Question about Amana ARB2257CSR Bottom Freezer Refrigerator
Amana bottom freezer refrigerator
When I open the top refrigerator section, there is condensation on both the bottom of the plastic part of the door, as well as on the plastic bottom of the refrigerator itself. Is this from a bad door gasket?
    President:
  • 1,462 Answers
Could be the cause. check by putting a slip of paper between seal and cabinet and with door shut, check paper is gripped all round the door. if it is not, try warming the seal with a hairdryer in the faulty place and pulling the seal out gently. many of these seals are foamed in and impossible or v dificult to replace. check also that the hinges are not worn
Posted on Jun 18, 2007
Amana fridge abb2222few not cooling but freezer is working where is fan motor located for fridge section
its in the freezer near the top if its not cooling I would check ur air damper flow control, is it to far close or opened? check the cold control thermostat, the thermistors. and of course the fan itself, check door seals.
Mar 17, 2015 | Amana ABB2222FE (22.1 cu. ft.) Bottom...
Water on floor - french door refrigerator with freezer below
Yes the bottom compartment does have a drain opening but to see it you will need to remove the rear panel covering the evaporator inside the back wall of the freezer compartment. See item location number 11 on page 3 of the parts list. That will need to be removed so you can reach the drain inside the freezer compartment. The fresh food section also has a drain. Here is a=> AFF2534FEB4 Parts List and AFF2534FEB4 User Manual I am here to answer any questions you may have, Thanks Sea Breeze
Leaking Refrigerators
Jul 23, 2013 | Whirlpool Amana Refrigerator Water Filter...
Freezer door opens when fridge door closes
if you are worried that the freezer is empty....fill it with plastic bottles of water...remember tho,don't fill the bottles completely as frozen water expands.
Jul 20, 2010 | Amana ATB1832AR Top Freezer Refrigerator
Freezer is working but fridge is cool not cold
the damper door vent is not opening fully if at all between the refrige and freezer compartments,it can freeze up from condensation or if controlled by a motor the motor can be bad its behind a plastic grille
May 24, 2010 | Amana ABB1921DE Bottom Freezer...
Amana freezer is cold, fridge is not.
You will be able to hear it when you open the freezer door and hold the door switch in.It is located behind the rear panel inside the freezer. The fan should be running when the compressor is running. If it is running make sure the damper(vent) to the fridge side is not blocked by ice and that the damper door is open.
Oct 08, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Amana
if you have condensation 1- not enough air flow for circulation and 2- a bad seal around the door
Aug 23, 2009 | Amana ATF2136ARQ 33" Top Freezer...
Amana ARB2117BW - Bottom Freezer Door Won't Stay Sealed
This problem was posted in the wrong section. My model didn't have it's own, so its in ABB1927DE Bottom Freezer Refrigerator - perhaps you could create a section for it.
As it turns out, I looked more closely at the baskets inside. We had noticed that if the top basket was slid all the way forward when we closed the door that it would close better. So I looked to see if they or the slides were out of alignment. They seemed ok, but then I saw that the way the bottom basket was hanging didn't seem right - it was not quite nestled into it's retainer slot. I took the baskets out and turned the bottom one around. It fit perfectly into it's retainer slot. I then replaced the top one (it was already in correctly) and closed the door. It sealed correctly the first time. I tested it several times after that and it sealed tightly. Closing the top door did not make it unseal as it had done before.
Jan 23, 2009 | Amana ABB1927DE Bottom Freezer...
Amana BX22A2W - freezer works, fridge not cooling
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
Oct 29, 2008 | Amana ABB2227DE Bottom Freezer...
Make sure that is not hot air getting inside the ref.
close the door and take a look at the gasket
May 08, 2008 | Refrigerators
Open Questions:
Amana ARB2257CSR Bottom Freezer Refrigerator Logo
164 people viewed this question
Top Amana Refrigerators Experts
Sal De
Steve Allison
Steve Allison
Carmen Mikulic
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
