet_kenmore
This can be a rather tough one to figure out, even with the error code explanation. I would recommend unplugging the washer for AT LEAST 30 minutes first. This will reset the Central Control Unit (CCU). In many cases this is all that is required to correct momentary glitches with the unit. If the error code reappears, check your washer installation to rule out the easiest possiblities, first. This means checking to ensure you don't have a siphoning condition, checking your drain lines and checking to ensure your fill hoses aren't kinked or clogged. Read through the link thoroughly and let me know if you have questions. I hope this helps you.
Posted on Jan 09, 2009
Both the coupler and the lid switch have been replaced yet unless you lift and close the lid it won't engage the spin cycle
Search Results
    Why am I getting an FL error code on a Kenmore Calypso ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kenmore Calypso washer model 11022062100 and there is water in ... Why am I getting an FL error code on a Kenmore Calypso washing Machine?
    fl error code on calypso washer-need help!! - Home Forumsths.gardenweb.com > Home Forums > Laundry RoomJul 22, 2006 - An FL error code keeps flashing on my Calypso Washing Machine. I can't do laundry. Could someone please tell me what I need to do to ..."F dl" light come on - Kenmore Elite HE3 Washing Machinehttps://www.ifixit.com/.../Why+is+the+%22F+dl%22+light+come+o...iFixitThese are the errors for error code F/dL Door Lock Error Condition A Door Lock Error... The Kenmore Elite HE3 is a washing machine by Kenmore. ... On Amazon I was able to get the CCU (Kenmore CCU Central Control Unit .... and a dose of WD40 on those contacts should keep that from misbehaving in the future as well.Kenmore Elite Calypso FL error code - ApplianceBlog
Jan 27, 2016 | Washing Machines
FH appears
The FH error code on your Kenmore Elite washing machine is an indicator that there is a problem with incoming water. When there is little water coming into the machine, the FH code will appear and the washer will stop. There are a couple of common problems you can check while you are resetting the FH error code. You will need to remove the power supply to the washer to reset the code
Look for the "Pause/Cancel" button on the washer control panel. The button will be below the digital time clock and to the lower right of the wash cycle selector.
  • 2
    Press the "Pause/Cancel" button twice to cancel the wash cycle. Unplug the Kenmore Elite washer from the wall outlet.
  • 3
    Check for kinks in the water supply hose while the washer does not have power. Turn off the water supply spigots and remove the hoses from the back of the washer. Check the port screens at the hose connections for sediment buildup and clean as necessary.
  • 4
    Connect the water supply hoses back to the washer and turn on the water spigots. Plug the washer cord back into the wall outlet.
  • 5
    Select the wash cycle and press the "Start" button.
  • If the error code come back you will probably have to change the water inlet valves. No hard to do and you can fdo this yourself
  • Dec 14, 2010 | Whirlpool Washing Machines
    Kenmore Elite HE3 Error FH I forgot to turn the water hoses on when I started a load. The FH error sounded at 33 minutes of a 45 minute cycle. I can't reset the machine now. It is stuck. It is unplugged....
    according to kenmore, you should press the "pause/cancel" button twice and it should release it.  it may also have locked up the CCU, central control module and might need to be replaced.
    Aug 02, 2010 | Kenmore Elite 45986 Front Load Washer
    Kenmore h2 error code
    April 8 2002 DIV 26 SOURCE 110 KENMORE ELITE HE3 & HET WASHERS "ADD-A-GARMENT" INDICATOR LIGHT ON DOOR WON'T UNLOCK WHEN PAUSE/CANCEL BUTTON IS DEPRESSED.
    MODELS: See additional page for Kenmore model numbers
    COMPLAINT: Due to a Microcomputer Machine Control software error , the ADD-A-GARMENT feature becomes inoperative.
    CORRECTION: The Microcomputer Machine Control must be replaced with a service part that has been reprogrammed to prevent ADD-A-GARMENT feature loss.
    PARTS: Order electronic control listed on this service flash by model from Division 26 , Source 110 following normal ordering procedure.
    MERCHANDISE CODES: WASHER Service Flash - Model Nurnbers for: Kenmore Elite HE3 & HE3t Washers: "ADD-A-GARMENT" indicator light on door won't unlock when Pause/Cancel button is depressed. Kenmore models with serial Numbers beginning with CSL23 through CSM04 11042822200 11042824200 11042826200 11042832200 11042834200 11042836200 11042922200 11042924200 11042926200 11042932200 11042934200 11042936200 Electronic conrrol p/n 8181900 Electronic control p/n 8181899
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
    Jan 11, 2010 | Kenmore 46462 Front Load Washer
    I have a whirlpool ghw9100lw the light is flashing but it will not start
    Aug 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Getting an FH error code during the cycle count down
    The FH code indicates it is not detecting water fill at the flow meter. Since you say that the washer is filling okay, I would check the wiring between the flowmeter and the control board. A common cause of this problem on this machine is the wiring harness jiggling loose. Unplug and reseat the wiring harness and see if it clears up the problem. Also look for and clean out any corrosion build-up where the harness plugs in. Hope this helped and best wishes.
    Aug 05, 2009 | Kenmore Elite 45986 Front Load Washer
    Kenmore front load He3 washer: door wont unlock
    happened to me once - I just unplugged the machine - waited a minute and plugged it back - it - then used cancel button
    Feb 27, 2009 | Kenmore Elite 45986 Front Load Washer
    Kenmore elite he3 flashing FH
    Jan 09, 2009 | Kenmore 46462 Front Load Washer
    Kenmore HE3 will not hold water leaks into the pedestal
    run you fingers into the door boot and inspect for holes ,, that probably what it is ,,,,,,big tear
    Dec 30, 2008 | Kenmore Elite 45986 Front Load Washer
    Kenmore elite HE3 Error Code
    Here's a link that explains the "FH" error:
    If you have questions about the information I provided, or need further assistance in trying to determine the source of your problem, please post back and let me know. I hope this helps provide an answer for you.
    Jul 11, 2008 | Kenmore Elite 45986 Front Load Washer
    Kenmore Elite 45986 Front Load Washer Logo
    1,836 people viewed this question
    Ron Lankford
    Archaeology
    Archaeology
    2mikecurtis
