Question about HP Pavilion dv6000z Notebook
What do i do after reseating
I reseated what do i do now
  • DEKR
    DEKR May 11, 2010
    Please tell me what you were doing
  • Jay Patel
    Jay Patel May 11, 2010
    please explain in detail what was the problem and what you did to resolve.
  • 520 Answers
Whatever is is that youve reseated you now need to restart pc and see if cured
Posted on Jan 22, 2009
HP DesignJet Z6100 Series - Error "Printhead Replacement Incomplete Restart It"
Time for a new printer. These things are just not worth fixing any more, even many of the large office units are made to break and be scrapped.
Nov 26, 2014 | HP Designjet Z6100 InkJet Printer
4 beeps on start up but no screen
four beeps is ram I believe. Take everything off and see if it starts and then put stuff back one at a time and see what is causing the problem
Oct 01, 2013 | Dell XPS 200 PC Desktop
Dell m90 beeping codes
Dell BIOS Beep Codes: Beep Codes Possible Causes Corrective Action 1 - 2 No video card detected Reseat the video card 1 - 2 - 2 - 3 BIOS ROM checksum error 1 - 3 - 1 - 1 DRAM refresh error Reseat the memory modules 1 - 3 - 1 - 3 8742 Keyboard Controller error Reseat the keyboard connector 1 - 3 - 3 - 1 Memory defective or not present Reseat the memory modules 1 - 3 - 4 - 1 RAM failure on line xxx Reseat the memory modules 1 - 3 - 4 - 3 RAM failure on data bits xxx of low byte on memory bus Reseat the memory modules 1 - 4 - 1 - 1 RAM failure on data bits xxx of high byte on memory bus Reseat the memory modules
Mar 03, 2013 | Dell Computers & Internet
Computer beeps 5 times and repeats the same 5 beeps continueously
5 beeps notes a memory error. Here are the possible solutions:
1.) Take the computer to a local repair shop and have the test/replace/reinstall the memory
2.) You can open the case and reseat the memory. You would want to follow proper procedures including unplugging the computer and following anti-static procedures by grounding yourself against the metal case.
3.) Reseating the memory means popping the latches loose and reconnecting (reseating) the RAM. This link has more details on the procedure.
4.) If reseating the memory does not fix the issue, you will want to replace the RAM.
Jan 11, 2011 | HP Compaq dc5100 PC Desktop
Re: Reseat Keyboard
here the link how you can reseat the keyboard for this Dell Inspiron 6400 Click Here
Jul 28, 2010 | Dell Inspiron 6400 Notebook
High pitched beeping sound?
hi!
I'm not sure with your beep code.. but here is the list of known beep codes for dell motherboards
Beep codes Possible Causes Solution
1-2 no video card detected Reseat the video card
1-2-2-3 BIOS ROM checksum error
1-3-1-1 DRAM refresh error Reseat the memory card
1-3-1-3 Keyboard error Keyboard connector
1-3-3-1 memory card Reseat the memory card
1-3-4-1 RAM failure on line xxx Reseat the memory card
1-3-4-3 RAM failure on data bits Reseat the memory card
1-4-1-1 RAM failure on data bits Reseat the memory card
I hope it match your beep code..
Please rate this help.. thanks..
May 25, 2010 | Dell Dimension 3100 PC Desktop
Falal error 173 on oki c5650 after changing fuser unit
Cause:
This error indicates that the Image Drum Up/Down Process is not working properly.
The errors are as follows:
140 - Yellow Drum Up/Down error
141 - Magenta Drum Up/Down error
142 - Cyan Drum Up/Down error
Resolution:
1. Reseat the Image Drums. Ensure they are in seating properly into the drum carriage.
2. Reseat the Toner Cartridges. Ensure they are seating properly into the Image Drums.
3. Reseat the Contact Sensor Spring assembly and inspect it for damage or mis-alignment. If the springs appear bent or dis-lodged reseat them.
http://my.okidata.com/PP-C7200.nsf?opendatabase
Apr 23, 2010 | OKI C5650n LED Laser Printer
Where can you find the too to reseat the brake
you can rent it from an auto supply shop
Apr 16, 2010 | 2004 Ford F150
Continuous Beep-Beep-Beep.. When I turn on T3304 E Machine
there is a faulty hardware in your PC. here the beep error code this might help to locate the faulty hardware in your pc, and which help you to isolate the problem.
1 Short beep - System is operating normally.
1 Long beep - Memory refresh circuitry has failed which indicates a problem with the motherboard. Try
reseating the memory DIMM or SIMM modules. Make sure if you have added memory that it is rated at the correct speed for the system.
1 Long 2 Short beeps - The video adapter has failed, or the video memory is having a read/write
failure. Try reseating the video card. If the video card is a PCI video card, try moving it to another slot.
1 Long 3 Short beeps - The system does not detect a monitor. Verify that the monitor cable is properly attached to the video card or the onboard video and to the monitor (if the monitor has a detachable cable). If possible, try another monitor on the system to verify that the video adapter is operating properly.
2 or 3 beeps - There is a problem with the system’s memory. Reseat the memory DIMM or SIMM modules.
4 beeps - This indicates a non-functional timer. This indicates a problem with the motherboard.
5 beeps - This indicates a CPU (Central Processing Unit or processor) failure. Try reseating the processor.
6 beeps - This indicates a keyboard controller failure. Try reseating the keyboard connector.
7 beeps - Another indication of a processor problem. Reseat the processor.
8 beeps - This indicates a video memory read/write failure. Reseat the video card (if any) and memory DIMM or SIMM modules.
9 or 10 beeps - This indicates a ROM (Read-Only Memory) checksum error or shutdown register failure. This indicates a defective BIOS chip(s). Reseat the BIOS chips.
11 beeps - Indicates an error in the cache memory. If the system has a Pentium class processor, reseat the processor. If the system has a cache memory module, try reseating it. These beep codes will vary depending on the system
hope this would help.
Nov 30, 2008 | E-Machines eMachines Desktop PC
Dell dimension 3100 when turned on bleeps and no display on monitor
It depends on how many times it bleeps.
More info here: http://www.bioscentral.com/postcodes/dellbios.htm
Oct 28, 2008 | Computers & Internet
HP Pavilion dv6000z Notebook Logo
26 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
